Software Archive
Read-only legacy content
17060 Discussions
Regarding building a native application for Intel Xeon Phi Coprocessors
dingjun_chencmgl_ca
I am very interested in building a native application for Intel Xeon Phi Coprocessor. As you know, the embedded Linux operating system runs on the Intel Xeon Phi coprocessors. My question is as follows:
Can I use the Intel Fortran Compiler XE 13.1 for Windows (Intel® Composer XE 2013 for Windows ) to build a native application running on the Intel Xeon Phi Coprocessors? Otherwise, Intel® Composer XE 2013 for Linux  can only be used to build a native application that can be excuted on the Intel Xeon Phi coprocessors.
I look forward to hearing from you. Thanks.
Ravi_N_Intel
use -mmic option to build a native application.  All this is documented in the Compiler User Guide.
icc -mmic  nativeapp.c   or ifort -mmic nativeapp.f
dingjun_chencmgl_ca
Thanks for your reply.  In fact, my concern is that:
Is Intel® Composer XE 2013 for Windows able to build a native application? such a native appliation is able to be excuted on Intel Xeon Phi coprocessors with Linux uOS.
Ravi_N_Intel
You will need the Windows beta compiler to build a native on Windows.
Kevin_D_Intel
You may not build a “Windows” application to run natively on the coprocessor because the coprocessor is running Linux.  Whether building a native application on the Linux-host or Windows-host, the native application is always a Linux application.
As Ravi indicates, the Composer XE 2013 SP1 Beta supports building the native coprocessor application on the Windows-host. Refer the following URL for more information about the Windows* Early Enabling now open to the public - http://software.intel.com/en-us/forums/topic/392264
