Sorry for posting a second time. The spell checker sort of wacked my first post...
I'm trying to read a string from the registry to implement design-time licensing in a COM DLL, which I've written in Fortran 6.5. I can successfully open the registry key, but when I try to read the REG_SZ value via RegQueryValueEx PI function, I get the following first-chance exception:
First-chance exception in OlisGW.exe (ADVAPI32.DLL): 0xC0000005: Access Violation.
I've used this same sort of licensing technique from I++ COM DLLs written in ATL, so I know the process works. Can anyone shed light on my problem? The code I am using is listed below.
Michael Gerfen
Michael Gerfen
! ! CanRequestLicenseKey ! function CanRequestLicenseKey result use dfwin implicit none logical r ! TODO: Add code to determine if the class is design-time licensed ! on this machine and we can return the license key in a ! call to GetLicenseKey integer(INT_PTR_KIND()) bstrKey integer(INT_PTR_KIND()) bstrLicense integer(LONG) hresult integer(LONG) retval integer(LONG) iLen character(1024) license integer hKey iLen = 1024 if ( RegOpenKeyEx(HKEY_CURRENT_USER, Key, 0, & KEY_QUERY_VALUE , loc(hKey) ) == ERROR_SUCCESS) then !this line causes the first-chance exception retval = RegQueryValueEx( hKey, "Fortran License"C, NULL, 1, loc(license), loc(iLen) ) bstrLicense = ConvertStringToBSTR(license) hresult = GetLicenseKey(bstrKey) if (bstrLicense .EQ. bstrKey) Then r = .TRUE. else r = .FALSE. end if end if end function
The fourth parameter to RegQueryValueEx is an out parameter. Pass either NULL or loc(somevar).
hth,
John
hth,
John
John,
Doh! Thanks, that did the trick.
Michael
Michael
