Software Archive
Read-only legacy content
17061 Discussions
RealSense the Streams possible sends by network (UDP or TCP/IP)?
jarikus
Is it possible to send RealSense the Streams like (Color Stream, Depth Stream and IR Stream)  to other computer over network (UDP or TCP/IP)?
For example I run 3D camera on NUC device and on another AIO connect to NUC to this streams, in the same manner as Havok Physics Visual Debuger.
Colleen_C_Intel
The RSSDK 2014 Gold R1 is only supported on Windows 8.1  And FPS in the range you mention are far out of expectations for the camera.
Colleen_C_Intel
Can you describe why you would want to stream feed to another computer?  Is it to get more computing power or ??
jarikus
Can you describe why you would want to stream feed to another computer?  Is it to get more computing power or ??>
Yes it will be good too. For example for my project on the 3-rd generation processor Intel® Core™ i5-3337U on AIO gives me 500 FPS and on NUC Intel(R) Core(TM) i5-4250U gives 300 FPS.
Also this opportunity gives us work with RealSense on older CPU and test this technology on other OS like Linux, MacOS.
Colleen_C_Intel
Jonathan_G_
I support the first and main question regardless the use, is there a way to get all that data over UDP, TCP. Applications are endless such as robotics, telepresence, VR, AR, FPV, thanks in advance for your quick answer.
samontab
Valued Contributor II
This functionality is actually part of a project that I'm working on.
Maybe you guys would be interested in doing a beta testing for it.
jarikus
samontab>
Your project have client/server architecture?
I can test your project. I think best environment for test is:
1) run server on NUC Windows 8.1 with camera R200.
2) run client on Linux (if it possible) and retrieve RealSense streams on Linux.
I think if your clients program will run on Linux/MacOS then your project can have commercially successful in future.
