Software Archive
Read-only legacy content
17061 Discussions
SMC Boot Loader Version : 1.2.3257
Ruibang_L_
I'm asking for an older SMC bootloader version, 1.2.3257, can Intel or anyone who have the older firmware pass me the file? Thanks in advance.
Frances_R_Intel
What version are you running now? It will make a difference in what you need.
Ruibang_L_
I'm using the 6720-15 driver version.
I failed flashing my 3100p, i've tried several times using command "mpssflash --device all --smcbootloader update", but everytime it returns
mic0: SMC update started
mpssflash: mic0: Flash operation timed out
mic0: Resetting
However, I can run programs on the card properly, despite micinfo and micsmc failed to retreive information from the card.
Vitaly_V__K_
Try to get info using command "micflash -getversion -device all" in ready state. It works for me while micinfo can't get firmware version of ours 5110P cards.
Vitaly_V__K_
Try the following methon which I used to resolve similar problem.
1. Disable mpss service "chkconfig mpss off" and reboot the host system.
2. Power off the host system and unplug AC cables on time about 10 seconds.
3. Power on the host system and make the second stage of the firmware updating
[bash]/opt/intel/mic/bin/micflash -update -smcbootloader -device all[/bash]
Frances_R_Intel
For additional information on dealing with very old version of flash and smc, see https://software.intel.com/en-us/forums/topic/534424. In the general case, the solution given by Vitaly should be successful.
