Software Archive
Read-only legacy content
17060 Discussions
Report active license expired for C++ STM Compiler 3.0 for Linux
lili2014
I download the C++ STM Compiler 3.0 and install it using an active evaluation license for C++ Compiler for Linux.
The installation is successfully complete. But it reports errors that my license has expired when I try to run it.
lili@lili-desktop:~$ icc
Error: A license for BetaSTMCCompL could not be obtained.
Your license has expired.
License file(s) used were (in this order):
1.. 2.. 3.. 4.. 5.. 6.. 7..
Please visit http://www.intel.com/software/products to obtain license renewal information.
icc: error #10052: could not checkout FLEXlm license
Has anyone met this problem before? I need your help. Thank you!
baghdadi_riyadh
Quoting - lili2014
Many people are having the same problem, (including me)
I downloaded the Intel pro version (NOT STM version), I used the key (it was a key that I got when I downloaded this Pro version last Spetember, but since then I formated my PC and I'm using now a new Ubuntu installation)
I the uninstalled Intel C++ pro (11.0), after using it for one day (successfully), and then Installed the Intel STM version (Intel C STM Compiler Professional for applications running on IA-32, Prototype Edition 3.0 Build 20081204 Package ID: l_cproc_p_11.0.606)
And now it shows the same problem !
lili2014
Quoting - baghdadi_riyadh
Really? So has anyone figured out this problem? It is strange, I have used C++ STM compiler 2.0 before but there is no such problem. i cannot find a place to download 2.0 now.
JenniferJ
Quoting - lili2014
This is not the right forum for this question. I'll transfer you to the correct place so you'll get the help needed.
Jennifer
degomme
I'm having the same problem here.
After a quick investigation, in the/opt/intel/Compiler/11.0/606/bin/intel64/l_cpp_32e_cd.lic license file, there is the line
FEATURE I0000000000000000000G000000000 INTEL 2008.1208 31-dec-2009
(I guess this line isn't too confidential for the forum)
The expiration date seems to be set to the 12/31/09, so the license has now expired. This is causing us some trouble. I didn't try to change it by hand in the file as I'm not root on the machine, but if someone wants to try...
If someone from Intel could answer us about this and tell us if it's intentional or if it's just a bug and then provide a new license file, I'd be glad.
Cordially,
lili2014
Quoting - degomme
Cordially,
Just changing the time in .lic file will not work, I have tried. There are more issues about security.
If anyone has no time to wait for intel's renewal, I suggest an awkard and effective method. Just change the time in YOUR system! It is done,
Li,
cam14
Me too, and my license file is new and has not expired. Using: Ubuntu Jaunty 9.04
Update: Setting the date back works for me. Seems to be a bug with 2010.
Cheers
drc5
Quoting - lili2014
Jennifer
I am having the same problem. I don't want to change the time on my system.
Jennifer,
Can you suggest the right place to get help since this seems to be not the right forum. Thanks.
aplicacions_cesga
I'm having the same problem, too!!!
Does anyone know another solution?? Without changing the time in the system. I working in a cluster and this is not an option.
chuckzhao
Quoting drc5
Quoting - lili2014
Jennifer
Jennifer,
Quoting drc5
Quoting - lili2014
Jennifer
Jennifer,
This now becomes a road-blocker for me.
If there a temp fix?
Does anybody know if/when Intel will release a new ICC STM build that extends the existing temp license?
Cry for a fix......
Thank you
Chuck
lois_orosausc_es
I have the same problem!!!! Suggestions??? (I can't change the time on the computer)
lois_orosausc_es
I guess that the version 2.0 works fine, Where can I download it???
Thank you very much
AaronTersteeg
The Team is aware of the issue. The Intel C++ STM compiler 3.0 licenses are expired for users to use, the Intel C++ STM compiler 4.0 that supports Draft Specification of Transactional Language Constructs for C++(http://software.intel.com/file/21569132kb PDF) will be posted in a few months.
Ravi_N_Intel
Tentatively the current plan is to release C++ STM Compiler 4.0 by end of August 2010.
Guoliang_Z_
i'm facing the same problem for Intel STM Compiler 3.0. And my licenses expires, I would apprecialte if anyone give me a solution.
