Software Archive
Read-only legacy content
17060 Discussions
The connect between two hosts (host_A with mic / host_B without mic)
Jimmy_C_1
Hello, if there are two hosts server(hostA with mic, hostB without mic).
How can I use the hostB to access mic ? by using ssh or router setting ?
Andrey_Vladimirov
New Contributor III
Hi Jimmy, in the "Advanced Configuration Guide for MPSS" ( http://registrationcenter.intel.com/irc_nas/2929/MPSS_Boot_Config_Guide.pdf ), in Section 3.4.3.5 ("External Bridge Topology") they mention a network configuration of the host system with bridging. This is similar to setting up a bridge for a virtual machine. The result of this configuration is that each Xeon Phi coprocessor on the host obtains an IP address on the host's network. After that, Xeon Phi coprocessors in different nodes on the network can ping each other, connect via ssh, MPI, or any other network protocol. Routing is not involved here, everything happens on the same network.
