Software Archive
Read-only legacy content
17060 Discussions
[SOLVED] can't install on ubuntu 12.04
mrhadian
I want to install parallel_studio_xe_2011_sp1_update2_ia32 on ubuntu 12.04. after checking the licence it stops because of prerequisites without a clear message. here is the message:
Step no: 4 of 6 | Options > Unresolved Critical Prerequisite(s)
There is one or more critical unresolved issues which prevents the installation
from continuing. You can fix it without exiting from the installation and
re-check.
Or you can quit from the installation, fix it and run the installation again.
Prerequisite(s)
-- missing system commands
1. Show the detailed info about issue(s) [default]
2. Re-check the prerequisites
h. Help
b. Back to the previous menu
q. Quit
Please type a selection or press "Enter" to accept default choice [1]:
mrhadian
I installed "essential build". then the installation of parallel studio was done!
