Software Archive
Read-only legacy content
Static analysis results do not show
Alexis_B_
Dear all,
I'm using Microsoft Visual Sutdio 2008 to developp a C++ application and I'm using Intel XE Parallel studio to do memory profiling (with Inspector). I would like to do static analysis ( as explained here : http://software.intel.com/sites/products/documentation/doclib/stdxe/2013/composerxe/compiler/fortran-mac/index.htm#GUID-56C2AE33-B3D4-470F-9FA1-10ACB9EF274F.htm ). There the documentation says:
Analysis results will open automatically in the Intel® Inspector XE user interface.
But after running Build for Intel Static Analysis, then nothing happens. Console output indicate that compilation run without errors.
Does anyone knows what's happening? What could I investigate more?
Alexis
Bernard
Valued Contributor I
Did you try to link with Intel librarian tool xilib.exe?
Bernard
Do you have any updates?
Alexis_B_
Thanks for the reply. I finally catched that I had to configure my project for Intel Compiler before being able to access the Static analysis options. This is strange as now when I try to run "Build for Intel Static Analysis", I get a popup to ask me to configure the project compiler to do that...
Next I'm having other problems: one of my project fails for analysis. Compiling with Intel works fine, but when I enable static analysis, this is what show up in the console:
Performing source code analysis... (Intel C++ Environment)
Analysis 10 % complete
Analysis 20 % complete
Analysis 30 % complete
": internal error: backend signals
Analysis 40 % complete
Analysis 50 % complete
xilink: error #10338: Static analysis has failed because of an internal error(code 4).  Analysis results are likely to be incomplete.
I guess I should open a new thread for this, but in case someone read it there... Thanks
Bernard
I cannot find what is the meaning of error code 4.
Alexis_B_
Following comments put on thread http://software.intel.com/en-us/forums/topic/327968, I'm still getting the error while I performed an update to change the compiler version (previously 13.1.3.198 Build 20130607, after update: 14.0.0.103 Build 20130728). I don't know where to look further, and additionally I cannot connect to the Premier Support website (it keeps saying "Not Authorized to Access" while I have valid support and correct activations...)
Alexis
Bernard
Try to ask that question on Intel compiler forum relevant to programming language used by you.
