Software Archive
Read-only legacy content
17060 Discussions
Status bar appears in android app
Campuzano_Serna__Jua
XDK ver. 3641
Android 6
Hello, I have a minimal application for android created with XDK.
The status bar is visible under the following conditions:
- When you start the application for the first time, sometimes the status bar is visible.
- If you launch the application from the android main screen, the status bar is visible.
- If you check the applications open and select the application the status bar is visible.
- If you query the open applications and select another native application and then re-select your application, the status bar then is not visible.
That is, it seems that the application created with XDK by itself is not able to hide the status bar at times.
In this video the application created with XDK is a blank screen, you can see that sometimes the visible status bar appears.
https://www.youtube.com/watch?v=t-KqvEf0jrM&feature=youtu.be
To solve this, in Construct 2 you have to run this event at all times.
http://i.imgur.com/qOooJFp.png
Any other necessary information?
Sorry for my english.
PaulF_IntelCorp
I recommend you try using the status bar plugin to get some control over that > https://www.npmjs.com/package/cordova-plugin-statusbar <
Sure, I'm using that plugin but I still have this problem.
I have read the documentation of the plugin, maybe I should always hide the bar at runtime?
I thought it was hidden automatically when I indicated in XDK the "FullScreen" box.
PaulF_IntelCorp
Yes, use the API to hide at runtime. That will be the most reliable route to success.
Ok, that solution will apply, thanks for your time !.
