Software Archive
Read-only legacy content
R on Xeon Phi
CPati2
New Contributor III
Hi All,
Is it possible to make use of OpenMP thread distribution and affinity for R on Xeon Phi? If yes, please share resources that can help understand how to optimize R for Xeon Phi.
Since, R code runs on R engine and doesn't go through the linking process, I am not sure how this will work out.
Any suggestion will help.
Sebastian_S_Intel
To take advantage of OpenMP you have to use library that uses it like MKL.
Here are interesting resources which may be helpful:
Sebastian_S_Intel
jimdempseyatthecove
Google:   multithreaded r programming
http://www.cs.toronto.edu/~radford/ftp/pqR-guelph.pdf
http://www.win-vector.com/blog/2016/01/parallel-computing-in-r/
http://garthtarr.com/parallel-computation-in-r/
There are additional links that may be of interest via the above search
Jim Dempsey
