Software Archive
Read-only legacy content
17060 Discussions
RealSense R200 depth camera not properly recognised in SDK
HFC
I am trying to capture the depth stream of the RealSense R200 developer camera using the latest RealSense SDK on a 64bit Windows 8.1 machine with i7 processor. Although the depth camera is detected, it doesn't seem to be recognised as a depth stream device. When I query the device, the stream type associated with the depth camera is STREAM_TYPE_COLOR, not STREAM_TYPE_DEPTH. If I try to run the '2_RawDataCapture' example, it only works when enabling the PXCSenseManager with STREAM_TYPE_COLOR, but not with STREAM_TYPE_DEPTH. Also, if I run the 'RawStreams' example, I can visualise the stream from the depth camera, but the resulting video feed does not look at all as a depth map. I get a video stream that is green instead of grey-scale and very noisy with double vision of objects.
I am not sure what I am doing wrong. Does the current RealSense SDK actually support the R200 camera? If not, when will the SDK for the R200 camera be released?
Colleen_C_Intel
The R200 support in the R2 SDK is at alpha - very limited features supported. As this camera is not generally available (I have yet to see one) and so you might check with where you got the camera for now. I may be seeing one next week and will answer then if I have more information.
samontab
Valued Contributor II
I wish I could have access to the R200 :)
