Looking at the replies to an earlier post (dated 5-23-2001), I found out that this problem occurs if you specify a large window and your display is set to a high combination of resolution and color depth. I have a couple of follow-up questions:
1. How can I determine the largest allowable size? Is it machine or OS-dependent? By experimentation, I found a maximum of approximately 8E6 pixels on one machine.
2. Can I reduce the color depth with SETWINDOWCONFIG? I want to use this window to display a large monochrome (not gray scale) bitmap file? SETWINDOWCONFIG is allocating 8 bits per pixel, when all I need is one bit.
3. Is there a substitute for setwindowconfig that would get around this problem? It seems that pure windows applications are able to use much higher window sizes.
Gabriel
Gabriel
The maximum window size is OS-dependent - Windows 9X/Me is much more restrictive. The color depth is taken from your video adapter settings - you can't change it with SETWINDOWCONFIG.
I asked Bill Conrad about this, and he says that if you already have a bitmap created, you can display it. Attached (I hope) is a small program that demonstrates this.
Steve
Steve
Steve,
Thanks for your response. I still have a question. How can I determine (or how can my program determine) the maximum size for a particular OS. I already know the limits for W98, but I would like users of my program in W2000 or NT to be able to use the greater resolution. Also, the technique of calling setwindowconfig a second time ifit returns an error does not seem to work.
Gabriel
Gabriel
Sorry - I don't know of a way to determine this in advance. I think on Windows 2000, it's limited by your available virtual memory, but on 9X, there's some smaller limit.
Steve
Steve
I got the same error message in a quick win application when enlarging the child window buffer to more than 2047 lines: I have a AC with 512 MA Ram, WIN 2000 and enough (> 1 GA) virtual memory available: it is possible to check or enlarge the allocated memory?
