Software Archive
Read-only legacy content
17061 Discussions
Reading registry values (2nd try)
Intel_C_Intel
Sorry for posting a second time. The spell checker sort of wacked my first post...
I'm trying to read a string from the registry to implement design-time licensing in a COM DLL, which I've written in Fortran 6.5. I can successfully open the registry key, but when I try to read the REG_SZ value via RegQueryValueEx PI function, I get the following first-chance exception:
First-chance exception in OlisGW.exe (ADVAPI32.DLL): 0xC0000005: Access Violation.
I've used this same sort of licensing technique from I++ COM DLLs written in ATL, so I know the process works. Can anyone shed light on my problem? The code I am using is listed below.
Michael Gerfen
    !  CanRequestLicenseKey
    function CanRequestLicenseKey result
        use dfwin
        implicit none
        logical r
        !  TODO:  Add code to determine if the class is design-time licensed
        !         on this machine and we can return the license key in a
        !         call to GetLicenseKey
        integer(INT_PTR_KIND()) bstrKey
        integer(INT_PTR_KIND()) bstrLicense
        integer(LONG) hresult
        integer(LONG) retval
        integer(LONG) iLen
        character(1024) license
        integer hKey
        iLen = 1024
        if ( RegOpenKeyEx(HKEY_CURRENT_USER, Key, 0, &
            KEY_QUERY_VALUE  , loc(hKey) ) == ERROR_SUCCESS) then
           !this line causes the first-chance exception
           retval = RegQueryValueEx( hKey, "Fortran License"C, NULL, 1, loc(license), loc(iLen) )
           bstrLicense = ConvertStringToBSTR(license)
           hresult = GetLicenseKey(bstrKey)
           if (bstrLicense .EQ. bstrKey) Then
               r = .TRUE.
           else
               r = .FALSE.
           end if
        end if
    end function
Intel_C_Intel
The fourth parameter to RegQueryValueEx is an out parameter. Pass either NULL or loc(somevar).
hth,
John
Intel_C_Intel
John,
Doh! Thanks, that did the trick.
Michael
