Software Archive
Read-only legacy content
17060 Discussions
Random number
Intel_C_Intel
Can anyone tell me how to get a random number that is different each time when the routine is excuted?
Intel_C_Intel
Call RANDOM_SEED with no arguments at the start of your main program. The initializes the seed of the RANDOM_NUMBER subroutine with a value taken from the RTC, I think. If you don't execute the program back to back with less time between invocations than the granularity of the RTC (1 second?) you will get a different set of values from RANDOM_NUMBER each time the program runs.
Steven_L_Intel1
James is correct, as it applies to Compaq Fortran, but I will caution you that this behavior (randomizing the seed based on the clock) is not specified by the standard. All the standard says is that a call to RANDOM_SEED with no arguments sets the seed to an implementation-defined value. It could be the same value run to run (and in fact was, in our initial implementation.)
Steve
Intel_C_Intel
James and Steve:
Thank you very much for your replies. Indeed, my question is how to generate a set of random numbers, say m random numbers, between 1 and N. Here m and N are integers and m <= N.
Intel_C_Intel
module all_my_functions
   implicit none
   contains
      subroutine sub
         integer m
         integer N
         integer, allocatable :: ran_ints(:)
         real, allocatable :: harvest(:)
         character(20) fmt
! Get the number of random numbers
         write(*,'(a)',advance='no') 'How many random numbers do you want:> '
         read(*,*) m
! Get the range of random numbers
         write(*,'(a)',advance='no') 'What should their maximum value be:> '
         read(*,*) N
! Make the arrays big enough
         allocate(ran_ints(m),harvest(m))
! Create random real array
         call random_number(harvest)
! Create random integer array
         ran_ints = harvest*N+1 ! Needs at least CVF 6.5 to work
! Write out results
         write(fmt,'(a,i0,a)') '(',m,'(i0:1x))'
         write(*,fmt) ran_ints
         return
      end subroutine sub
end module all_my_functions
program ran_test
   use all_my_functions
   implicit none
   character(1) response
   character(6) :: again = ''
! Put this call once in the main program; you shouldn't call
! random_seed again in the program
   call random_seed()
! Loop while the user wants to test the subroutine
   response_loop: do
      write(*,'(a)',advance='no') 'Do you want to run the test'
      write(*,'(a)',advance='no') trim(again)//' [y|n]:> '
      read(*,'(a1)') response
      select case(response)
         case('y','Y')
            call sub
            again = ' again'
         case('n','N')
            exit response_loop
         case default
            write(*,'(a)') "Your response, '"//response//"', was invalid"
            write(*,'(a)') "Please enter 'y' or 'n' at the prompt"
      end select
   end do response_loop
end program ran_test
