Software Archive
Read-only legacy content
17060 Discussions
Quickwin, Accelerator-Keys
Intel_C_Intel
How can I generate accelerator-keys in a Quickwin-Application
and
how can I generate "fly-out/pop-up"-Sub-Menus in a Quickwin-Application?
It would be no problem to generate the resources for it
but how can I use the accelerator- and menu-resources?
many thanks
Burkhard Meyer
Jugoslav_Dujic
Valued Contributor II
AFAIK classic accelerators are out in QuickWin. The best you could achieve is to subclass QuickWin windows and intercept WM_KEYDOWN.
As for popup menus, here's a code snippet from an actual app which adds popup sub-menus to a QuickWin menu. Note that you have to subclass the window containing the menu in order to catch WM_COMMAND messages from these items.
SUBROUTINE AdditionalMenus
USE COMCTL
USE MSFWIN
USE MSFLIB
USE REGISTRY
IMPLICIT INTEGER(h-n)
INCLUDE 'Resource.fd'
CHARACTER*24::      szMenuName(0:3)=(/'&Topology Analyser�    'C,      &
                                      '&Load Flow�            'C,      &
                                      'State &Estimation�     'C/)
CHARACTER*32::      szItemName(4,0:3)=                                  &
                             (/'&Voltage level coloring�     'C,       &
                               '&Area coloring�              'C,       &
                               '&Feeder coloring�            'C,       &
                               '&Energization coloring�      'C,       &
                               '&Display options...�         'C,       &
                               '�                            'C,       &
                               '�                            'C,       &
                               '�                            'C,       &
                               '&Options...�                 'C,       &
                               '&Show toolbar�               'C,       &
                               '�                            'C,       &
                               '�                            'C,       &
                               '&Voltage quality�            'C,       &
                               'Operation planning�          'C,       &
                               '�                            'C,       &
                               '�                            'C/)
INTEGER,PARAMETER::     nItems(0:3)=(/4,1,2,4/)
INTEGER,PARAMETER::     IDItem(4,0:3)=                                  &
                        (/ID_BUTTON_PONAP,                              &
                          ID_BUTTON_POGRA,                              &
                          ID_BUTTON_POIZV,                              &
                          ID_BUTTON_POSTA,                              &
                          ID_BUTTON_TS,                                 &
                          0,0,0,                                        &
                          ID_BUTTON_ESTOPC,                             &
                          ID_BUTTON_VREME,                              &
                          0,0,                                          &
                          ID_BUTTON_OPTIMALNINAPON,                     &
                          ID_BUTTON_KVALITETNAPONA,                     &
                          0,                                            &
                          ID_BUTTON_OPPLAN/)
hMenu=GetMenu(hFrame)
hMenu1=GetSubMenu(hMenu,0)
DO i=0,3
      hAddMenu=CreatePopupMenu()
      DO j=1,nItems(i)
            iFlags=MF_BYPOSITION.OR.MF_STRING.OR.MF_ENABLED
            IF (i.EQ.0 .AND. j.EQ.4) iFlags=IOR(iFlags,MF_CHECKED)
            IF (i.EQ.3 .AND. j.EQ.3) iFlags=MF_BYPOSITION.OR.MF_SEPARATOR
            iSt=AppendMenu(hAddMenu,iFlags,IDItem(j,i),LOC(szItemName(j,i)))
!            iSt=SetM
enuItemBitmaps(hAddMenu,j-1,MF_BYPOSITION,hBojenjeBmp(j),hBojenjeBmp(j))
      END DO
      iSt=ModifyMenu(hMenu1,i,MF_BYPOSITION.OR.MF_POPUP.OR.MF_STRING.OR.MF_ENABLED, &
                     hAddMenu,LOC(szMenuName(i)))
END DO
END SUBROUTINE AdditionalMenus
Note that in the sample menus are created at run-time using CreatePopupMenu. It's probably possible to use LoadMenu from resources, though I didn't try it. Actuall
Jugoslav_Dujic
...continued
Note that in the sample menus are created at run-time using CreatePopupMenu. It's probably possible to use LoadMenu from resources, though I didn't try it. Actually, it adds four popup menus to the first four items of leftmost QuickWin submenu. nItems is number of items in each sub-submenu, szItemName names of items, IDItem are item IDs (added manually into .rc file, though any set of IDs will serve). hFrame is QW frame window (GetHWNDQQ(QWIN$FRAMEWINDOW)). As noted above, you'll need to subclass hFrame (SetWindowLong(GWL_WNDPROC)). If you're not familiar with it, you may refer to DFWIN samples or search for, say, GWL_WNDPROC in the Forum for few samples. You'll have to catch WM_COMMAND and test whether LOWORD(wParam) matches any of IDs assigned to menu.
HTH
Jugoslav
Intel_C_Intel
Thank you for your help.
I successfully created a popup-menu and "MyWndProc".
I receive the WM_COMMAND-Messages and the ID-No's for
the popup-menu-selection. Wonderful.
But I don't receive any WM_KEYDOWN-message in "MyWndProc"
to get the codes for accelerator-keys.
What could solve this problem?
Jugoslav_Dujic
The problem is that WM_KEYDOWN is sent to the window which has keyboard focus; in a QuickWin app that's usually a MDI child. However, that implies that you should subclass all child windows in order to have that effect.
A better method would be to use a keyboard hook for your application. Hooking is similar to subclassing, except that it works on a "higher level", i.e. it filters messages before they reach any window in the application. The following hook watches for release of "Ctrl" key in windows hFrame and hChild and does something when it's released. You could easily adapt it by testing for different key(s) (see description of "KeyboardProc" in help).
!Of course, explicit interface for KeyboardProc here.
hKbHook=SetWindowsHookEx(WH_KEYBOARD,LOC(KeyboardProc),NULL,0)
INTEGER(4) FUNCTION KeyboardProc(nCode,wParam,lParam)
!DEC$ATTRIBUTES STDCALL::      KeyboardProc
USE DFWIN
USE COMCTL
USE GLOBALS
USE REGISTRY
IMPLICIT NONE
INTEGER,INTENT(IN)::    nCode,wParam,lParam
INTEGER::               hFocus
LOGICAL::               bSt
TYPE(T_POINT)::         PT
INTEGER::               iEvent,  &
                        nKey,    &
                        iSt
INCLUDE "Resource.fd"
IF (nCode.LT.0) THEN
      KeyboardProc=CallNextHookEx(hHook,nCode,wParam,lParam)
      RETURN
END IF
!Bit 31 specifies transition state of the key
nKey=wParam
IF (IAND(lParam,ISHFT(1,31)) .NE.0) THEN
      iEvent=WM_KEYUP
ELSE
      iEvent=WM_KEYDOWN
END IF
hFocus=GetFocus()
IF ((hFocus.EQ.hFrame .OR. hFocus.EQ.hChild) .AND. iEvent.EQ.WM_KEYUP) THEN
      SELECT CASE (wParam)
      CASE (VK_CONTROL)
            IF (PROMENA_ZUMA) THEN
                  PROMENA_ZUMA=.FALSE.
                  iSt=ReleaseCapture()
                  CALL SetDefAppCursor()
                  CALL Draw(Zum, -1. ,-1.)
            END IF
      END SELECT
END IF
KeyboardProc=CallNextHookEx(hKbHook,nCode,wParam,lParam)
END FUNCTION KeyboardProc
Note that, like with subclassing, hKbHook variable has to be globally saved and the hook has to CallNextHookEx so that it doesn't break existing hook system.
HTH
Jugoslav
isn-removed200637
Of course you still have the ability to use letter1letter2 where 'letter1' is the
letter preceded by '&' in the text tag of one of the main QUickWin window's menu item's and 'letter2' is the
letter preceded by '&' in a text tag in the drop-down menu that letter1 opens.
Intel_C_Intel
Thank you for your Help.
But still I couldn't make the solution for the accelerator keys work.
Using "hKbHook= SetWindowsHookEx(WH_KEYBOARD_LL,LOC(MyKbProc),NULL,0)" etc. was not successful. I don't receive any message in MyKbProc. What could be the problem? Many thanks, Burkhard
Jugoslav_Dujic
You should use WH_KEYBOARD, not WH_KEYBOARD_LL. WH_KEYBOARD_LL should be used for system-wide low-level hooks; WH_KEYBOARD is sufficient. Moreover, the routine that calls SetWindowsHookEx should have an knowledge that MyKbProc is local procedure somehow (do you use IMPLICIT NONE?). Maybe EXTERNAL would suffice -- I'm not sure -- I always use either INTERFACE blocks
or MODULE association.
HTH
Jugoslav
