Software Archive
Read-only legacy content
17060 Discussions
Support for Native Code C dlls called from C# main program via PInvoke
hemahgoub1
After having joined the recent Webcast about Intel Parallel Studio's Parallel Inspector and I had posed a question about support for native code C dlls that are called from a C# User Interface Program. I received the answer that this was probably not supported and I was encouraged to request support for this case. So, here I am, requesting that C native code dlls taht are called from C# UI are supported by Intel Parallel Studio.
Vladimir_T_Intel
Quoting - hemahgoub1
Intel Parallel Inspector supports native C/C++ only. But in case of not too big application Inspector's Thread Checker might handle the mixed code since all the threading API ends up in the native calls. This is not the case for Memory Checker, though.
hemahgoub1
Thanks very much for your reply. It would be convenient if Parallel Studio would support such a case, as the memory checking is important for our work.
Hossam Mahgoub
Vladimir_T_Intel
Hossam Mahgoub
Thanks for your feed back - this is valid andvaluable. I'm not sure that Intel Parallel Studio will be supporting managed run-times any soon, but it helps us to understand the customer's needs for the future products.
