Software Archive
Read-only legacy content
17060 Discussions
Running image on qemu
Michal_Pawlowski
Does anyone knows how do I run galileo iot image on qemu?
When I call runqemu from the build folder like this:
runqemu qemux86 tmp/deploy/images/clanton/bzImage--3.8-r0-clanton-20140220130836.bin tmp/deploy/images/clanton/iot-devkit-prof-dev-image-clanton.ext3
qemu fires up but freezes on "Booting the kernel." message
Brendan_L_Intel
I don't recommend this at all, you'll need to change kernel etc... also if you're already running linux it's pointless really, just use chroot. If you run a 64bit linux use linux32 in front of the chroot command and you're good to go (remember to mount /proc, /dev and /sys). schroot is a very good chroot util if you don't want to manually do chroots all the time : https://wiki.debian.org/Schroot
Michal_Pawlowski
Nice one. That will be a great for travelling.
Btw is there any way that I could simulate interacting with a real board, setting gpios and plugging "virtual devices" for example?
Christopher_M_2
Hay Brendan,
Thanks for the ptr to schroot.
Been running Sid since as far back as Potato (or so) and never ran across that one.
Thanks man   Chris
Matthias_H_Intel
sidenote: if your Linux host is x64 and you want to compile within chroot make sure to compile for the right architecture (e.g. -m32 when using gcc)
