Software Archive
Read-only legacy content
17061 Discussions
Problems installing Intel C v 11 on Windows 2003 with VS 2005 and VS 2008
Resa_A_
Subject : trying to install Intel v11 compilers - errors
Current status:
OS: windows server 2003
Visual studio 2005 with intel 10.1 compilers integrated
Visual studio 2008
trying to install Intel 11 compilers with integration into visual studio 8 only. the installation fails during package 7 with the following error (snipped from the install log)
MSI (s) (44:B0) [15:28:27:248]: Note: 1: 1722 2: CMM_RunDevenv2005 3: C:\Program Files (x86)\Microsoft Visual Studio 8\Common7\IDE\devenv.exe 4: /setup MSI (s) (44:B0) [15:28:56:025]: Product: Intel Parallel Debugger Extension for Microsoft Visual Studio, version 11.1.051 -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action CMM_RunDevenv2005, location: C:\Program Files (x86)\Microsoft Visual Studio 8\Common7\IDE\devenv.exe, command: /setup
Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action CMM_RunDevenv2005, location: C:\Program Files (x86)\Microsoft Visual Studio 8\Common7\IDE\devenv.exe, command: /setup MSI (s) (44:B0) [15:28:56:042]: Executing op: Header(Signature=1397708873,Version=301,Timestamp=997686129,LangId=1033,Platform=0,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=3)
MSI (s) (44:B0) [15:28:56:042]: Executing op: DialogInfo(Type=0,Argument=1033) MSI (s) (44:B0) [15:28:56:042]: Executing op: DialogInfo(Type=1,Argument=Intel Parallel Debugger Extension for Microsoft Visual Studio, version 11.1.051) MSI (s) (44:B0) [15:28:56:042]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back
Can you give me any insights?
Thanks!
Resa Alvord
Cornell University Center for Advanced Computing
clarktb09
i also had this problem. have you found a solution for this?
thank you, Clark
