Software Archive
Read-only legacy content
17060 Discussions
#RESOLVED# Issues to build app from any computer installed Intel XDK. (Error: Plugin....)
Rodrigo_M_1
New Contributor II
Hi Intel support team, I would like to report a problem with Intel tool.
Some days ago I start seeing some "Error: Plugin" on build app.
Fisrt I start get Error: Plugin "StatusBar" failed to install .
So I just removed once I'm not using this plugin yet... but now I got Error: Plugin "Device" failed to install  .
So, after that I have tested couple of projects in a couple of computers that I have installed the Intel XDK, and I notice that doesn't matter the computer / project...
Some time on same computer, on same project I try to upload the project and rebuild it and get the Device plugin error or StatusBar...
I have tried to remove / add again these plugins to the projects and no success...
I think maybe is something on server side... because some times I'm just able to build the application with success!
Note: Almost time I got error is with the projects that have the StatusBar plugin !
 StatusBar plugin Version: 2.0.0
Cordova CLI 5.1.1
Eric_H_Intel
I cleared a corrupt cache on the build server that may have been causing the issue.   Try your build again and let me know if you are still seeing the failure.
Eric
Rodrigo_M_1
New Contributor II
After a couple of tests, seems to be a problem on build server side (for Device plugin) because I have created a new project, uploaded to Intel XDK Server and build it with success !
Just after success I rebuild the same project and got error on plugins Device and Splashscreen ... I rebuild it without re-upload the files and the build was success!
So looks like there some problem / conflict on server side that needs more attention to be fixed!
Please let me know if there's anything that may I can help!
Rodrigo.
PaulF_IntelCorp
Thank you for that info, Redrigo. I will alert our build system team.
Eric_H_Intel
Eric
Rodrigo_M_1
New Contributor II
Hi Paul / Eric, I just rebuild with all plugins and works with success!
Thanks for your help guys!
Rodrigo.
