Software Archive
Read-only legacy content
17060 Discussions
Recorded streams (.rssdk) play back out of order
Max_L_1
I have been using the DF_RawStreams SDK sample to record streams for later playback and processing. When playing a captured stream back I've often noticed that there is occasional jerkiness or jumping. When I inspect these captures in the clip editor I see that the frame timestamp will sometimes jump backward, then forward again. Usually this only happens at the beginning of the recording but sometimes it will be throughout, rendering the capture unusable. What can be done to mitigate or fix this issue?
Max
Xusheng_L_Intel
Could you send us the .rssdk file so we can do further investigating? Thanks!
