Software Archive
Read-only legacy content
17060 Discussions
Static variable alignment
james1
I need to align a static variable on a 64k boundary. On OVMS one did this by using the PSECT ALIGN directive, however CVF does not appear to support this past 6. Any suggestions?
The MS linker doesn't support this - sorry. What are you trying to accomplish? Perhaps there's another way...
Steve
james1
I need to use MapViewOfFileEx with lpBaseAddress pointing to the address of a 64k aligned static data structure. There should be a way, otherwise I don't know why this Win32 routine would exist in addition to the MapViewOfFile call. Thanks.
James
james1
Also I noticed from the release notes that ALIGN=PAGE should work (note that it does not solve this problem, I need ALIGN=16) but that doesn't appear to work in the 6.6 RC. From what I can tell the directive has no effect regardless of value.
James
Hmm - I'll ask our local expert on such things to see what is going on...
Steve
Ok, here's the scoop.
First, there's a bug in CVF, in that alignments greater than 6 are limited to 6. We'll fix that.
Second, the documentation says that for IA32, an alignment of 13, not 16, is the maximum, and that PAGE gets you 12 (4096 bytes), which is indeed the Windows page size.
Third, the PE-COFF object file format does not support alignments past 8192 bytes, so we couldn't go past that even if we wanted to.
MapViewOfFileEx does not suggest that there is a way to get 64K-aligned static data. It leaves it up to you to figure out how to get the address space. My recommendation is to create a COMMON of size 128K-1 bytes and then take the address of the last element and IAND it with Z'FFFF0000' to get your address. How you deal with that as a variable in Fortran is an exercise left for the reader.
Steve
james1
First, I still contend that the alignment directive is being ignored for all values. Just an FYI, I have example code if needed.
Second, I believe the limitation in the linker, and am just trying to determine a way around it without resorting to pointers for a large body of existing code (using a large, complex structure mapped to a global section under OVMS, with direct access to the record variable from all code). I know the page size is 4k, but unfortunately that isn't sufficient alignment for this call, which requires 64k.
Regarding creating a common of size 2^17-1 this does not work, the original common remains aligned on a 2^6 boundary which doesn't help. Unless I can get a location (even if not properly aligned) at compile time, I have no way to base structures by relying upon chopping off the low order 16 bits. If I had the information at compile time then indeed I could equivalence to the appropriate location in a byte array, but doing this calculation at runtime doesn't appear to gain anything over using pointers.
James
My tests show that the directive does work, up to a maximum alignment of 6.
As for using pointers, yes, that's essentially what I was proposing.
Steve
james1
Regarding pointers, I would just use MapViewOfFile and that would be that. :-) Just trying to make this transparent to a lot of existing code...
Anyhow here is what *I* see regarding the operation of the PSECT ALIGN directive.
align.f90
program test_align
implicit none
integer aval
byte base
byte x0, x1, x2, x3, x4, x5, x6, x7, x8, x9, x10, x11, x12
common /cx0/ x0
common /cx1/ x1
common /cx2/ x2
common /cx3/ x3
common /cx4/ x4
common /cx5/ x5
common /cx6/ x6
common /cx7/ x7
common /cx8/ x8
common /cx9/ x9
common /cx10/ x10
common /cx11/ x11
common /cx12/ x12
!DEC$ PSECT /cx0/ ALIGN=0
!DEC$ PSECT /cx1/ ALIGN=1
!DEC$ PSECT /cx2/ ALIGN=2
!DEC$ PSECT /cx3/ ALIGN=3
!DEC$ PSECT /cx4/ ALIGN=4
!DEC$ PSECT /cx5/ ALIGN=5
!DEC$ PSECT /cx6/ ALIGN=6
!DEC$ PSECT /cx7/ ALIGN=7
!DEC$ PSECT /cx8/ ALIGN=8
!DEC$ PSECT /cx9/ ALIGN=9
!DEC$ PSECT /cx10/ ALIGN=10
!DEC$ PSECT /cx11/ ALIGN=11
!DEC$ PSECT /cx12/ ALIGN=12
type *
type *, 'LOCATION REQUESTED ACTUAL'
type 1, loc(base), -1, aval(loc(base))
type 1, loc(x0), 0, aval(loc(x0))
type 1, loc(x1), 1, aval(loc(x1))
type 1, loc(x2), 2, aval(loc(x2))
type 1, loc(x3), 3, aval(loc(x3))
type 1, loc(x4), 4, aval(loc(x4))
type 1, loc(x5), 5, aval(loc(x5))
type 1, loc(x6), 6, aval(loc(x6))
type 1, loc(x7), 7, aval(loc(x7))
type 1, loc(x8), 8, aval(loc(x8))
type 1, loc(x9), 9, aval(loc(x9))
type 1, loc(x10), 10, aval(loc(x10))
type 1, loc(x11), 11, aval(loc(x11))
type 1, loc(x12), 12, aval(loc(x12))
1 format(x,z8.8,6x,i2,6x,i2)
end
integer function aval (addr)
integer addr
integer i,j
i = 0; j = -1
do while (j .lt. 0 .and. i .lt. bit_size(addr)-1)
  if (btest(addr,i)) then
    j = i
  else
    i = i + 1
  end if
end do
aval = j
return
end
Result under Windows XP Pro build 2505 CVF 6.6
00448604      -1       2
0044C040       0       6
0044C038       1       3
0044C030       2       4
0044C028       3       3
0044C020       4       5
0044C018       5       3
0044C010       6       4
0044C008       7       3
0044C000       8      14
0044BFF8       9       3
0044BFF0      10       4
0044BFE8      11       3
0044BFE0      12       5
Sanity check on OpenVMS Alpha V7.3 CF 7.3
00040000      -1      18
00040010       0       4
00040012       1       1
00041004       2       2
00041008       3       3
00041010       4       4
00041020       5       5
00041040       6       6
00041080       7       7
00041100       8       8
00041200       9       9
00040400      10      10
00040800      11      11
00041000      12      12
FWIW,
James
James,
I have good news and bad news. The good news is that we'll fix the compiler to allow alignments up to 13 to work. The bad news is that the Microsoft object format does not recognize alignment requests on uninitialized COMMONs - there's nothing we can do about this. The workaround is to DATA initialize at least one variable in your COMMON. Note that you must do this in one program unit only, preferably a BLOCK DATA subprogram. We'll amend our documentation to state this.
Steve
james1
Steve,
I came across a proposed solution in C and wondered if there was a way to do this in CVF. The following procedure (roughly) should do the job in C:
typedef structure _record_str
    INT    record_number;
    DWORD  number;
    struct record_junk; ...
}    _record_str;
#pragma data_seg(".record_seg")
extern _record_str _record_common;
#pragma data_seg()
This link with /align:0x10000. Of course this gives all program sections 64k alignment but there aren't that many. I notice that with my previous example that all commons are placed in the same program section (.data), so is there any way to identify a common with a separate program section?
James
