Software Archive
Read-only legacy content
17060 Discussions
SDK Sample Browser error
Andrey_A_
"Referenced SDK components are not registered on the machine or SDK roo directories not found".
RSSDK_DIR variable seems to be ok. What components can be not registered?
Xusheng_L_Intel
Could you provide us the installer log to me? You can find this log @C:/Users/<user>/AppData/Local/Temp/micl_tmp_<user>. Installer logs are arranged in dates and sequences. Zip and collect the right log. Thanks!
Andrey_A_
Xusheng_L_Intel
What is your RSSDK_DIR value? Do you have this directory(C:\Program Files (x86)\Intel\RSSDK\data\sample_browser) in your computer?
Andrey_A_
No i don't have this directory. My RSSDK_DIR value is just C:\Program Files (x86)\Intel\RSSDK
Xusheng_L_Intel
Do you have RSSDK/samples/sample_browser/data directory? Thanks!
Andrey_A_
Yes, I do.
Xusheng_L_Intel
Could you run SDK_INFO in advanced mode and send me the log file? It is pretty strange you can not run SDK sample browser. Did you run this under C:\Program Files (x86)\Intel\RSSDK\bin\win32? Thanks!
Andrey_A_
428750
Yes, I run this  under C:\Program Files (x86)\Intel\RSSDK\bin\win32
Xusheng_L_Intel
It can be some other installation issue when not all files copied properly. The only thing I can recommend is to reinstall SDK. Thanks!
Kosta_D_
I had the same problem, then I run SDK sample browser as administrator and it worked. You have to run each sample as administrator!!!
NANDKISHOR_S_Intel
Thanks Kosta!    Yes, running 'SDK Sample Browser' in administrator mode resolves the issue.
RBang
New Contributor II
Right click on SDK sample browser ->  Properties -> Advanced -> Click to select the Checkbox next to Run as Admin ->  Click OK -> Click Apply -> When the access denied popup shows up select continue -> Click OK
Now you won't have to always select run as Admin while starting the program.
