Software Archive
Read-only legacy content
17060 Discussions
Segmentation Fault when using mpirun -f option
Dan_M_4
Whenever I use the mpirun -f option to run MPI programs on the device, I get a segmentation fault.
[user@node ~]$ echo mic0 > mic0.hosts
[user@node ~]$ mpirun -perhost 1 -n 2 -f mic0.hosts  ./hello
Segmentation fault
However, I am able to run it fine with the -host option or even with the -f option as long as there are no mic devices in the file.
[user@node ~]$ echo different_node > mic0.hosts
[user@node ~]$ mpirun  -n 2 -f mic0.hosts  ./hello
CPU: Hello from different_node 1 of 2
CPU: Hello from different_node 0 of 2
[user@node ~]$ mpirun -perhost 1 -n 2 -host mic0  ./hello
MIC: Hello from node-mic0 1 of 2
MIC: Hello from node-mic0 0 of 2
I haven't been very successful in debugging this problem. Does anyone have any suggestions?
Dan
Loc_N_Intel
Hi Dan,
If the file mic0.host contains "mic0" only, then your two commands are equivalent
% mpirun -perhost 1 -n 2 -f mic0.hosts  ./hello
% mpirun -n 2 -host mic0  ./hello
Assuming that "hello" is the MIC binary, and transferred to /root in mic0
Could you verify the content of mic0.hosts contains only mic0?
% cat mic0.hosts
Also, what MPI version and compiler version are you using? Thank you.
Dan_M_4
Thank you for your response.
I am using Intel MPI v4.1.3.045.
I construct mic0.hosts using "echo mic0 > mic0.hosts". It does contain only mic0 as confirmed by cat:
$ cat mic0.hosts
mic0
If I construct the hosts file the same way but with non-Xeon Phi hosts, then the program executes correctly. I would have expected the -hosts command and the -f command to be equivalent to, however I observe a segmentation fault with one and proper execution with the other.
Dan
Frances_R_Intel
I notice that in your original example, you specify -perhost on the command line when you are using the coprocessor but not when you are using the non-coprocessor hosts. Is this just a typo? If not, could you try your example using the -perhost in both cases?
Frances_R_Intel
I have not been able to duplicate this behavior. If this is still a problem, please let us know.
Dan_M_4
Thank you for checking in Frances. I have checked again today and there is no problem with using the -f option, although I haven't updated any of the software involved. It is working both with the -perhost option and without it. So, it seems I am no longer able to reproduce the problem myself.
I will post here again if the problem resurfaces. Thank you for your help.
Dan
