Software Archive
Read-only legacy content
17060 Discussions
#-SOLVED-# HELP ! Intel XDK crashes, and I just can't open it anymore even after reinstall
Rodrigo_M_1
New Contributor II
Hi there,
I was working in a project, and I was build my application when the Intel XDK just close it self.
So, I tried to open it again, but looks like that screen to report error / crashes logs have some "infinite" loop, just after upload the error log and reopen the XDK, I got the same error log screen report ...
Even after remove the entire applicarion and reinstall it, I still facing the same issue, so any one had the same experience before ?
I need help to fix it!
By the way, follow the information I noticed on debug.log file located on XDK\bin folder!
[9204:0204/115421:INFO:CONSOLE(17)] ""xdk:client:[2016-02-04T16:54:21.583Z]: (1454604861583): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[9204:0204/115426:INFO:CONSOLE(17)] ""xdk:client:[2016-02-04T16:54:26.689Z]: (1454604866689): Uncaught top-level browser exception at file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:19:69: Uncaught TypeError: Cannot read property 'iosDebugImpl' of undefined\nStack trace from browser: TypeError: Cannot read property 'iosDebugImpl' of undefined\n    at file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:19:22644\n    at Object.context.execCb (file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1615:33)\n    at Object.Module.check (file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:851:51)\n    at Object.\u003Canonymous\u003E (file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1092:34)\n    at file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:129:23\n    at file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1135:21\n    at each (file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:57:31)\n    at Object.Module.emit (file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1134:17)\n    at Object.Module.check (file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:905:30)\n    at Object.Module.enable (file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1122:22)"", source: C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[9204:0204/115426:INFO:CONSOLE(19)] "Uncaught TypeError: Cannot read property 'iosDebugImpl' of undefined", source: file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js (19)
[9204:0204/115426:INFO:CONSOLE(17)] ""client:appcenter-options:[2016-02-04T16:54:26.774Z]: (1454604866774): Something went wrong. Could not create appCenterBaseUrl (%s) for appCenterOption key/value pair (%s/%s) in default.json" null "crosswalk" "apk"", source: C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
Thanks!
Rodrigo.
Rodrigo_M_1
New Contributor II
Hi there, I was able to fix the problem by doing the follow steps:
1-Remove (Uninstall Intel XDK from your computer)
2- Download the Intel XDK Version 2366 from: https://software.intel.com/pt-br/forums/intel-xdk/topic/594398
3-Install the older version of Intel 2366.
4-When you open the Intel XDK version 2366, it will ask you to update it, go ahead and update it and the issue will be fixed!
Rodrigo_M_1
New Contributor II
This is the screen that keeps showing and don't let me open the Intel XDK...
Any one could help me please ?
Appreciate!
Thanks!
Rodrigo.
gabriel_o_
I have the same problem now, please help on how to resolve it. thanks
Elroy_A_Intel
I recommend uninstalling Intel XDK and rebooting your machine before installing it again. There appears to be a few invalid files in your xdk directory.
Rodrigo_M_1
New Contributor II
Hi Elroy, thanks for the tip bu I already have tried this couple of times with no success!
That's really strange.... Maybe some registry corrupt data ?
Rodrigo_M_1
New Contributor II
Good Morning!
I still with this problem... any one has fixed it without have to reinstall the Windows OS ?
gabriel have you fixed your issue ?
Rodrigo.
John_H_Intel2
What antivirus do you have installed? I am wondering if it is somehow deleting files behind the scene?
Rodrigo_M_1
New Contributor II
Hi JOHN, I have the Webroot SecureAnywhere Antivirus!
It's strange, because I was working with this computer with this antivirus from 2015 without problem...
Rodrigo_M_1
New Contributor II
Hi there, I still with the problem but now, some times I got this screen just after report error screen!
John_H_Intel2
Can you try disabling it and reinstalling?
Rodrigo_M_1
New Contributor II
Hi JOHN. what do you mean about disabling it ? How should I proceed ?
BTW, I have logged in with another administrator account and reinstalled the app to check if the problem could be with my user profile, but no success...
Below is the Preview log of the crash for you.
xdk:client:[2016-02-08T20:07:42.944Z]: (1454962062945): memlim: 767557632
xdk:client:[2016-02-08T20:07:42.948Z]: (1454962062948): Setting NW crash dump to: C:\Users\rmartins.APT\AppData\Local\XDK
xdk:client:[2016-02-08T20:07:43.112Z]: (1454962063112): Intel XDK: 2893
xdk:client:[2016-02-08T20:07:43.113Z]: (1454962063113): Platform: win32-ia32 (6.1.7601)
xdk:client:[2016-02-08T20:07:43.113Z]: (1454962063113): System Info:  CPU: 8 X Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Physical Memory: 34325278720
xdk:client:[2016-02-08T20:07:43.113Z]: (1454962063113): NW: 0.11.7-rc9
xdk:client:[2016-02-08T20:07:43.158Z]: (1454962063158): Created new theme: base
xdk:client:[2016-02-08T20:07:43.158Z]: (1454962063158): Registered new theme: base
xdk:client:[2016-02-08T20:07:43.159Z]: (1454962063159): Current theme is now: base
xdk:client:[2016-02-08T20:07:43.159Z]: (1454962063159): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-02-08T20:07:43.160Z]: (1454962063160): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-02-08T20:07:43.244Z]: (1454962063244): Starting client process initialization
xdk:client:[2016-02-08T20:07:43.272Z]: (1454962063272): NW Cache is up-to-date.
xdk:server:[2016-02-08T20:07:44.884Z]: (1454962064885): memlim: 767557632
xdk:server:[2016-02-08T20:07:44.890Z]: (1454962064890): Setting NW crash dump to: C:\Users\rmartins.APT\AppData\Local\XDK
xdk:server:[2016-02-08T20:07:45.096Z]: (1454962065096): Starting server process initialization
xdk:server:[2016-02-08T20:07:45.207Z]: (1454962065207): Http server started on the standard port 58889
xdk:server:[2016-02-08T20:07:46.234Z]: (1454962066234): NW Cache is up-to-date.
xdk:server:[2016-02-08T20:07:46.744Z]: (1454962066744): Component "core:assert" starting import
xdk:server:[2016-02-08T20:07:46.744Z]: (1454962066744): Component "core:assert" finished initialization
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:component-error" starting import
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:component-error" finished initialization
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:command-line-options" starting import
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:command-line-options" finished initialization
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:service-error" starting import
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:service-error" finished initialization
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:buffer" starting import
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:buffer" finished initialization
xdk:server:[2016-02-08T20:07:46.745Z]: (1454962066745): Component "core:signaler" starting import
xdk:server:[2016-02-08T20:07:46.747Z]: (1454962066747): Component "core:signaler" finished initialization
xdk:server:[2016-02-08T20:07:46.747Z]: (1454962066747): Component "core:signaler-group" starting import
xdk:server:[2016-02-08T20:07:46.749Z]: (1454962066749): Component "core:signaler-group" finished initialization
xdk:server:[2016-02-08T20:07:46.749Z]: (1454962066749): Component "core:logger" starting import
xdk:server:[2016-02-08T20:07:46.750Z]: (1454962066750): Component "core:logger" finished initialization
xdk:server:[2016-02-08T20:07:46.750Z]: (1454962066750): Component "core:http-request" starting import
xdk:server:[2016-02-08T20:07:46.751Z]: (1454962066751): Component "core:http-request" finished initialization
xdk:server:[2016-02-08T20:07:46.751Z]: (1454962066751): Component "core:database" starting import
xdk:server:[2016-02-08T20:07:46.751Z]: (1454962066751): Component "core:database" finished initialization
xdk:server:[2016-02-08T20:07:46.751Z]: (1454962066751): Component "core:version" starting import
xdk:server:[2016-02-08T20:07:46.751Z]: (1454962066751): Component "core:version" finished initialization
xdk:server:[2016-02-08T20:07:46.751Z]: (1454962066751): Component "core:userfs-name-converter" starting import
xdk:server:[2016-02-08T20:07:46.752Z]: (1454962066752): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-02-08T20:07:46.752Z]: (1454962066752): Component "core:crash-handler" starting import
xdk:server:[2016-02-08T20:07:46.753Z]: (1454962066753): Component "core:crash-handler" finished initialization
xdk:server:[2016-02-08T20:07:46.753Z]: (1454962066753): Component "core:i18n-support" starting import
xdk:server:[2016-02-08T20:07:46.753Z]: (1454962066753): Component "core:i18n-support" finished initialization
xdk:server:[2016-02-08T20:07:46.753Z]: (1454962066753): Component "core:theme" starting import
xdk:server:[2016-02-08T20:07:46.796Z]: (1454962066796): Component "core:theme" finished initialization
xdk:server:[2016-02-08T20:07:46.797Z]: (1454962066797): Component "server:userfs" starting import
xdk:server:[2016-02-08T20:07:46.803Z]: (1454962066803): Component "server:userfs" calling init()
xdk:server:[2016-02-08T20:07:46.835Z]: (1454962066835): Component "server:userfs" finished initialization
xdk:server:[2016-02-08T20:07:46.835Z]: (1454962066835): Component "server:user-profile" starting import
xdk:server:[2016-02-08T20:07:46.837Z]: (1454962066837): Component "server:user-profile" calling init()
xdk:server:[2016-02-08T20:07:46.838Z]: (1454962066838): Component "server:user-profile" finished initialization
xdk:server:[2016-02-08T20:07:46.838Z]: (1454962066838): Component "server:ui-builder" starting import
xdk:server:[2016-02-08T20:07:46.885Z]: (1454962066885): Component "server:ui-builder" calling init()
xdk:server:[2016-02-08T20:07:46.887Z]: (1454962066887): Component "server:ui-builder" finished initialization
xdk:server:[2016-02-08T20:07:46.887Z]: (1454962066887): Component "server:emulator-notification" starting import
xdk:server:[2016-02-08T20:07:46.894Z]: (1454962066894): Component "server:emulator-notification" calling init()
xdk:server:[2016-02-08T20:07:46.894Z]: (1454962066894): Component "server:emulator-notification" finished initialization
xdk:server:[2016-02-08T20:07:46.894Z]: (1454962066894): Component "server:emulator-webserver" starting import
xdk:server:[2016-02-08T20:07:46.895Z]: (1454962066895): Component "server:emulator-webserver" calling init()
xdk:server:[2016-02-08T20:07:46.897Z]: (1454962066897): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-02-08T20:07:46.897Z]: (1454962066897): Component "server:new-project-creator" starting import
xdk:server:[2016-02-08T20:07:46.902Z]: (1454962066902): Component "server:new-project-creator" calling init()
xdk:server:[2016-02-08T20:07:46.902Z]: (1454962066902): Component "server:new-project-creator" finished initialization
xdk:server:[2016-02-08T20:07:46.902Z]: (1454962066902): Component "server:zip-util" starting import
xdk:server:[2016-02-08T20:07:46.905Z]: (1454962066905): Component "server:zip-util" calling init()
xdk:server:[2016-02-08T20:07:46.905Z]: (1454962066905): Component "server:zip-util" finished initialization
xdk:server:[2016-02-08T20:07:46.905Z]: (1454962066905): Component "server:uuid-server" starting import
xdk:server:[2016-02-08T20:07:46.908Z]: (1454962066908): Component "server:uuid-server" calling init()
xdk:server:[2016-02-08T20:07:46.908Z]: (1454962066908): Component "server:uuid-server" finished initialization
xdk:server:[2016-02-08T20:07:46.908Z]: (1454962066908): Component "server:app-starter" starting import
xdk:server:[2016-02-08T20:07:46.914Z]: (1454962066914): Component "server:app-starter" calling init()
xdk:server:[2016-02-08T20:07:46.917Z]: (1454962066917): Component "server:app-starter" finished initialization
xdk:server:[2016-02-08T20:07:46.917Z]: (1454962066917): Component "server:force-download" starting import
xdk:server:[2016-02-08T20:07:46.919Z]: (1454962066919): Component "server:force-download" calling init()
xdk:server:[2016-02-08T20:07:46.920Z]: (1454962066920): Component "server:force-download" finished initialization
xdk:server:[2016-02-08T20:07:46.920Z]: (1454962066920): Component "server:updater" starting import
xdk:server:[2016-02-08T20:07:46.925Z]: (1454962066925): Component "server:updater" calling init()
server:updater:[2016-02-08T20:07:46.925Z]: (1454962066926): config.base-auto
server:updater:[2016-02-08T20:07:46.926Z]: (1454962066926): url=auto
xdk:server:[2016-02-08T20:07:46.926Z]: (1454962066926): Component "server:updater" finished initialization
xdk:server:[2016-02-08T20:07:46.926Z]: (1454962066926): Component "server:editor-node" starting import
xdk:server:[2016-02-08T20:07:46.952Z]: (1454962066952): Component "server:editor-node" calling init()
xdk:server:[2016-02-08T20:07:46.952Z]: (1454962066952): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-02-08T20:07:46.952Z]: (1454962066952): Component "server:cordova-lib" starting import
xdk:server:[2016-02-08T20:07:47.236Z]: (1454962067236): Component "server:cordova-lib" calling init()
xdk:server:[2016-02-08T20:07:47.346Z]: (1454962067346): Component "server:cordova-lib" finished initialization
xdk:server:[2016-02-08T20:07:47.346Z]: (1454962067346): Component "server:api-explorer" starting import
xdk:server:[2016-02-08T20:07:47.351Z]: (1454962067351): Component "server:api-explorer" calling init()
xdk:server:[2016-02-08T20:07:47.392Z]: (1454962067392): Component "server:api-explorer" finished initialization
xdk:server:[2016-02-08T20:07:47.392Z]: (1454962067392): Component "server:plugin-listener" starting import
xdk:server:[2016-02-08T20:07:47.394Z]: (1454962067394): Component "server:plugin-listener" calling init()
xdk:server:[2016-02-08T20:07:47.395Z]: (1454962067395): Component "server:plugin-listener" finished initialization
xdk:server:[2016-02-08T20:07:47.395Z]: (1454962067395): Component "server:git-runner" starting import
xdk:server:[2016-02-08T20:07:47.398Z]: (1454962067398): Component "server:git-runner" calling init()
xdk:server:[2016-02-08T20:07:47.398Z]: (1454962067398): Component "server:git-runner" finished initialization
server:editor-node:[2016-02-08T20:07:47.399Z]: (1454962067399): Starting Brackets node process C:\Users\rmartins.APT\AppData\Local\Intel\XDK\bin\node.exe C:\Users\rmartins.APT\AppData\Local\Intel\XDK\bin\node-core
server:editor-node:[2016-02-08T20:07:47.757Z]: (1454962067757): Brackets node is running on port 50342
xdk:server:[2016-02-08T20:07:47.758Z]: (1454962067758): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-02-08T20:07:47.759Z]: (1454962067759): Component "server:ui-builder" calling start()
xdk:server:[2016-02-08T20:07:47.762Z]: (1454962067762): Component "server:ui-builder" finished start()
xdk:server:[2016-02-08T20:07:47.762Z]: (1454962067762): Component "server:emulator-webserver" calling start()
xdk:server:[2016-02-08T20:07:47.762Z]: (1454962067762): Component "server:emulator-webserver" finished start()
xdk:server:[2016-02-08T20:07:47.762Z]: (1454962067762): Component "server:editor-node" calling start()
xdk:server:[2016-02-08T20:07:47.762Z]: (1454962067762): Component "server:editor-node" finished start()
xdk:server:[2016-02-08T20:07:47.765Z]: (1454962067765): Intel XDK is initialized now
xdk:server:[2016-02-08T20:07:47.765Z]: (1454962067765): Writing to the server data file
xdk:server:[2016-02-08T20:07:47.766Z]: (1454962067766): Wrote server data to "C:\Users\rmartins.APT\AppData\Local\XDK\server-data.txt"
xdk:client:[2016-02-08T20:07:47.770Z]: (1454962067770): Successfully read server data file
xdk:client:[2016-02-08T20:07:47.891Z]: (1454962067891): Component "core:assert" starting import
xdk:client:[2016-02-08T20:07:47.891Z]: (1454962067891): Component "core:assert" finished initialization
xdk:client:[2016-02-08T20:07:47.891Z]: (1454962067891): Component "core:component-error" starting import
xdk:client:[2016-02-08T20:07:47.892Z]: (1454962067892): Component "core:component-error" finished initialization
xdk:client:[2016-02-08T20:07:47.892Z]: (1454962067892): Component "core:command-line-options" starting import
xdk:client:[2016-02-08T20:07:47.892Z]: (1454962067892): Component "core:command-line-options" finished initialization
xdk:client:[2016-02-08T20:07:47.892Z]: (1454962067892): Component "core:service-error" starting import
xdk:client:[2016-02-08T20:07:47.892Z]: (1454962067892): Component "core:service-error" finished initialization
xdk:client:[2016-02-08T20:07:47.892Z]: (1454962067892): Component "core:buffer" starting import
xdk:client:[2016-02-08T20:07:47.892Z]: (1454962067892): Component "core:buffer" finished initialization
xdk:client:[2016-02-08T20:07:47.892Z]: (1454962067892): Component "core:signaler" starting import
xdk:client:[2016-02-08T20:07:47.893Z]: (1454962067893): Component "core:signaler" finished initialization
xdk:client:[2016-02-08T20:07:47.893Z]: (1454962067893): Component "core:signaler-group" starting import
xdk:client:[2016-02-08T20:07:47.895Z]: (1454962067895): Component "core:signaler-group" finished initialization
xdk:client:[2016-02-08T20:07:47.895Z]: (1454962067895): Component "core:logger" starting import
xdk:client:[2016-02-08T20:07:47.896Z]: (1454962067896): Component "core:logger" finished initialization
xdk:client:[2016-02-08T20:07:47.896Z]: (1454962067896): Component "core:http-request" starting import
xdk:client:[2016-02-08T20:07:47.897Z]: (1454962067897): Component "core:http-request" finished initialization
xdk:client:[2016-02-08T20:07:47.897Z]: (1454962067897): Component "core:version" starting import
xdk:client:[2016-02-08T20:07:47.897Z]: (1454962067897): Component "core:version" finished initialization
xdk:client:[2016-02-08T20:07:47.897Z]: (1454962067897): Component "core:exit-notifier" starting import
xdk:client:[2016-02-08T20:07:47.897Z]: (1454962067897): Component "core:exit-notifier" finished initialization
xdk:client:[2016-02-08T20:07:47.897Z]: (1454962067897): Component "core:userfs-name-converter" starting import
xdk:client:[2016-02-08T20:07:47.897Z]: (1454962067897): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-02-08T20:07:47.897Z]: (1454962067897): Component "core:crash-handler" starting import
xdk:client:[2016-02-08T20:07:47.898Z]: (1454962067898): Component "core:crash-handler" finished initialization
xdk:client:[2016-02-08T20:07:47.898Z]: (1454962067898): Component "core:analytics" starting import
xdk:client:[2016-02-08T20:07:47.898Z]: (1454962067898): Component "core:analytics" finished initialization
xdk:client:[2016-02-08T20:07:47.898Z]: (1454962067898): Component "core:i18n-support" starting import
xdk:client:[2016-02-08T20:07:47.898Z]: (1454962067898): Component "core:i18n-support" finished initialization
xdk:client:[2016-02-08T20:07:47.899Z]: (1454962067899): Component "core:theme" starting import
xdk:client:[2016-02-08T20:07:47.899Z]: (1454962067899): Component "core:theme" finished initialization
xdk:client:[2016-02-08T20:07:47.906Z]: (1454962067906): Analytics ID: 0eb3776b-f8b8-4011-b7d4-157a7a028323
xdk:client:[2016-02-08T20:07:47.907Z]: (1454962067907): onExit listener 0:
    at Object.exports.onExit (C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
    at setupDefaultAnalytics (C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:1438)
    at C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:6219
    at C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1229:26
    at _fulfilled (C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:834:54)
    at self.promiseDispatch.done (C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:863:30)
    at Promise.promise.promiseDispatch (C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:796:13)
    at C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44
    at runSingle (C:\Users\rmartins.APT\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2016-02-08T20:07:47.931Z]: (1454962067931): Component "client:app" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:help-helper" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:nativefs" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:document-manager" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:project-manager" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:aa-controller" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:projects-renderers" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:active-sync" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:apk-installer" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:appcenter-options" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-manager" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-cocos2d" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-phaser" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-pixi" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-easeljs" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-plain" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-render-frame" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:resource-util" starting import
xdk:client:[2016-02-08T20:07:47.932Z]: (1454962067932): Component "client:bower-package-manager" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:services-tab" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:editor" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:live-preview" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:backend-services" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:backend-feeds" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:merged-feed" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:backend-services-ext" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:backend-service-utils" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:app-starter" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:ui-builder-client" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:project-meta" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:contenttype-registry" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:editor-registry" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:platform-registry" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:projecttype-registry" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:library-registry" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:cordova-registry" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:service-method" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:settings-db" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:adb" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:iosdb" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:device" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:device-discovery" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:dialog-box" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:test-local-server" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:quick-tour" starting import
xdk:client:[2016-02-08T20:07:47.933Z]: (1454962067933): Component "client:hot-keys" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:persistance" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:tabs" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:hash-utils" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:file-watcher" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:tool-tip" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:cordova" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:settings-ui" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:external-links" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:external-editors-runner" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:project-list-load" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:upload-manager" starting import
xdk:client:[2016-02-08T20:07:47.934Z]: (1454962067934): Component "client:git-manager" starting import
xdk:client:[2016-02-08T20:07:47.961Z]: (1454962067961): memmrk:	16500324	37337216
xdk:client:[2016-02-08T20:07:47.964Z]: (1454962067964): Component "client:help-helper" finished initialization
xdk:client:[2016-02-08T20:07:47.965Z]: (1454962067965): Component "client:nativefs" finished initialization
xdk:client:[2016-02-08T20:07:47.980Z]: (1454962067980): Component "client:active-sync" calling init()
xdk:client:[2016-02-08T20:07:47.980Z]: (1454962067980): Component "client:active-sync" finished initialization
xdk:client:[2016-02-08T20:07:47.990Z]: (1454962067990): Component "client:apk-installer" calling init()
xdk:client:[2016-02-08T20:07:47.990Z]: (1454962067990): Component "client:apk-installer" finished initialization
xdk:client:[2016-02-08T20:07:48.002Z]: (1454962068002): Component "client:resource-render-frame" calling init()
xdk:client:[2016-02-08T20:07:48.003Z]: (1454962068003): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.003Z]: (1454962068003): Component "client:resource-util" calling init()
xdk:client:[2016-02-08T20:07:48.003Z]: (1454962068003): Component "client:resource-util" finished initialization
xdk:client:[2016-02-08T20:07:48.009Z]: (1454962068009): Component "client:backend-services" calling init()
xdk:client:[2016-02-08T20:07:48.010Z]: (1454962068010): Component "client:backend-services" finished initialization
xdk:client:[2016-02-08T20:07:48.011Z]: (1454962068011): Component "client:backend-feeds" calling init()
xdk:client:[2016-02-08T20:07:48.011Z]: (1454962068011): Component "client:backend-feeds" finished initialization
xdk:client:[2016-02-08T20:07:48.012Z]: (1454962068012): Component "client:merged-feed" finished initialization
xdk:client:[2016-02-08T20:07:48.013Z]: (1454962068013): Component "client:backend-services-ext" calling init()
xdk:client:[2016-02-08T20:07:48.013Z]: (1454962068013): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-02-08T20:07:48.013Z]: (1454962068013): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-02-08T20:07:48.016Z]: (1454962068016): Component "client:project-meta" calling init()
xdk:client:[2016-02-08T20:07:48.016Z]: (1454962068016): Component "client:project-meta" finished initialization
xdk:client:[2016-02-08T20:07:48.022Z]: (1454962068022): Component "client:service-method" finished initialization
xdk:client:[2016-02-08T20:07:48.024Z]: (1454962068024): Component "client:settings-db" calling init()
xdk:client:[2016-02-08T20:07:48.024Z]: (1454962068024): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.025Z]: (1454962068025): Component "client:iosdb" calling init()
xdk:client:[2016-02-08T20:07:48.025Z]: (1454962068025): Component "client:iosdb" finished initialization
xdk:client:[2016-02-08T20:07:48.026Z]: (1454962068026): Component "client:adb" calling init()
xdk:client:[2016-02-08T20:07:48.048Z]: (1454962068048): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.055Z]: (1454962068055): Component "client:persistance" calling init()
xdk:client:[2016-02-08T20:07:48.055Z]: (1454962068055): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.057Z]: (1454962068057): Component "client:file-watcher" calling init()
xdk:client:[2016-02-08T20:07:48.057Z]: (1454962068057): Component "client:file-watcher" finished initialization
xdk:client:[2016-02-08T20:07:48.060Z]: (1454962068060): Component "client:external-links" finished initialization
xdk:client:[2016-02-08T20:07:48.061Z]: (1454962068061): Component "client:external-editors-runner" calling init()
xdk:client:[2016-02-08T20:07:48.061Z]: (1454962068061): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-02-08T20:07:48.061Z]: (1454962068061): Component "client:project-list-load" calling init()
xdk:client:[2016-02-08T20:07:48.061Z]: (1454962068061): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.063Z]: (1454962068063): Component "client:upload-manager" calling init()
xdk:client:[2016-02-08T20:07:48.063Z]: (1454962068063): Component "client:upload-manager" finished initialization
xdk:client:[2016-02-08T20:07:48.063Z]: (1454962068064): Component "client:git-manager" calling init()
client:git-manager:[2016-02-08T20:07:48.064Z]: (1454962068064): git path =  C:\Users\rmartins.APT\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2016-02-08T20:07:48.064Z]: (1454962068064): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.067Z]: (1454962068067): Component "client:app-starter" finished initialization
xdk:client:[2016-02-08T20:07:48.068Z]: (1454962068068): Component "client:hot-keys" calling init()
xdk:client:[2016-02-08T20:07:48.068Z]: (1454962068068): Component "client:hot-keys" finished initialization
xdk:client:[2016-02-08T20:07:48.071Z]: (1454962068071): Component "client:document-manager" calling init()
xdk:client:[2016-02-08T20:07:48.071Z]: (1454962068071): Component "client:document-manager" finished initialization
xdk:client:[2016-02-08T20:07:48.079Z]: (1454962068079): Component "client:aa-controller" calling init()
xdk:client:[2016-02-08T20:07:48.079Z]: (1454962068079): Component "client:aa-controller" finished initialization
xdk:client:[2016-02-08T20:07:48.102Z]: (1454962068102): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-02-08T20:07:48.108Z]: (1454962068108): Component "client:ui-builder-client" calling init()
xdk:client:[2016-02-08T20:07:48.109Z]: (1454962068109): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-02-08T20:07:48.110Z]: (1454962068110): Component "client:dialog-box" finished initialization
xdk:client:[2016-02-08T20:07:48.113Z]: (1454962068113): Component "client:tool-tip" finished initialization
xdk:client:[2016-02-08T20:07:48.115Z]: (1454962068115): Component "client:settings-ui" finished initialization
xdk:client:[2016-02-08T20:07:48.128Z]: (1454962068128): Component "client:appcenter-options" calling init()
xdk:client:[2016-02-08T20:07:48.128Z]: (1454962068128): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.130Z]: (1454962068130): Component "client:test-local-server" calling init()
xdk:client:[2016-02-08T20:07:48.153Z]: (1454962068153): Component "client:test-local-server" finished initialization
xdk:client:[2016-02-08T20:07:48.154Z]: (1454962068154): Component "client:tabs" finished initialization
xdk:client:[2016-02-08T20:07:48.157Z]: (1454962068157): Component "client:app" calling init()
xdk:client:[2016-02-08T20:07:48.167Z]: (1454962068167): Component "client:app" finished initialization
xdk:client:[2016-02-08T20:07:48.199Z]: (1454962068199): Component "client:services-tab" calling init()
xdk:client:[2016-02-08T20:07:48.199Z]: (1454962068199): Component "client:services-tab" finished initialization
xdk:client:[2016-02-08T20:07:48.202Z]: (1454962068202): Component "client:contenttype-registry" calling init()
xdk:client:[2016-02-08T20:07:48.203Z]: (1454962068203): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-02-08T20:07:48.203Z]: (1454962068203): Component "client:editor-registry" finished initialization
xdk:client:[2016-02-08T20:07:48.208Z]: (1454962068208): Component "client:library-registry" calling init()
xdk:client:[2016-02-08T20:07:48.208Z]: (1454962068208): Component "client:library-registry" finished initialization
xdk:client:[2016-02-08T20:07:48.215Z]: (1454962068215): Component "client:device-discovery" calling init()
xdk:client:[2016-02-08T20:07:48.215Z]: (1454962068215): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.216Z]: (1454962068216): Component "client:hash-utils" finished initialization
xdk:client:[2016-02-08T20:07:48.244Z]: (1454962068244): Component "client:cordova" calling init()
xdk:client:[2016-02-08T20:07:48.244Z]: (1454962068244): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.253Z]: (1454962068253): Component "client:project-manager" calling init()
xdk:client:[2016-02-08T20:07:48.253Z]: (1454962068254): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.262Z]: (1454962068262): Component "client:projects-renderers" calling init()
xdk:client:[2016-02-08T20:07:48.263Z]: (1454962068263): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.263Z]: (1454962068263): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-02-08T20:07:48.263Z]: (1454962068263): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-02-08T20:07:48.272Z]: (1454962068272): Component "client:navbar" starting import
xdk:client:[2016-02-08T20:07:48.272Z]: (1454962068272): Component "client:tweets" starting import
xdk:client:[2016-02-08T20:07:48.272Z]: (1454962068272): Component "client:projects-tab" starting import
xdk:client:[2016-02-08T20:07:48.272Z]: (1454962068272): Component "client:test-tab" starting import
xdk:client:[2016-02-08T20:07:48.273Z]: (1454962068273): Component "client:profilingTab" starting import
xdk:client:[2016-02-08T20:07:48.273Z]: (1454962068273): Component "client:emulator" starting import
xdk:client:[2016-02-08T20:07:48.273Z]: (1454962068273): Component "client:remote-tab" starting import
xdk:client:[2016-02-08T20:07:48.273Z]: (1454962068273): Component "client:build-tab" starting import
xdk:client:[2016-02-08T20:07:48.273Z]: (1454962068273): Component "client:bower-client" starting import
xdk:client:[2016-02-08T20:07:48.273Z]: (1454962068273): Component "client:editor-tab" starting import
xdk:client:[2016-02-08T20:07:48.273Z]: (1454962068273): Component "client:account" starting import
xdk:client:[2016-02-08T20:07:48.273Z]: (1454962068273): Component "client:project-selector" starting import
xdk:client:[2016-02-08T20:07:48.294Z]: (1454962068294): Component "client:resource-manager" calling init()
xdk:client:[2016-02-08T20:07:48.295Z]: (1454962068295): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.299Z]: (1454962068299): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-02-08T20:07:48.299Z]: (1454962068299): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-02-08T20:07:48.302Z]: (1454962068302): Component "client:resource-phaser" calling init()
xdk:client:[2016-02-08T20:07:48.302Z]: (1454962068302): Component "client:resource-phaser" finished initialization
xdk:client:[2016-02-08T20:07:48.303Z]: (1454962068303): Component "client:resource-pixi" calling init()
xdk:client:[2016-02-08T20:07:48.304Z]: (1454962068304): Component "client:resource-pixi" finished initialization
xdk:client:[2016-02-08T20:07:48.305Z]: (1454962068305): Component "client:resource-easeljs" calling init()
xdk:client:[2016-02-08T20:07:48.305Z]: (1454962068305): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-02-08T20:07:48.306Z]: (1454962068306): Component "client:resource-plain" calling init()
xdk:client:[2016-02-08T20:07:48.306Z]: (1454962068306): Component "client:resource-plain" finished initialization
xdk:client:[2016-02-08T20:07:48.312Z]: (1454962068312): Component "client:cordova-registry" calling init()
xdk:client:[2016-02-08T20:07:48.312Z]: (1454962068312): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.326Z]: (1454962068326): Component "client:quick-tour" calling init()
xdk:client:[2016-02-08T20:07:48.326Z]: (1454962068326): Component "client:quick-tour" finished initialization
xdk:client:[2016-02-08T20:07:48.331Z]: (1454962068331): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-02-08T20:07:48.331Z]: (1454962068331): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.340Z]: (1454962068340): Component "client:platform-registry" calling init()
xdk:client:[2016-02-08T20:07:48.340Z]: (1454962068340): Component "client:platform-registry" finished initialization
xdk:client:[2016-02-08T20:07:48.342Z]: (1454962068342): Component "client:projecttype-registry" calling init()
xdk:client:[2016-02-08T20:07:48.342Z]: (1454962068342): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-02-08T20:07:48.346Z]: (1454962068346): Component "client:device" calling init()
xdk:client:[2016-02-08T20:07:48.403Z]: (1454962068403): Component "client:device" threw exception during initialization
xdk:client:[2016-02-08T20:07:48.408Z]: (1454962068408): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-02-08T20:07:48.411Z]: (1454962068411): Component "client:settings-db" finished delayed initialization
xdk:client:[2016-02-08T20:07:48.424Z]: (1454962068424): Component "client:bower-package-manager" calling init()
xdk:client:[2016-02-08T20:07:48.425Z]: (1454962068425): Component "client:bower-package-manager" finished initialization
xdk:client:[2016-02-08T20:07:48.439Z]: (1454962068439): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-02-08T20:07:48.440Z]: (1454962068440): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-02-08T20:07:48.444Z]: (1454962068444): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-02-08T20:07:48.445Z]: (1454962068445): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-02-08T20:07:48.473Z]: (1454962068473): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-02-08T20:07:48.474Z]: (1454962068474): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-02-08T20:07:48.494Z]: (1454962068494): Component "client:account" getting UI region for "account"
xdk:client:[2016-02-08T20:07:48.494Z]: (1454962068494): Component "client:account" calling init()
xdk:client:[2016-02-08T20:07:48.501Z]: (1454962068501): Component "client:account" finished initialization
xdk:client:[2016-02-08T20:07:48.508Z]: (1454962068508): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-02-08T20:07:48.509Z]: (1454962068509): Component "client:project-selector" calling init()
xdk:client:[2016-02-08T20:07:48.509Z]: (1454962068509): Component "client:project-selector" finished initialization
xdk:client:[2016-02-08T20:07:48.513Z]: (1454962068513): Component "client:tweets" finished initialization
xdk:client:[2016-02-08T20:07:48.514Z]: (1454962068514): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-02-08T20:07:48.514Z]: (1454962068514): Component "client:projects-tab" calling init()
xdk:client:[2016-02-08T20:07:48.515Z]: (1454962068515): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.518Z]: (1454962068518): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-02-08T20:07:48.518Z]: (1454962068518): Component "client:test-tab" calling init()
xdk:client:[2016-02-08T20:07:48.518Z]: (1454962068518): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-02-08T20:07:48.529Z]: (1454962068529): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-02-08T20:07:48.529Z]: (1454962068529): Component "client:emulator" calling init()
xdk:client:[2016-02-08T20:07:48.532Z]: (1454962068532): Component "client:emulator" finished initialization
xdk:client:[2016-02-08T20:07:48.533Z]: (1454962068533): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-02-08T20:07:48.533Z]: (1454962068533): Component "client:build-tab" calling init()
xdk:client:[2016-02-08T20:07:48.540Z]: (1454962068540): Component "client:build-tab" finished initialization
xdk:client:[2016-02-08T20:07:48.548Z]: (1454962068548): Uncaught top-level browser exception at file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:19:69: Uncaught TypeError: Cannot read property 'iosDebugImpl' of undefined
    at Object.<anonymous> (file:///C:/Users/rmartins.APT/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1092:34)
[Log closed from xdk:client]
xdk:server:[2016-02-08T20:07:49.887Z]: (1454962069887): memmrk:	29571752	43419136
Rodrigo_M_1
New Contributor II
TLars
Tried all versions below
[root@localhost XDK]$ ll
total 892136
-rw-r--r--. 1 xdkuser xdkuser 190433035 Feb 19 13:17 xdk-ea_web_linux64_master-ea_2866.tgz
-rw-r--r--. 1 xdkuser xdkuser 138201259 May 23 23:03 xdk_web_linux64_master_2366.tgz
-rw-r--r--. 1 xdkuser xdkuser 189321353 Feb 19 10:40 xdk_web_linux64_master_2893.tgz
-rw-r--r--. 1 xdkuser xdkuser 197491298 May  6 10:28 xdk_web_linux64_master_3240.tgz
-rw-r--r--. 1 xdkuser xdkuser 198066290 May 23 22:26 xdk_web_linux64_master_3357.tgz
All crashes on Fedora Core 23 and 24. The  only version that partially has worked if I let the crash notification stay open, is xdk-ea_web_linux64_master-ea_2866 .tgz
After install I did
[root@localhost XDK]# ln -sf /usr/lib64/libudev.so.0
Crash with latest 3357
# more debug.log
[18398:0523/225818:ERROR:browser_main_loop.cc(162)] Running without the SUID sandbox! See
 https://code.google.com/p/chromium/wiki/LinuxSUIDSandboxDevelopment for more information
 on developing with the sandbox on.
[18398:0523/225820:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:20.194Z]: (1464037100
194): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: /opt/intel/XDK/xdk
/core-modules/private/logger.js (17)
[18398:0523/225821:INFO:CONSOLE(17)] ""xdk:server:[2016-05-23T20:58:21.830Z]: (1464037101
830): Unexpected undefined handler detected when requiring component: server:userfs\n
at Object.\u003Canonymous\u003E (/opt/intel/XDK/xdk/components/server/ui-builder/basic_ap
i.js:17:16248)\n    at Module._compile (module.js:465:26)\n    at Object.Module._extensio
ns..js (module.js:483:10)\n    at Module.load (module.js:360:32)\n    at Function.Module.
_load (module.js:315:12)\n    at Module.require (module.js:370:17)\n    at require (modul
e.js:389:17)"", source: /opt/intel/XDK/xdk/core-modules/private/logger.js (17)
[18398:0523/225821:INFO:CONSOLE(17)] ""xdk:server:[2016-05-23T20:58:21.875Z]: (1464037101
875): Unexpected undefined handler detected when requiring component: server:userfs\n
at Object.\u003Canonymous\u003E (/opt/intel/XDK/xdk/components/server/ui-builder/undo_dat
abase.js:17:5250)\n    at Module._compile (module.js:465:26)\n    at Object.Module._exten
sions..js (module.js:483:10)\n    at Module.load (module.js:360:32)\n    at Function.Modu
le._load (module.js:315:12)\n    at Module.require (module.js:370:17)\n    at require (mo
dule.js:389:17)"", source: /opt/intel/XDK/xdk/core-modules/private/logger.js (17)
[18398:0523/225821:INFO:CONSOLE(17)] ""xdk:server:[2016-05-23T20:58:21.882Z]: (1464037101
882): Unexpected undefined handler detected when requiring component: server:userfs\n
at Object.\u003Canonymous\u003E (/opt/intel/XDK/xdk/components/server/ui-builder/datafeed
_api.js:17:3070)\n    at Module._compile (module.js:465:26)\n    at Object.Module._extens
ions..js (module.js:483:10)\n    at Module.load (module.js:360:32)\n    at Function.Modul
e._load (module.js:315:12)\n    at Module.require (module.js:370:17)\n    at require (mod
[18398:0523/225821:INFO:CONSOLE(17)] ""xdk:server:[2016-05-23T20:58:21.884Z]: (1464037101
884): Unexpected undefined handler detected when requiring component: server:userfs\n
at Object.\u003Canonymous\u003E (/opt/intel/XDK/xdk/components/server/ui-builder/help_ser
ver.js:17:2463)\n    at Module._compile (module.js:465:26)\n    at Object.Module._extensi
ons..js (module.js:483:10)\n    at Module.load (module.js:360:32)\n    at Function.Module
._load (module.js:315:12)\n    at Module.require (module.js:370:17)\n    at require (modu
[18398:0523/225823:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:23.100Z]: (1464037103
100): Unexpected undefined handler detected when requiring component: client:backend-serv
ices\n    at getGlobalSettingsFileName (file:///opt/intel/XDK/xdk/components/client/setti
ngs-db/settings-db.js:17:12420)\n    at Object.init (file:///opt/intel/XDK/xdk/components
/client/settings-db/settings-db.js:17:12921)\n    at /opt/intel/XDK/xdk/core-modules/priv
ate/main.js:17:9073\n    at Object.context.execCb (file:///opt/intel/XDK/xdk/public/exter
nal/js/require-jquery.js:1615:33)\n    at Object.Module.check (file:///opt/intel/XDK/xdk/
//opt/intel/XDK/xdk/public/external/js/require-jquery.js:1092:34)\n    at file:///opt/int
el/XDK/xdk/public/external/js/require-jquery.js:129:23"", source: /opt/intel/XDK/xdk/core
[18398:0523/225823:INFO:CONSOLE(21)] ""Could not parse offline feed"", source: file:///op
t/intel/XDK/xdk/components/client/projects-tab/projects-renderers-smarthome.js (21)
[18398:0523/225823:INFO:CONSOLE(17)] ""ios-device:[2016-05-23T20:58:23.856Z]: (1464037103
856): Failed to initialize libwi due to " "Dynamic Linking Error: libcrypto.so.1.0.0: can
not open shared object file: No such file or directory"", source: /opt/intel/XDK/xdk/core
[18398:0523/225823:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:23.944Z]: (1464037103
944): Unexpected undefined handler detected when requiring component: client:external-lin
ks\n    at DialogBox.show (file:///opt/intel/XDK/xdk/components/client/dialog-box/dialog-
box.js:17:1960)\n    at recoverXdk (file:///opt/intel/XDK/xdk/components/client/persistan
ce/persistance.js:17:1982)\n    at file:///opt/intel/XDK/xdk/components/client/persistanc
e/persistance.js:17:1030\n    at _fulfilled (/opt/intel/XDK/xdk/node_modules/q/q.js:834:5
4)\n    at self.promiseDispatch.done (/opt/intel/XDK/xdk/node_modules/q/q.js:863:30)\n
 at Promise.promise.promiseDispatch (/opt/intel/XDK/xdk/node_modules/q/q.js:796:13)\n
at /opt/intel/XDK/xdk/node_modules/q/q.js:604:44"", source: /opt/intel/XDK/xdk/core-modul
[18398:0523/225824:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:24.186Z]: (1464037104
186): Unexpected undefined handler detected when requiring component: client:projects-ren
derers-idrapp\n    at file:///opt/intel/XDK/xdk/components/client/projects-tab/projects-r
enderers.js:21:881\n    at _fulfilled (/opt/intel/XDK/xdk/node_modules/q/q.js:834:54)\n
  at self.promiseDispatch.done (/opt/intel/XDK/xdk/node_modules/q/q.js:863:30)\n    at Pr
omise.promise.promiseDispatch (/opt/intel/XDK/xdk/node_modules/q/q.js:796:13)\n    at /op
t/intel/XDK/xdk/node_modules/q/q.js:604:44\n    at runSingle (/opt/intel/XDK/xdk/node_mod
ules/q/q.js:137:13)\n    at flush (/opt/intel/XDK/xdk/node_modules/q/q.js:125:13)"", sour
[18398:0523/225824:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:24.187Z]: (1464037104
187): Unexpected undefined handler detected when requiring component: client:projects-ren
derers-ebook\n    at file:///opt/intel/XDK/xdk/components/client/projects-tab/projects-re
 at self.promiseDispatch.done (/opt/intel/XDK/xdk/node_modules/q/q.js:863:30)\n    at Pro
mise.promise.promiseDispatch (/opt/intel/XDK/xdk/node_modules/q/q.js:796:13)\n    at /opt
/intel/XDK/xdk/node_modules/q/q.js:604:44\n    at runSingle (/opt/intel/XDK/xdk/node_modu
les/q/q.js:137:13)\n    at flush (/opt/intel/XDK/xdk/node_modules/q/q.js:125:13)"", sourc
[18398:0523/225824:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:24.264Z]: (1464037104
264): Unexpected undefined handler detected when requiring component: client:backend-serv
ice-utils\n    at file:///opt/intel/XDK/xdk/components/client/test-tab/test-tab.js:17:142
99\n    at Object.context.execCb (file:///opt/intel/XDK/xdk/public/external/js/require-jq
uery.js:1615:33)\n    at Object.Module.check (file:///opt/intel/XDK/xdk/public/external/j
s/require-jquery.js:851:51)\n    at Object.\u003Canonymous\u003E (file:///opt/intel/XDK/x
dk/public/external/js/require-jquery.js:1092:34)\n    at file:///opt/intel/XDK/xdk/public
/external/js/require-jquery.js:129:23\n    at file:///opt/intel/XDK/xdk/public/external/j
s/require-jquery.js:1135:21\n    at each (file:///opt/intel/XDK/xdk/public/external/js/re
quire-jquery.js:57:31)"", source: /opt/intel/XDK/xdk/core-modules/private/logger.js (17)
[18398:0523/225824:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:24.368Z]: (1464037104
368): Unexpected undefined handler detected when requiring component: server:proxy\n    a
t Object.myExports.init (file:///opt/intel/XDK/xdk/components/client/remote-tab/remote-ta
b.js:19:30604)\n    at /opt/intel/XDK/xdk/core-modules/private/main.js:17:9073\n    at Ob
ject.context.execCb (file:///opt/intel/XDK/xdk/public/external/js/require-jquery.js:1615:
33)\n    at Object.Module.check (file:///opt/intel/XDK/xdk/public/external/js/require-jqu
ery.js:851:51)\n    at Object.\u003Canonymous\u003E (file:///opt/intel/XDK/xdk/public/ext
ernal/js/require-jquery.js:1092:34)\n    at file:///opt/intel/XDK/xdk/public/external/js/
require-jquery.js:129:23\n    at file:///opt/intel/XDK/xdk/public/external/js/require-jqu
ery.js:1135:21"", source: /opt/intel/XDK/xdk/core-modules/private/logger.js (17)
[18398:0523/225839:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:39.490Z]: (1464037119
490): Unexpected undefined handler detected when requiring component: client:iot-tools\n
   at Object.\u003Canonymous\u003E (file:///opt/intel/XDK/xdk/brackets/b/extensions/defau
lt/IoTSensorLibrary/main.js:32:50)\n    at Object.context.execCb (file:///opt/intel/XDK/x
dk/brackets/b/thirdparty/requirejs/require.js:1658:33)\n    at Object.Module.check (file:
///opt/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:869:55)\n    at Object.\u
003Canonymous\u003E (file:///opt/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js
:1121:34)\n    at file:///opt/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:13
2:23\n    at file:///opt/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1164:21
\n    at each (file:///opt/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:57:31
[18398:0523/225839:INFO:CONSOLE(220)] ""[Extension] Unable to read stylesheet ioTSensorLi
brary.css:" "error" """, source: /utils/ExtensionUtils.js (220)
[18398:0523/225840:INFO:CONSOLE(212)] ""NW proxy string: DIRECT"", source: /brackets.js (
212)
[18398:0523/225840:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:40.839Z]: (1464037120
839): Unexpected undefined handler detected when requiring component: client:projects-ren
derers-idrapp\n    at file:///opt/intel/XDK/xdk/components/client/projects-tab/projects-c
reate-list.js:21:6681\n    at file:///opt/intel/XDK/xdk/public/external/js/underscore.js:
175:20\n    at _.each._.forEach (file:///opt/intel/XDK/xdk/public/external/js/underscore.
js:87:24)\n    at Function._.filter._.select (file:///opt/intel/XDK/xdk/public/external/j
s/underscore.js:174:5)\n    at Backbone.View.extend.initialize (file:///opt/intel/XDK/xdk
/components/client/projects-tab/projects-create-list.js:21:6396)\n    at Backbone.View (f
ile:///opt/intel/XDK/xdk/public/external/js/backbone.js:987:21)\n    at new child (file:/
//opt/intel/XDK/xdk/public/external/js/backbone.js:1531:41)"", source: /opt/intel/XDK/xdk
[18398:0523/225840:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:40.840Z]: (1464037120
840): Unexpected undefined handler detected when requiring component: client:projects-ren
derers-ebook\n    at file:///opt/intel/XDK/xdk/components/client/projects-tab/projects-cr
eate-list.js:21:6681\n    at file:///opt/intel/XDK/xdk/public/external/js/underscore.js:1
75:20\n    at _.each._.forEach (file:///opt/intel/XDK/xdk/public/external/js/underscore.j
s:87:24)\n    at Function._.filter._.select (file:///opt/intel/XDK/xdk/public/external/js
/underscore.js:174:5)\n    at Backbone.View.extend.initialize (file:///opt/intel/XDK/xdk/
components/client/projects-tab/projects-create-list.js:21:6396)\n    at Backbone.View (fi
le:///opt/intel/XDK/xdk/public/external/js/backbone.js:987:21)\n    at new child (file://
/opt/intel/XDK/xdk/public/external/js/backbone.js:1531:41)"", source: /opt/intel/XDK/xdk/
[18398:0523/225841:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:41.004Z]: (1464037121
004): Unexpected undefined handler detected when requiring component: server:proxy\n    a
t Object.myExports.start (file:///opt/intel/XDK/xdk/components/client/remote-tab/remote-t
ab.js:20:2707)\n    at resumeClientInit (/opt/intel/XDK/xdk/core-modules/private/main.js:
17:12038)\n    at /opt/intel/XDK/xdk/core-modules/private/main.js:17:1734\n    at _fulfil
led (/opt/intel/XDK/xdk/node_modules/q/q.js:834:54)\n    at self.promiseDispatch.done (/o
pt/intel/XDK/xdk/node_modules/q/q.js:863:30)\n    at Promise.promise.promiseDispatch (/op
t/intel/XDK/xdk/node_modules/q/q.js:796:13)\n    at /opt/intel/XDK/xdk/node_modules/q/q.j
s:604:44"", source: /opt/intel/XDK/xdk/core-modules/private/logger.js (17)
[18398:0523/225841:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:41.071Z]: (1464037121
071): Unexpected exception while initializing \"device-discovery\" (maybe crash): Error:
Dynamic Linking Error: libcrypto.so.1.0.0: cannot open shared object file: No such file o
r directory\nError: Dynamic Linking Error: libcrypto.so.1.0.0: cannot open shared object
file: No such file or directory\n    at new DynamicLibrary (/opt/intel/XDK/xdk/node_modul
es/ffi/lib/dynamic_library.js:74:11)\n    at Object.Library (/opt/intel/XDK/xdk/node_modu
les/ffi/lib/library.js:45:12)\n    at start (file:///opt/intel/XDK/xdk/components/client/
device-discovery/impl/discovery-iosdb.js:17:217)\n    at file:///opt/intel/XDK/xdk/compon
ents/client/device-discovery/device-discovery.js:17:9939\n    at Array.map (native)\n
at Array.impls_.call (file:///opt/intel/XDK/xdk/components/client/device-discovery/device
-discovery.js:17:9879)\n    at Object.start (file:///opt/intel/XDK/xdk/components/client/
device-discovery/device-discovery.js:17:8460)\n    at resumeClientInit (/opt/intel/XDK/xd
k/core-modules/private/main.js:17:12038)\n    at /opt/intel/XDK/xdk/core-modules/private/
main.js:17:1734\n    at _fulfilled (/opt/intel/XDK/xdk/node_modules/q/q.js:834:54)"", sou
[18398:0523/225841:INFO:CONSOLE(17)] ""xdk:client:[2016-05-23T20:58:41.156Z]: (1464037121
156): Error in common initialization"", source: /opt/intel/XDK/xdk/core-modules/private/l
ogger.js (17)
[18415:0523/225841:WARNING:x11_util.cc(1408)] X error received: serial 349, error_code 3
(BadWindow (invalid Window parameter)), request_code 4, minor_code 0 (X_DestroyWindow)
[18398:0523/225847:ERROR:channel.cc(316)] RawChannel read error (connection broken)
Suggestions?
Regards, ToreL
PaulF_IntelCorp
Tore -- the XDK is only validated on Ubuntu, we do not test it on Fedora. Try installing a 32-bit Ubuntu VM on your system and install the XDK there.
