Software Archive
Read-only legacy content
17060 Discussions
Pushwoosh iOS build fails
Mario_T_
I have XDK app that uses Pushwoosh service for push notifications. I'm using version 1816 of XDK. When I try to build iOS app i get an error
Error: Plugin "com.pushwoosh.plugins.pushwoosh" (3.4.11) failed to install.
App builds fine for Android crosswalk with same plugins.
There is no log which I can C/P.
John_H_Intel2
Are you trying to include that particular version for a reason?
I can successfully built an iOS 8 app using the default plugin value and the build log says
  • Plugin "com.pushwoosh.plugins.pushwoosh" (3.4.9) installed.
What are you specifying for the name and plugin ID? Local plugin or from the web?
Mario_T_
I wasn't specifying version number at all, i just added plugin through XDK interface. It used latest available version (3.4.11) as I can see.
I now tried downloading plugin locally and it worked (version is 3.4.11), but I don't understand why it doesn't work when I include it from the web.
Is there any kind of log I can take a look at (I'm using Linux)?
John_H_Intel2
Under Plugins, pick Get Plugin From Web, then enter the following into the fields:
pushWoosh ( can be anything you want)
(dont check the box)
https://github.com/Pushwoosh/pushwoosh-phonegap-3.0-plugin.git
You can see https://github.com/Pushwoosh/pushwoosh-phonegap-3.0-plugin for more info.
