Dear all, I am new here.
I have a project to do with university and we would like to use the Real Sense 3D Camera R200, which is available. I started to have a look at it, as well I go through samples given with documentation.
My question is which requirements I need to code with the RealSense SDK according to you? I have the basis of C/C++ gained during two academic courses, and I used C# for a recent project. I am wondering if C# is better from a visual point of view.
Besides, any suggestion is appreciated.
Thank you in advance for any kind reply.
Since the RealSense SDK contains sample programs written in both C++ and C#, and the manuals have sample code in both C++ and C#, I assume that either is a valid option for developing applications in RealSense.
If you are planning on developing using the Unity game engine though, you will have a much easier time if you write scripts in C#, otherwise your code will have to be treated as external C++ plugin files rather than an integral part of the application like C# scripts are.
Thank you very much for your answer.
Actually, I do not know if I really need to code for this project; that means, my questions was irrelevant. However, thanks again for the feedback.
