Software Archive
Read-only legacy content
17060 Discussions
Run a function when a new view (window) is loaded
Denis_L_
Hi, I am new in Intel XDK , and the version I am using is 1878. I am trying to fire a function when the system change page (new view show). I did try the following  code :
document.getElementById('agreementPage').addEventListener('panelload', function(){
alert("you're in agreementPage  view!");
}, false);
But this did not work. It’s look like the notion of panel is not used anymore, The system just hidden and show the div containing the information of the new view.
<div class="upage vertical-col hidden" id="mainpage">
<div class="upage vertical-col left " id="agreementPage">
I also did try to include a onpropertychange="functionOnShow()" tag to the div without success.
I will appreciate all advice.
Thank you
Barry_Johnson
I am assuming you are using the Intel App Framework, but you don't mention which version you are using: 2.x or 3.x.
Please see this discussion thread from the App Framework section of the board which might be helpful.
Denis_L_
Thanks a lot Barry, this discussion tread was very useful.... everything is in order now... Thanks again Denis
