Software Archive
Read-only legacy content
17060 Discussions
SMC bootloader flash fails
john_p_2
We have an Intel Xeon Phi 3120A for which we can't update the SMC Flash and SMC Bootloader flash. Any suggestions are greatly appreciated !
First of all I'd like to mention that the blue LED is not blinking at any time during the procedures described below. It is always solid blue. Not sure if it's supposed to be like that.
When we first installed the board in the computer it had flash version 3.72 so we ran a flash update on it to bring it up to the current version (3.90).
We ran:
micflash -update -v -device all -log micflash.log
and the log file shows the following:
Fri Oct 24 16:48:27 2014: micflash: Tool version: 3.4-1
Fri Oct 24 16:48:27 2014: mic0: Flash image: /usr/share/mpss/flash/EXT_HP2_B1_0390-02.rom.smc
Fri Oct 24 16:48:27 2014: mic0: Flash update started...
Fri Oct 24 16:48:29 2014: mic0: Flash update done
Fri Oct 24 16:48:29 2014: mic0: SMC update started...
Fri Oct 24 16:48:29 2014: micflash: mic0: SMC update failed: SMC buffer size exceeded (0x1)
Fri Oct 24 16:48:29 2014: mic0: SMC update: 0% was completed
Fri Oct 24 16:48:30 2014: mic0: Transitioning to ready state...
Fri Oct 24 16:48:39 2014: mic0: Exit status: 10
Then, we followed instructions provided in other posts and we power cycled the computer and then, immediately after reboot, without starting the mpss service, we ran the following command:
micflash -update -v -smcbootloader -device all
but unfortunately we get the same message:
Fri Oct 24 16:53:55 2014: micflash: Tool version: 3.4-1
Fri Oct 24 16:53:55 2014: mic0: Flash image: /usr/share/mpss/flash/EXT_HP2_B1_0390-02.rom.smc
Fri Oct 24 16:53:55 2014: mic0: SMC boot-loader image: /usr/share/mpss/flash/EXT_HP2_SMC_Bootloader_1_8_4326.css_ab
Fri Oct 24 16:53:55 2014: mic0: SMC boot-loader update started...
Fri Oct 24 16:53:55 2014: micflash: mic0: SMC update failed: SMC buffer size exceeded (0x1)
Fri Oct 24 16:53:55 2014: mic0: SMC boot-loader update: 0% was completed
Fri Oct 24 16:53:56 2014: mic0: Transitioning to ready state...
Fri Oct 24 16:54:05 2014: mic0: Exit status: 8
The result of micinfo is this:
    System Info
        HOST OS            : Linux
        OS Version        : 3.10.0-123.el7.x86_64
        Driver Version        : 3.4-1
        MPSS Version        : 3.4
        Host Physical Memory    : 32682 MB
Device No: 0, Device Name: mic0
    Version
        Flash Version          : NotAvailable
        SMC Firmware Version     : NotAvailable
        SMC Boot Loader Version     : NotAvailable
        uOS Version          : NotAvailable
        Device Serial Number      : NotAvailable
    Board
        Vendor ID          : 0x8086
        Device ID          : 0x225d
        Subsystem ID          : 0x2500
        Coprocessor Stepping ID     : 3
        PCIe Width          : x16
        PCIe Speed          : 5 GT/s
        PCIe Max payload size     : 128 bytes
        PCIe Max read req size     : 512 bytes
        Coprocessor Model     : 0x01
        Coprocessor Model Ext     : 0x00
        Coprocessor Type     : 0x00
        Coprocessor Family     : 0x0b
        Coprocessor Family Ext     : 0x00
        Coprocessor Stepping      : B1
        Board SKU          : B1QS-3115A
        ECC Mode          : NotAvailable
        SMC HW Revision      : NotAvailable
    Cores
        Total No of Active Cores : NotAvailable
        Voltage          : NotAvailable
        Frequency          : NotAvailable
    Thermal
        Fan Speed Control      : NotAvailable
        Fan RPM          : NotAvailable
        Fan PWM          : NotAvailable
        Die Temp         : NotAvailable
    GDDR
        GDDR Vendor         : NotAvailable
        GDDR Version         : NotAvailable
        GDDR Density         : NotAvailable
        GDDR Size         : NotAvailable
        GDDR Technology         : NotAvailable
        GDDR Speed         : NotAvailable
        GDDR Frequency         : NotAvailable
        GDDR Voltage         : NotAvailable
Thank you !
Frances_R_Intel
In looking at other posts about flash/smc update, you have probably seen that flash versions prior to 3.75 are a problem. You said that the flash version was 3.72. Did you find that out from running micinfo prior to the update attempt? What does 'micctrl -s' say - has the card returned to the ready state?
If the card will not come back to the ready state, there is little I can recommend other than for you to contact your supplier and see if there is anything they can do for you.
The micinfo command will not show all the information unless the card is booted. If the card has come back to the ready state, you can try booting it and rerunning micinfo. If it does boot, could you post the micinfo information you get at that point? It would be good to know what the card thinks its flash and smc version are now. It may think it has an up-to-date flash and an out-of-date smc, which would be a bad thing.
At this point, I don't believe I can get my hands on an early enough version of the MPSS to guarantee that you will be able to update the flash and smc. I didn't have much luck when I looked for one a year ago. The earliest version that is still publicly available is in the MPSS 2.1. However, even this version wants the flash to be 3.75 or later.
So - I guess my recommendation would be -
If the card will not come back to the ready state, talk to the folks who supplied the card.
If it will come back to the ready state, see if it will boot and provide the full micinfo information.
And in the meantime, I will seek advice from those more knowledgeable to see if there is anything that can be done to get this card to a known state and update it.
john_p_2
Thank you, Frances !
Per your instructions, micctrl -s  indicated that it was ready, so I've tried to boot and I've got the following:
micctrl -b -vv
   [Info] mic0: [Parse] /etc/mpss/mic0.conf
   [Info] mic0: [Parse] Configuration version 1.1
   [Info] mic0: [Parse] /etc/mpss/default.conf
   [Info] mic0: [Parse] /etc/mpss/conf.d/sep.conf
   [Info] mic0: [Parse] /etc/mpss/conf.d/itt.conf
   [Info] mic0: [Parse] /etc/mpss/conf.d/amplxe.conf
   [Info] mic0: Command line: quiet root=ramfs console=hvc0 cgroup_disable=memory highres=off
          mic0: booting /usr/share/mpss/boot/bzImage-knightscorner
  [Error] mic0 failed to boot: card state online
Then, I've tried to reboot it with the following 2 commands:
micctrl -r -vv
          mic0: resetting
micctrl -b -vv
At this point it seems to be booted (because it doesn't say that it failed to boot) so I run micinfo but it still doesn't show the flash version:
 micinfo
MicInfo Utility Log
Created Mon Oct 27 15:31:19 2014
    System Info
        HOST OS            : Linux
        MPSS Version        : 3.4
    Version
    Board
        Vendor ID          : 0x8086
        Device ID          : 0x225d
        PCIe Width          : x16
        PCIe Speed          : 5 GT/s
    Cores
    Thermal
    GDDR
Frances_R_Intel
It can take a little while between when you see:
and when the coprocessor is actually booted. (If you add a '-w' to the micctrl command, the command will not terminate until the boot processes completes.)  So, I am not so sure that your card was booted when you ran the micinfo command.
At this point, the best thing might be to put the testing aside until I can get more information.
Frances_R_Intel
For all those who have a B1 card with a flash earlier than 375, we now have a 375 flash that has been tested and can be used to move from your present flash to 375 and from there to the current 390 flash in MPSS 3.3.x and 3.4.x. These instructions are ONLY for B1 cards and ONLY if your flash is (or was when you started trying to update the MPSS) pre-375. (C0 cards shouldn't have this problem and if your flash is 375 or later, you can follow the directions in the readme.txt exactly as given.) Some people have been successful just going straight from the a pre-375 flash to the the current flash, but not everyone, as shown by your problem, John.
If you have already attempted to update straight to the current version of flash and, when you run micinfo as root, your flash and smc bootloader versions match the version numbers given in the readme.txt, DO NOT follow the instructions below.
If your card is NOT a B1 stepping, as shown by micinfo, DO NOT follow the instructions below.
Follow the directions in the readme.txt for the version of MPSS you are upgrading to, until you get to the line telling you to update the flash and at that point STOP.
Download the attached file and unzip it in a directory on your host system - for this example, I will use /tmp/oldflash/.
Execute (substituting your directory name, if different):
      micflash -update /tmp/oldflash -device all smcbootloader
Reboot your host system
Return to the directions in the readme.txt and continue from where you stopped, updating your flash to the current version.
