Software Archive
Read-only legacy content
17060 Discussions
Push Notifications
Andrea_P_1
i'm trying to create an application that use Push Notifications. I've tried phonegap-plugin-push and OneSignal but even if both plugins are added correctly in the project they doesn't works when i try to debug them via Live Preview on Phone. Basically the plugin is not added into the available plugins and the Javascript classes are not present and so it fail when i try to call them.
Can anyone tell me how can i try to debug (or even use..) those libs to use notifications? Do i need to add some permissions in the build configuration?
Thank you
Anusha_M_Intel
Generic debugging only supports core plugins. If you want to test phonegap-plugin-push or onesignal, you will have to build either a custom debug module or build the app to test on device.
Refer to this page for information on custom debug module: https://software.intel.com/en-us/xdk/docs/using-the-debug-tab
And refer to this page for an alternative if you are having trouble with custom debug modules: https://software.intel.com/en-us/xdk/docs/using-the-debug-tab#generic_debug
Andrea_P_1
Yes thank you. I've resolved the fantastic OneSignal and debugging the app via "Debug" tab.
