Software Archive
Read-only legacy content
17060 Discussions
Shimmering colours
davidgraham
I am displaying 256 boxes on a dialog using FillRec.
When the dialog is first displayed the whole dialog shimmers, but if I move the dialog it stops and is the display is OK.
Any ideas how I can stop this?
David
davidgraham
Jugoslav,
Here is the code for drawing the 256 colours (in fact 16 colours drawn 16 times at present). The main call are CreateSolidBrush, FillRect & DeteObject - all the rest is drawing the rectangles in the correct place.
grad_inc & the *.gcb files contain global variables.
David
integer*4 function SetColourProc(hwnd, message, wParam, lParam)
!MS$ATTRIBUTES STDCALL, ALIAS : '_SetColourProc@16' :: SetColourProc
use dfwin
use grad_inc
include 'resource.fd'
include 'rgbcol.gcb'	! api_rgb,api_rgbc,api_lsc
include 'apipar.gcb'	! hdc,x/yClientView,yClientOffset,hpen
common/SetColourc/jSetColour
integer*2	jSetColour
TYPE(T_RECT)   rect1,rectC,rectD,rectB
integer*4	hwnd, message, wParam, lParam
integer*4 iret,hdcDlg,iCtrl,hdcClr,hbr,col,row,hColours,CWidth,CHeight
integer*4 XColour,YColour
integer*4	hSR
integer*2	c,r,b
real*4	width,height
logical*4	lret
! Unreferenced variables
lparam = lparam
select case (message)
     case (#0053)			! WM_HELP
      call help
    case (WM_INITDIALOG)
	hdcDlg=GetDC(hWnd)
	SetColourProc=1
	return
    case (WM_SHOWWINDOW)
	if (wParam) then
                 	iret=ShowCursor(.TRUE.)
		hColours=GetDlgItem(hwnd,IDC_COLOURS)
	endif
        SetColourProc = 1
        return
case (WM_PAINT)
	lret=GetWindowRect(hColours,rectC)
	lret=GetWindowRect(hwnd,rectD)
	hdcClr = GetDC (hwnd)
	lret=GetClientRect(hwnd,rect1)
	col=16
	row=16
	XColour=rectC%left-rectD%left
	YColour=rectC%top-rectD%top
	CWidth=rectC%right-rectC%left-7
	CHeight=rectC%bottom-rectC%top-15
	width=real(CWidth)/(real(col)+(real(col)+1.0)/2.0)
	height=real(CHeight)/(real(row)+(real(row)+1.0)/2.0)
	do b=1,256				! 256 colours
		c=imod(b-1,col)+1	! column
		r=int2((b-1)/row)+1	! row
		rect1%left=(int4(c)*(1.5)-1.0)*width+Xcolour
		rect1%right=rect1%left+width
		rect1%top=(int4*(1.5)-1.0)*height+Ycolour-10
		rect1%bottom=rect1%Top+height
		hbr = CreateSolidBrush (RGB(api_rgb(1,c),api_rgb(2,c),api_rgb(3,c)))
		lret = FillRect (hdcClr, rect1, hbr)
		lret = DeleteObject (hbr)
	end do
case (WM_COMMAND)                       ! message: received a command
	iCtrl=LoWord(wParam)
	select case (iCtrl)
case (IDOK)				! OK
	lret=EndDialog(hWnd,1)
            SetColourProc = 1
case (IDCANCEL)		! System menu close command?
            lret = EndDialog(hWnd, 0)
            SetColourProc = 1
end select
case default
	SetColourProc=0
	end select
               return
	end function SetColourProc
Jugoslav_Dujic
Valued Contributor II
IMO it's quite incommon to do the drawing directly on
dialog's hDC. Even as you wrote it, its atypical for standard
WM_PAINT handling. You can try two things:
1) Add
type(T_PAINSTRUCT) ps
      IF (GetUpdateRect(hWnd,Rect,.FALSE.)) THEN
            hdcClr=BeginPaint(hWnd,ps)
            bSt=EndPaint(hWnd,ps)
      END IF
(also remove line hDcClr=GetDC(...))
I think that dialog shimmers because noone has ever
validated the update region, so Windows keep on
sending WM_PAINT until the region is validated another
way. ValidateRect documentation says that, quote,
"The BeginPaint function automatically validates the entire client area. Neither the ValidateRect nor ValidateRgn function should be called if a portion of the update region must be validated before the next WM_PAINT message is generated. Windows continues to generate WM_PAINT messages until the current update region is validated."
b) Nevertheless, I think it's clearer to do the drawing in an owner-
drawn static control. So, make IDC_COLOURS an owner-drawn static control
Unfortunately, Visual Studio 5 (nor 6, as I checked) does not have "Owner drawn" check-box for static control on property sheet. You have to edit .rc file manually later - add SS_OWNERDRAW style to your control:
CONTROL "",IDC_COLOURS,"Static",SS_OWNERDRAW,11,16,116,120
then, instead of WM_PAINT, process WM_DRAWITEM in SetColourProc:
TYPE(T_DRAWITEMSTRUCT)::      DIS;  POINTER(pDIS,DIS)
CASE(WM_DRAWITEM)
      pDIS=lParam
      hdcClr=DIS%hDC
and leave the rest of the code more or less the same.
Owner-drawn controls are very powerful for obtaining nice
effects with controls.
HTH
Jugoslav
davidgraham
Thanks, I used the BeginPaint / EndPaint and the colours are now OK.
David
