Software Archive
Read-only legacy content
17061 Discussions
Strange Errors by reseting mic configuration
Kevin_F_1
Hi all,
I have installed mpss 3.3.3 on my Centos 7.2 machine. After rebuilding the kernel-modules, I could install it without problems.
I had another mpss configuration on the machine which caused problems (in terms of, no functioning). So I removed those packages and reinstalled.
When I want to reset the config / init the default config, I get those errors.
micinfo displays my Xeon Phi and I can access it via ssh.
I just wanted to know it this Errors are somewhat take influence on my system. And how to fix them
micctrl --resetconfig -v
  [Error] mic0: [Parse] Family invalid config parameter
  [Error] mic0: [Parse] MPSSVersion invalid config parameter
[Warning] mic0: Generating compatibility network config file /opt/intel/mic/filesystem/mic0/etc/sysconfig/network/ifcfg-mic0 for IDB.
[Warning]       This may be problematic at best and will be removed in a future release, Check with the IDB release.
[root@mice mpss-3.3.3]# micctrl --resetconfig -v
   [Info] mic0: Using existing /etc/mpss/default.conf
   [Info] mic0: Using existing /etc/mpss/mic0.conf
   [Info] mic0: File System Base /usr/share/mpss/boot/initramfs-knightscorner.cpio.gz
   [Info] mic0: Common files at /var/mpss/common
   [Info] mic0: Unique files at /var/mpss/mic0
   [Info] mic0: Hostname mice-mic0
   [Info] mic0: Updated /etc/hosts with 172.31.1.1 mice-mic0
   [Info] mic0: Verbose mode Disabled
   [Info] mic0: Linux OS image /usr/share/mpss/boot/bzImage-knightscorner
                System Map /usr/share/mpss/boot/bzImage-knightscorner
   [Info] mic0: Boot On Start Enabled
   [Info] mic0: Shutdown Timeout 300
   [Info] mic0: MIC Crash Dump at /var/crash/mic size 16
   [Info] mic0: Restored /var/mpss/mic0/etc/ssh/ssh_host_key.pub from /var/mpss/mic0/etc/ssh/ssh_host_key.pub.save
   [Info] mic0: Restored /var/mpss/mic0/etc/ssh/ssh_host_rsa_key.pub from /var/mpss/mic0/etc/ssh/ssh_host_rsa_key.pub.save
   [Info] mic0: Restored /var/mpss/mic0/etc/ssh/ssh_host_dsa_key.pub from /var/mpss/mic0/etc/ssh/ssh_host_dsa_key.pub.save
   [Info] mic0: Restored /var/mpss/mic0/etc/ssh/ssh_host_ecdsa_key.pub from /var/mpss/mic0/etc/ssh/ssh_host_ecdsa_key.pub.save
   [Info] mic0: ExtraCommandLine 'highres=off'
   [Info] mic0: RootDevice RamFS /var/mpss/mic0.image.gz
   [Info] mic0: Console hvc0
   [Info] mic0: PowerManagement cpufreq_on;corec6_off;pc3_on;pc6_off
   [Info] mic0: Cgroup memory=disabled
   [Info] mic0: [Parse] /etc/mpss/mic0.conf
   [Info] mic0: [Parse] Configuration version 1.1
   [Info] mic0: [Parse] /etc/mpss/default.conf
Thanks in advance
most sincerely
Kevin
JJK
New Contributor III
hmmm mpss 3.3.3 is no longer support and the only version of mpss that is supported on RHEL 7.2 is mpss 3.6.1 - please consider installing that version.
And yes, mpss 3.6 support opencl, even though Intel does not support it ;)
Kevin_F_1
But I also got an intel xeon phi, and intel says one need to use 3.3.X Version for supporting it.
