Software Archive
Read-only legacy content
17060 Discussions
Text in a Sent Private Message is re-formatted when 'Rich-text' disabled
SergeyKostrov
Valued Contributor II
Problem: Text in a Sent Private Message is re-formatted when 'Rich-text' disabled. Here is example: [ Source message looks like ] Aaa bbb ccc Aaa bbb ccc #include "stdio.h" int main( void ) { return ( int )0; } Aaa bbb ccc Aaa bbb ccc [ Sent message ( re-formatted ) looks like ] Aaa bbb ccc Aaa bbb ccc #include "stdio.h" int main( void ) { return ( int )0; } Aaa bbb ccc Aaa bbb ccc
SergeyKostrov
Another issue just detected: If 'Rich-text' is enabled and some text is Pasted ( Ctrl+V pressed ) the pasted text is not displayed and IE stops responding.
Bernard
I have the same issue.It is occurring right now.In order to fix it I need to disable "rich text".
SergeyKostrov
>>...If 'Rich-text' is enabled and some text is Pasted ( Ctrl+V pressed ) the pasted text is not displayed and IE stops responding. I think this is a very old problem and I see that there is some "escalation" of the problem due to recent updates on IDZ web-site. Please take a look and investigate. Thanks in advance.
Bernard
I have never seen this problem in past,but you are longer on this forum than me.I did a few observation of this problem and I can say that in mycase the hang of the comment windows occures only when I try to post my first reply since login.
Bernard
If you are interested I'm continuing to investing that problem and I can confirm that in my system the error still persists mainly when I'm freshly logged and posting a message.
SergeyKostrov
Thank you, Iliya for your investigation. I think we provided enough details for Intel Web Developers and I expect they will fix the problem.
Bernard
Thnak you, Iliya for your investigation. I think we provided enough details for Intel Web Developers and I expect they will fix the problem.
No problem:)
Have you ever experienced problem with so called "message queued for admin approval".It is quite annoying and the simple discussion is impossible.
Thanks in advance.
SergeyKostrov
>>...Have you ever experienced problem with so called "message queued for admin approval".... Yes, and it happens every time when a web link is referenced in a text of the post. In order to avoid it don't use h_t_t_p_:_\_\ prefix. Here is a test: www.aaabbbccc.com and I hope that the post will be displayed without delay.
Bernard
Thank you very much for your help.I was wondering what was the cause of those "message queues".
