Software Archive
Read-only legacy content
17060 Discussions
QR Scanner capture orientation
Abel_G_
There is any way to use the QR scanner in portrait mode instead the landscape mode when the camera opens?, because I don't see any option in the docs: https://software.intel.com/en-us/node/493099
Thanks a lot :)
Swati_S_Intel1
You can set the orientation using setRotateOrientation method prior to calling barcode.scan. https://software.intel.com/en-us/node/493051
Abel_G_
Hi Swati, thanks for your help
This is my code but I'm still viewing the scanner in landscape mode :(
document.addEventListener("intel.xdk.device.barcode.scan", function(evt) {
	if (evt.success == true) {
  		temp = evt.codedata;
	  	console.log(temp);
	} else {
		  console.log("fail");
}, false);
$('a').click(function(event) {
	intel.xdk.device.setRotateOrientation("portrait");
	intel.xdk.device.scanBarcode();
again, thanks for your help :)
Swati_S_Intel1
I believe you are trying on Android. I was able to reproduce it. I've filed a bug for this.
Swati
