Software Archive
Read-only legacy content
17060 Discussions
Sharing Data between Fortran programs
Tote_Licences
Hi there,
I have been unsuccessfully trying to use the MODULEstatement and a DLL to allow sharing of data.
First I set up a dll contining this code :-
module Global_Commons
implicit none
INTEGER*4 FIRST, LAST
COMMON /TSKCOM/ FIRST
COMMON /TSKCOM/ LAST
VOLATILE :: /TSKCOM/
end module Global_Commons
I use one program to set values in the new TSKCOM
program Console1
use Global_Commons
implicit none
CHARACTER*4 RESPONDER
FIRST=1
LAST=2
Write (*,100) FIRST, LAST
100 FORMAT (" Written to common FIRST=",I5," LAST=",I5)
read (*,200) RESPONDER
200 FORMAT (A)
end program Console1
and another to read the new TSKCOM
program Console2
use Global_Commons
implicit none
100 FORMAT (" In common FIRST=",I5," LAST=",I5)
200 FORMAT (A)
END
The second program displays both values as zero.
Could you possibly explain what I have done wrong?
prandf
hi
This works but I am having problems with connecting a C program to the shared memory module.
I suspect it is something to do withthe build options.
I have a C version of the datastructure Global_Commons.
implicit none
INTEGER*4 :: FIRST = 678
INTEGER*4 :: LAST
!DEC$ ATTRIBUTES DLLEXPORT :: /TSKCOM/
program Console1
use Global_Commons
implicit none
FIRST=1
LAST=2
Write (*, "('First and Last begin as : ',I5,I5)") FIRST, LAST
RESPONDER = '0000'
do while (RESPONDER .ne. '9999')
write(*,"('press return to continue - 9999 to finish')")
read (*,"(A)") RESPONDER
write (*,"('Now First and Last are = ',I5,I5)") FIRST, LAST
write (*,"('enter new value for FIRST ')")
read (*,"(I8)") FIRST
write (*,"('enter new value for LAST ')")
read (*,"(I8)") LAST
enddo
program Console2
use Global_Commons
implicit none
Write (*,"('First and Last begin as : ',I5,I5)") FIRST, LAST
RESPONDER = '0000'
enddo
END
the build file looks like this
rem build Global_Commons
ifort /nologo /dll Global_Commons.f90 /link /section:.data,RWS
rem build Console1
ifort /nologo /libs:dll Console1.f90 Global_Commons.lib
rem build Console2
ifort /nologo /libs:dll Console2.f90 Global_Commons.lib
rem "all done"
Any ideas on getting the C routine to share the Fortran shared global module?
regards
Peter.
