Software Archive
Read-only legacy content
17060 Discussions
Runtime installer is not enough to run app
IPetr1
Tried running apps (including demos) on fresh Windows 8.1 with RealSense SDK runtime (intel_rs_sdk_runtime_3.1.0.85181.exe, 374 MB) only installed and they all report “Init failed”.
Meaning full RealSense SDK is required (intel_rs_sdk_offline_package_r_3.1.0.85181.exe, 1.5 GB) to be able to run apps.
What's the catch with runtime installer?
Ivan
Colleen_C_Intel
Do you have DCM installed?
IPetr1
Not sure what DCM is.
When intel_rs_sdk_runtime_3.1.0.85181.exe only is installed apps are not working.
When intel_rs_sdk_offline_package_r_3.1.0.85181.exe is installed apps are working.
I guess some component should be added to runtime installer.
kunal_b_
I am having the same issue.
After compiling the app with Unity into an executable the App no longer works.
Any help
Its Urgent
S__A_
Intel RealSense Depth Camera Management (DCM) Driver
S__A_
When you run sdk_info.exe in C:\Program Files\Intel\RSSDK\bin\x64 it should look similar to the attached screen shot below highlighting the DCM version.
