Software Archive
Read-only legacy content
Avisos
17060 Discusiones
SR300 Preventing Computer Sleep
Eric_J_
Principiante
3.233 Vistas
I recently received my SR300 dev kit. The camera is working wonderfully with Windows Hello and the SDK, but I can't get my computer to go to sleep with the camera attached to the USB port. When I tell the computer to go to sleep, it powers off briefly (about 4 seconds) and then turns back on. 'powercfg /lastwake' does not indicate the source the wake request, but it happens every time. If I disconnect the camera, no problems with sleeping. Anyone have any ideas on how to fix this? I've tried unchecking the "allow this device to wake the computer" everywhere that I can think of in Device Manager as it relates to the camera but that has had no effect. I have the latest DCM from Intel's site as well.
Windows 10 Pro - Intel i5-6600K - Gigabyte Gaming 7 Z170
0 kudos
4 Respuestas
GTL
Principiante
3.233 Vistas
I've got the exact same thing! My PC also wakes directly after I put it to sleep, without the SR300 there is no problem. I also tried powercfg /lastwake, but no success.
I hope there is a workaround since I use sleep all the time.
Windows 10 Pro 10586.318 - Intel 4670K - Asus Z87 Pro
Update
I installed the older DCM driver and now everything is working fine.
lee_s_1
Principiante
3.233 Vistas
I'm also experiancing this issue...
Any news on this?
Eric_J_
Principiante
3.233 Vistas
It does not seem to be affecting me anymore so I'm not sure what, if anything fixed it, nor can I prove that it was associated with the webcam. Good luck.
Chuck_K_
Principiante
3.233 Vistas
Just replaced an F200 with an SR300 camera and have the same issue with immediately waking the computer from sleep when the camera is connected.  Anyone have any ideas about the cause/solution?  I've run through all the usual Windows sleep diagnostics.
Responder
