Using intelxdk 32.40 with app framework.
After a clean project installation my pageshow won't fire at all. Tried many different ways not sure what to do next.
I used it before but now it won't fire any page(before show/init/show).
This is the code i am using
$(document).on("pageshow",function(){
alert("pageshow event fired - the page is now shown");
this is the html
<!DOCTYPE html>
<html>
* Please see the included README.md file for license terms and conditions.
<head>
<link rel="stylesheet" type="text/css" href="app_framework/3.0/af.ui.css" data-ver="2">
<link rel="stylesheet" type="text/css" href="app_framework/3.0/icons.min.css">
<meta charset="UTF-8">
<title>Blank App Designer Cordova Web App Project Template</title>
<meta http-equiv="Content-type" content="text/html; charset=utf-8">
* The "meta viewport" tag (below) helps your app size appropriately to a device's ideal viewport.
* Note that Windows device viewports work better when initialized using the @viewport CSS rule.
* For a quick overview of "meta viewport" and @viewport, see this article:
* http://webdesign.tutsplus.com/tutorials/htmlcss-tutorials/quick-tip-dont-forget-the-viewport-meta-tag
* To see how it works, try your app on a real device with and without a "meta viewport" tag.
* Additional useful references include:
* http://www.quirksmode.org/mobile/viewports.html
* http://www.quirksmode.org/mobile/metaviewport/devices.html
* https://developer.apple.com/library/safari/documentation/AppleApplications/Reference/SafariHTMLRef/Articles/MetaTags.html
<!-- <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1"> -->
<meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=no">
<!-- <meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=yes, minimum-scale=1, maximum-scale=2"> -->
<style>
/* following three (cascaded) are equivalent to above three meta viewport statements */
/* see http://www.quirksmode.org/blog/archives/2014/05/html5_dev_conf.html */
/* see http://dev.w3.org/csswg/css-device-adapt/ */
@-ms-viewport { width: 100vw ; min-zoom: 100% ; zoom: 100% ; } @viewport { width: 100vw ; min-zoom: 100% zoom: 100% ; }
@-ms-viewport { user-zoom: fixed ; min-zoom: 100% ; } @viewport { user-zoom: fixed ; min-zoom: 100% ; }
/*@-ms-viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; } @viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }*/
</style>
<link rel="stylesheet" href="css/app.css">
<link rel="stylesheet" type="text/css" href="css/index_main.less.css" class="main-less">
<!-- IMPORTANT: Do not include a weinre script tag as part of your release builds! -->
<!-- Place your remote debugging (weinre) script URL from the Test tab here, if it does not work below -->
<!-- <script src="http://debug-software.intel.com/target/target-script-min.js#insertabiglongfunkynumberfromthexdkstesttab"></script> -->
<!-- Recommended location for your JavaScript libraries -->
<!-- These library references (below) are just examples to give you the general idea... -->
<!-- <script src="lib/mc/hammer.js"></script> -->
<!-- <script src="lib/ft/fastclick.js"></script> -->
* cordova.js is a phantom lib for "Cordova HTML5 web app," it does nothing in a "Standard HTML5 web app"
* Seeing a "Failed to load resource: net::ERR_FILE_NOT_FOUND" message caused by this "cordova.js" script?
* The cordova.js script is required if you convert your "Standard HTML5" project into a "Cordova" project.
* You can safely ignore the error or comment out this line if you will not be developing a Cordova app.
<script src="cordova.js" id="xdkJScordova_"></script>
<script src="js/app.js"></script>
<!-- for your event code, see README and file comments for details -->
<script src="js/init-app.js"></script>
<!-- for your init code, see README and file comments for details -->
<script src="xdk/init-dev.js"></script>
<!-- normalizes device and document ready events, see file for details -->
<script type="application/javascript" src="lib/jquery.min.js"></script>
<script type="application/javascript">
$.afui.autoLaunch = false; //By default, it is set to true and you're app will run right away. We set it to false to show a splashscreen
/* This function runs when the content is loaded.*/
$.afui.useOSThemes=false;
$(document).ready(function(){
setTimeout(function(){
$.afui.launch();
},1500);
</script>
<script type="application/javascript" src="app_framework/3.0/appframework.ui.min.js"></script>
<script type="application/javascript" src="lib/appframework.js"></script>
<script type="application/javascript" src="js/index_user_scripts.js"></script>
<script type="application/javascript" src="xdk/ad/af_subpage.js"></script>
</head>
<body id="afui" class="v2">
<!-- Place your remote debugging (weinre) script URL from the Test tab here, if it does not work above -->
<div class="upage vertical-col left view" id="mainpage" data-header="af-header-1" data-footer="none">
<header class="container-group outer-element uib_w_2" data-uib="app_framework/header" data-ver="3" id="af-header-1">
<h1></h1>
<div class="widget-container wrapping-col single-centered"></div>
<div class="widget-container content-area horiz-area wrapping-col header-left"></div>
<div class="widget-container content-area horiz-area wrapping-col header-right"></div>
</header>
<div class="pages">
<div class="upage-outer">
<div class="upage-content vertical-col left panel ac0" id="uib_page_1">
</div>
</div>
</div>
</div>
<div class="upage vertical-col left view" id="uib_page_2" data-header="af-header-0" data-footer="none">
<header class="container-group outer-element uib_w_1" data-uib="app_framework/header" data-ver="3" id="af-header-0">
<h1></h1>
</header>
<div class="pages">
<div class="upage-content vertical-col left panel ac0" id="uib_page_3">
</div>
</div>
</div>
</div>
</body>
</html>
- Tags:
- HTML5
- Intel® XDK
Found the solution
Ordering the scripts differently makes it work
jQuery-mobile must be in last position.
When using App Framework UI library, JQuery should be the last script in the HEAD.
Topic Options
