Software Archive
Read-only legacy content
17060 Discussions
The strange method access to the global variable on MIC
王_子_
hello, recently I want to use the global variable on MIC  but find a strange problem:
At first, I write the code like this :
#include <stdio.h>
#include <stdlib.h>
__attribute__((target(mic))) double *test1;
__attribute__((target(mic))) void initglobal() {
	test1=(double *)malloc(sizeof(double)*10);
	for (int i = 0; i < 10; i++)
		test1 = i;
int main() {
#pragma offload target(mic:0)
		initglobal();
		printf("%f\n",test1[4]);
The compiler said :
error: pointer variable "test1" in this offload region must be specified in an in/out/inout/nocopy clause
And then I try the method to access the global variable :
#include <stdio.h>
#include <stdlib.h>
		test1 = i;
__attribute__((target(mic))) void printglobal() {
int main() {
		initglobal();
		printglobal();
This time it is worked and print the data.
So I have a question that the global variable is really calculated on MIC, but why I can not access directly?
