Software Archive
Read-only legacy content
STREAM benchmark test results for several Intel architectures
SergeyKostrov
Valued Contributor II
*** STREAM benchmark test results for several Intel architectures *** This is a thread for tests results using STREAM benchmark for several Intel architectures. Results for Ivy Bridge posted first. Results for KNL will be posted some time later.
SergeyKostrov
This is how that timing function was modified:
/* A gettimeofday routine to give access to the wall
   clock timer on most UNIX-like systems. */
double mysecond( void )
 double value;
 #ifdef _USE_CUSTOM_RDTSC
 value = Rdtsc();
 #else
 struct timeval tp;
 struct timezone tzp;
 int i = gettimeofday( &tp, &tzp );
 value = ( ( double )tp.tv_sec + ( double )tp.tv_usec * 1.e-6 );
 #endif
 return ( double )value * dTscSS;
 #else
 return ( double )value;
 #endif
I also verified results for both implementations of mysecond function:
Unmodified:
Function    Best Rate MB/s  Avg time     Min time     Max time
Copy:           17475.6     0.025130     0.024001     0.036002
Scale:          11650.2     0.036292     0.036002     0.037003
Add:            13106.7     0.049422     0.048002     0.051003
Triad:          12839.2     0.049809     0.049002     0.058004
Modified:
Copy:           17476.3     0.026742     0.024000     0.037000
Scale:          11650.9     0.036226     0.036000     0.038000
Add:            12839.8     0.049387     0.049000     0.051000
Triad:          12839.8     0.051161     0.049000     0.066000
and they are consistent.
SergeyKostrov
On average 17 GB/s ( for copy operation ) and it is ~35% lower than a theoretical 25 GB/s for an Ivy Bridge system. I've added explicitly a command line option -mavx for MinGW C++ compiler and results on average 22 GB/s ( for copy operation ) and it is ~15% lower than a theoretical memory bandwidth.
SergeyKostrov
STREAM version $Revision: 5.10 $
This system uses 4 bytes per array element.
Array size = 134217728 (elements), Offset = 0 (elements)
Memory per array = 512.0 MiB (= 0.5 GiB).
Total memory required = 1536.0 MiB (= 1.5 GiB).
Each kernel will be executed 128 times.
The *best* time for each kernel (excluding the first iteration)
will be used to compute the reported bandwidth.
Number of Threads requested = 4
Number of Threads counted = 4
Your clock granularity/precision appears to be 15599 microseconds.
Each test below will take on the order of 62399 microseconds.
   (= 4 clock ticks)
Increase the size of the arrays if this shows that
you are not getting at least 20 clock ticks per test.
WARNING -- The above is only a rough guideline.
For best results, please be sure you know the
precision of your system timer.
Copy:           22943.3     0.067436     0.046800     0.093601
Scale:          13765.9     0.098022     0.078000     0.124801
Add:            12905.6     0.132785     0.124800     0.171601
Triad:          12905.6     0.132784     0.124800     0.171601
Solution Validates: avg error less than 1.000000e-006 on all three arrays
gaston-hillar
Hi Sergey,
Thanks for sharing all these results. Are you sharing the results of the following STREAM benchmark: https://www.cs.virginia.edu/stream/?
SergeyKostrov
>>...Are you sharing the results of the following STREAM benchmark: https://www.cs.virginia.edu/stream/? Yes, and C codes source file was downloaded from: http://www.cs.virginia.edu/stream/FTP/Code/stream.c.
SergeyKostrov
>>... >>Scale: 13765.9 0.098022 0.078000 0.124801 >>Add: 12905.6 0.132785 0.124800 0.171601 >>Triad: 12905.6 0.132784 0.124800 0.171601 >>... I don't think that measurements for Scale, Add and Triad tests should be done in GB/s and they need to be measured in FLOPS.
gaston-hillar
@Sergey,
Thank you for the quick response and for sharing the link with the C source files.
