Software Archive
Read-only legacy content
17060 Discussions
Project not loading
Igor_F_1
I was debugging a project and XDK emulation debugger became unresponsive.
I closed application by clicking 'X', application did exit.
After opening application again project did not load instead it appeared to be opened for the first time so I had to select project manually.
Project did not load and app got stuck with message "Opening project...".
Closing application will result in user interface being closed but nw processes will remain running.
I restarted PC and tried again. Project that gets loaded in seconds failed to load in 6 minutes.
Reinstalling app but leaving preferences did not help.
What should I do?
Igor_F_1
I solved by reinstalling the app and clearing user preferences on uninstall.
App loads fine, project is reset regarding some settings as well but seems to be working fine.
I must also add that emulators debugger is much more responsive now that settings and preferences have been erased, but that might just be me.
BR,
Igor
