Software Archive
Read-only legacy content
17061 Discussions
 The package : xdk_web_linux64_master_1494 downloaded from Intel's site , to extract it I...
Alessandro_Galvão_F_
 The package : xdk_web_linux64_master_1494 downloaded from Intel's site , to extract it I did not find the file intall_gui.sh only intall.sh file, but to run it I get this message error :
sudo ./install.sh
[ sudo ] password for sandro :
Error : Incorrect path to installation script . Installation can not be started
if the path contains space symbols .
Quitting ! Press "Enter " to install terminate .
S.O : Linux Mint 17 64
Elroy_A_Intel
Intel XDK is tested and guaranteed to work on Ubuntu Linux. Other distributions of Linux is recognized as not supported at this time. I have escalated your issue to the engineering team.
Please tell me why the package does not have the file : install_gui as mentioned in the tutorial itself.
Intel XDK E Testado e Garantido Paragrafo trabalhar SEM Ubuntu Linux. Otras Distribuições de Linux E Reconhecida Como Localidade:. Localidade: Não suportado Neste Momento Eu ter encaminhado o Problema Para a Equipe de engenharia.
[/ Quote]
Miwako_T_Intel
Hi there.
Can you try installing from a directory that doesn't have a space on it?
ex. if you are installilng from
/home/my work/xdk_web_linux64/
please don't, and install from
/home/mywork/xdk_web_linux64/ or /tmp/xdk_web_linux64
or wherever.. :)
Hello I do not know how to thank for your help solved my problem , I am newbie in linux and with this information I learned a lot .
Thank you so much !
Miwako_T_Intel
No problem! I am it worked for you. :)
Thank you very much for a report. At least we should fix the inconsistency between the documentation and our product. We'll also see if it's possible for the installer to handle the space in the path though I can't promise on this one.
Cheers for now.
Miwako
Ritesh_J_
I tried downloading linux32 bit version xdk_web_linux32_master_2807.tgz It got downloaded as fL7GuzzX.bin.part . I am unable to extract it .Can you please suggest a reason . I have tried downloading several times but i see it always get downloaded as .bin.partMy system is ~/Downloads$ uname -a
Linux ritesh 3.2.0-29-generic-pae #46-Ubuntu SMP Fri Jul 27 17:25:43 UTC 2012 i686 i686 i386 GNU/Linux .
I also tried below to extrqct .bin but it failed
Downloads$ sh FPSuPSZD.bin.part
FPSuPSZD.bin.part: 1: FPSuPSZD.bin.part: Syntax error: word unexpected (expecting ")")
PaulF_IntelCorp
Try downloading it from a different machine, perhaps a Windows or Mac machine and then copy it to your Linux machine using a flash drive. The page auto-detects your OS, but you can change the file you download by using the "Choose another platform" pulldown before you push the "Download" link.
