Software Archive
Read-only legacy content
17060 Discussions
Remove admob banner problems?
John_E_2
Hello!
iam using this script to show my admob but i dont want the banner to show only the interstitial.
now both shows up, can i remove the banner and only show the interstitial?
can someone help me?
<script src='cordova.js'></script>
    <script type="text/javascript">
       var onDeviceReady=function(){
           navigator.splashscreen.hide();
           initAdMob();
           showAdMobInterstitial();
           showAdMobBanner();
        document.addEventListener("deviceready",onDeviceReady,false);
       function initAdMob(){
           if ( window.plugins && window.plugins.AdMob ) {
               var admob_key_banner = "xx";
               var admob_key_interstitial = "xx";
               window.plugins.AdMob.setOptions( {
                   publisherId: admob_key_banner,
                   bannerAtTop: true, // set to true, to put banner at top
                   overlap: false, // set to true, to allow banner overlap webview
                   offsetTopBar: true, // set to true to avoid ios7 status bar overlap
                   interstitialAdId: admob_key_interstitial,
                   autoShow: true, // autoshow intertitial Ad
                   isTesting: false // receiving test ad
           } else {
               alert("AdMob plugin not ready");
       function showAdMobBanner(){
           window.plugins.AdMob.createBannerView();
       function showAdMobInterstitial(){
           window.plugins.AdMob.createInterstitialView();
    </script>
Elroy_A_Intel
I recommend removing all references to properties and methods including "banner" in the name.
John_E_2
thanks for your replay.
function destroyAdMobBanner(){
worked too.
Hamilton_Tenório_da_
Valued Contributor I
do you build this function (destroyAdMobBanner) or it exists in the plugin?
John_E_2
i changed this line in the plugin:
to this:
Here is the whole code without the admob banner, only interstitial:
intel xdk plugin---------->com.rjfun.cordova.plugin.admob. And check the Plugin is located in the Apache Cordova Plugins Registry
           initAdMob();
           showAdMobBanner();
               var admob_key_banner = "yourkey";
               var admob_key_interstitial = "yourkey";
           } else {
    </script>
@John> thank you
