Software Archive
Read-only legacy content
17060 Discussions
Stuck at "Cordova preparing sources..."
Marcelo_C_2
Hello Friends.
I imported an existing Cordova project, when I tried to emulate, it stuck at the "Cordova preparing sources..."
I finished XDK, but when I restart it returns to the same point with the same message.
Any Clues?
Swati_S_Intel1
Close the XDK, clear the cache from XDK install location and restart.
 ~/Library/Application Support/XDK/Cache on Mac
%LocalAppData%\XDK\Cache
Marcelo_C_2
Dear Swati,
I cleared the cache, restarted windows.
When I started XDK, it got stuck at the same point.
PaulF_IntelCorp
Marcelo -- make sure there are no plugin references in your intelxdk.config.additions.xml file and delete all plugins directories located inside your project (with the XDK closed). Then open the XDK and try opening your project. You may have to add back some of the plugins manually, using the plugin management tool on the Projects tab.
Swati_S_Intel1
Marcelo, under the ~/Library/Application Support/XDK/ directory there is a global-settings.xdk file. Open that file and search for currenttab. It would be 'emulate' in your particular situation. Please change it to 'project' and save global-settings.xdk file. And then, restart the XDK, the XDK will restart with Projects tab open.
For our investigation purpose, before you do the above, please copy the xdk.log file from  ~/Library/Application Support/XDK/ folder and send it to us (attach here or Private Message). Also, if you are able to please send your project that caused this issue.
John_H_11
I am also experiencing this problem after upgrading to the latest XDK.  Cleared cache and removed plugins but still very slow when I switch to Emulator tab after making any kind of source edit.  Shows message "Cordova preparing sources...".  This is unusable in this state.
John_H_11
It turns out the slowness was due to me having installed node modules in the 'www' folder for testing purposes.  This made for a lengthy prep/build process when switching to Emulate.  Removing those folders solved the problem.
