I'm trying to run an mpi symmetric model on the host and mic architecture. Everything works fine as long as the total number of processes (mic+host) is less 10. But when it's greater than 10, I get the attached error.
This is my mpirun command:
mpirun -v -host p-linux -check-mpi -env I_MPI_DEBUG 5 -genv I_MPI_FABRICS shm:tcp -np 1 <host executable> : -host mic0 -iface mic0 -env I_MPI_DEBUG 5 -env LD_LIBRARY_PATH=/opt/intel/composer_xe_2013.5.192/compiler/lib/mic:/opt/intel/mic/coi/device-linux-release/lib:/opt/intel/mic/myo/lib:/opt/intel/mic/coi/device-linux-release/lib:/opt/intel/mic/myo/lib:/opt/intel/composer_xe_2013.5.192/compiler/lib/mic:/opt/intel/composer_xe_2013.5.192/mkl/lib/mic:/opt/intel/composer_xe_2013.5.192/tbb/lib/mic -np 11 <mic executable>
Here the total number of processes is 11+1=12 which is greater than 10 and so I get the error. If it's less than 10 the program executes correctly.
I noticed that in the bottom part of the above error message, i.e. :
[proxy:0:1@p-linux-mic0] got pmi command (from 30): put
kvsname=kvs_9321_0 key=P10-businesscard-0 value=description#
there is no $port ... $ifname after the "value=description#" part, which is not the case for other processes.
Just for an update, I ran the mpi test case, and got exactly the same problem.
mpirun -host p-linux -env I_MPI_DEBUG 5 -genv I_MPI_FABRICS shm:tcp -np 1 -check_mpi ./a.host : -host mic0 -iface mic0 -env I_MPI_DEBUG 5 -np 10 ./a.mic
ERROR: ld.so: object 'libVTmc.so' from LD_PRELOAD cannot be preloaded: ignored.
[0] MPI startup(): shm and tcp data transfer modes
[6] MPI startup(): shm and tcp data transfer modes
[5] MPI startup(): shm and tcp data transfer modes
[1] MPI startup(): shm and tcp data transfer modes
[4] MPI startup(): shm and tcp data transfer modes
[7] MPI startup(): shm and tcp data transfer modes
[10] MPI startup(): shm and tcp data transfer modes
[2] MPI startup(): shm and tcp data transfer modes
[3] MPI startup(): shm and tcp data transfer modes
[8] MPI startup(): shm and tcp data transfer modes
[9] MPI startup(): shm and tcp data transfer modes
[mpiexec@p-linux] handle_pmi_cmd (./pm/pmiserv/pmiserv_cb.c:78): Unrecognized PMI command: k | cleaning up processes
[mpiexec@p-linux] control_cb (./pm/pmiserv/pmiserv_cb.c:868): unable to process PMI command
[mpiexec@p-linux] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
[mpiexec@p-linux] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:435): error waiting for event
[mpiexec@p-linux] main (./ui/mpich/mpiexec.c:901): process manager error waiting for completion
But if I run if for fewer processes, I get the correct result:
mpirun -host p-linux -env I_MPI_DEBUG 5 -genv I_MPI_FABRICS shm:tcp -np 1 -check_mpi ./a.host : -host mic0 -iface mic0 -env I_MPI_DEBUG 5 -np 5 ./a.mic
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 894 p-linux {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,
30,31,32,33,34,35,36,37,38,39}
[0] MPI startup(): 1 5235 p-linux-mic0 {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30
,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45}
[0] MPI startup(): 2 5236 p-linux-mic0 {46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72
,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90}
[0] MPI startup(): 3 5237 p-linux-mic0 {91,92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112,1
13,114,115,116,117,118,119,120,121,122,123,124,125,126,127,128,129,130,131,132,1
33,134,135}
[0] MPI startup(): 4 5238 p-linux-mic0 {136,137,138,139,140,141,142,143,144,145,146,147,148,149,150,151,152,153,154,155,
156,157,158,159,160,161,162,163,164,165,166,167,168,169,170,171,172,173,174,175,
176,177,178,179,180}
[0] MPI startup(): 5 5239 p-linux-mic0 {0,181,182,183,184,185,186,187,188,189,190,191,192,193,194,195,196,197,198,199,20
0,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217,218,219,22
0,221,222,223,224}
[0] MPI startup(): I_MPI_DEBUG=5
[0] MPI startup(): I_MPI_FABRICS=shm:tcp
[0] MPI startup(): I_MPI_MIC=1
[0] MPI startup(): I_MPI_PIN_MAPPING=1:0 0
Hello world: rank 0 of 6 running on
p-linux
Hello world: rank 1 of 6 running on
p-linux-mic0
Hello world: rank 2 of 6 running on
p-linux-mic0
Hello world: rank 3 of 6 running on
p-linux-mic0
Hello world: rank 4 of 6 running on
p-linux-mic0
Hello world: rank 5 of 6 running on
p-linux-mic0
Hi George,
- Could you run your application on host only (without coprocessor) with more than 10 ranks? Do you see the same error?
- Repeat the test again on the coprocessor only (without host) with more than 10 ranks? Do you see the same error?
Hi
Everything works fine when I run on host or phi only. The problem in is the symmetric execution. I'm using the Intel mpi version 4.1.3.
Is there a MaxSessions specified in /etc/ssh/sshd_config?
Hi George,
You use the option "-iface" only in your command when you want to specify a network interface. In your case, you don't need to specify mic0. Therefore, can you retry your command without "-iface mic0" and observe if you still have that error:
# mpirun -host p-linux -env I_MPI_DEBUG 5 -genv I_MPI_FABRICS shm:tcp -np 1 -check_mpi ./a.host : -host mic0 -env I_MPI_DEBUG 5 -np 10 ./a.mic
