Hi there,
I encounter a strange Cordova iOS build issue in Mac. I got below error without any build log for reference, yes, it only shows a single line of error message. I have no idea what goes wrong.
An error occurred while building the application. Verify your build assets are correct and try again
Strange point 1: The point is I was able to build the Adhoc version and tested in iOS devices but when I switch to Production version, the build process keeps fail.
Strange point 2: Then I tried to build in AppCenter (web portal), it is successful.
Could you please help check why? My project is DonBosco (from bestsoft2go@gmail.com)
- Tags:
- HTML5
- Intel® XDK
I see you have a couple successful builds. Were you able to get your issue fixed?
I should have 2 successful builds within last 12 hrs.
1. The first one was I used the AppCenter portal to build - After I had set to Production, uploaded, built and got two or three fails in IntelXDK tool (in Mac), I switched to the portal, I promoted the build from QA then used Cordova iOS build and it became successful.
2. The second one was I used IntelXDK tool (in Mac) - After I had got the above AppCenter build successful, I retried without changing anything in IntelXDK tool and just uploaded then rebuild, that time it became successful.
I cannot determine why what went wrong in IntelXDK tool and why I could build in AppCenter, and also IntelXDK tool became successful. I believe there was something wrong in the IntelXDK when it switched from Adhoc to Production. Before I tried in AppCentre, no matter how many times I changed between Adhoc and Production and uploaded and built, it was NOT successful until I used AppCentre to build.
Actually, the issue is NOT yet fixed, the problem is still there. It is just look like I can build after I used AppCenter portal.
Could you check what went wrong in the fail logs?
Can you try to build through the XDK again, let it fail, then let me know when you have done so?
The error occurred a few times around 16:00 ~ 17:00 Hong Kong Time (GMT+8) before I used AppCenter.
Sorry, I cannot reproduce the problem now.
