- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello, yesterday I was working with Intel XDK and everything was working fine, however today it started crashing on a Start Up. I've tried to reinstall it, deleting and cleaning all the files but it didnt help. Here are the logs:
xdk:client:[2016-06-18T06:35:30.002Z]: (1466231730003): memlim: 767557632
xdk:client:[2016-06-18T06:35:30.009Z]: (1466231730009): Setting NW crash dump to: /Users/denparf/Library/Application Support/XDK
xdk:client:[2016-06-18T06:35:30.398Z]: (1466231730398): Intel XDK: 3400
xdk:client:[2016-06-18T06:35:30.399Z]: (1466231730399): Platform: darwin-ia32 (15.5.0)
xdk:client:[2016-06-18T06:35:30.399Z]: (1466231730399): System Info: CPU: 4 X Intel(R) Core(TM) i5-2557M CPU @ 1.70GHz Physical Memory: 4294967296
xdk:client:[2016-06-18T06:35:30.399Z]: (1466231730399): NW: 0.11.7-rc10-dev
xdk:client:[2016-06-18T06:35:30.501Z]: (1466231730501): Created new theme: base
xdk:client:[2016-06-18T06:35:30.502Z]: (1466231730502): Registered new theme: base
xdk:client:[2016-06-18T06:35:30.504Z]: (1466231730504): Current theme is now: base
xdk:client:[2016-06-18T06:35:30.504Z]: (1466231730504): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-06-18T06:35:30.505Z]: (1466231730505): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-06-18T06:35:30.819Z]: (1466231730819): Starting client process initialization
xdk:client:[2016-06-18T06:35:30.855Z]: (1466231730855): OS version: 10.11.5
xdk:client:[2016-06-18T06:35:30.893Z]: (1466231730893): NW Cache is up-to-date.
xdk:server:[2016-06-18T06:35:31.845Z]: (1466231731847): memlim: 767557632
xdk:server:[2016-06-18T06:35:31.851Z]: (1466231731851): Setting NW crash dump to: /Users/denparf/Library/Application Support/XDK
xdk:server:[2016-06-18T06:35:32.197Z]: (1466231732197): Starting server process initialization
xdk:server:[2016-06-18T06:35:32.337Z]: (1466231732337): Http server started on the standard port 58889
xdk:server:[2016-06-18T06:35:32.366Z]: (1466231732366): NW Cache is up-to-date.
xdk:server:[2016-06-18T06:35:32.894Z]: (1466231732894): Component "core:assert" starting import
xdk:server:[2016-06-18T06:35:32.894Z]: (1466231732894): Component "core:assert" finished initialization
xdk:server:[2016-06-18T06:35:32.894Z]: (1466231732894): Component "core:component-error" starting import
xdk:server:[2016-06-18T06:35:32.895Z]: (1466231732895): Component "core:component-error" finished initialization
xdk:server:[2016-06-18T06:35:32.895Z]: (1466231732895): Component "core:command-line-options" starting import
xdk:server:[2016-06-18T06:35:32.895Z]: (1466231732895): Component "core:command-line-options" finished initialization
xdk:server:[2016-06-18T06:35:32.895Z]: (1466231732895): Component "core:service-error" starting import
xdk:server:[2016-06-18T06:35:32.896Z]: (1466231732896): Component "core:service-error" finished initialization
xdk:server:[2016-06-18T06:35:32.896Z]: (1466231732896): Component "core:buffer" starting import
xdk:server:[2016-06-18T06:35:32.896Z]: (1466231732896): Component "core:buffer" finished initialization
xdk:server:[2016-06-18T06:35:32.896Z]: (1466231732896): Component "core:signaler" starting import
xdk:server:[2016-06-18T06:35:32.899Z]: (1466231732899): Component "core:signaler" finished initialization
xdk:server:[2016-06-18T06:35:32.899Z]: (1466231732899): Component "core:signaler-group" starting import
xdk:server:[2016-06-18T06:35:32.902Z]: (1466231732902): Component "core:signaler-group" finished initialization
xdk:server:[2016-06-18T06:35:32.902Z]: (1466231732902): Component "core:logger" starting import
xdk:server:[2016-06-18T06:35:32.904Z]: (1466231732904): Component "core:logger" finished initialization
xdk:server:[2016-06-18T06:35:32.904Z]: (1466231732904): Component "core:http-request" starting import
xdk:server:[2016-06-18T06:35:32.906Z]: (1466231732906): Component "core:http-request" finished initialization
xdk:server:[2016-06-18T06:35:32.906Z]: (1466231732906): Component "core:database" starting import
xdk:server:[2016-06-18T06:35:32.907Z]: (1466231732907): Component "core:database" finished initialization
xdk:server:[2016-06-18T06:35:32.907Z]: (1466231732907): Component "core:version" starting import
xdk:server:[2016-06-18T06:35:32.908Z]: (1466231732908): Component "core:version" finished initialization
xdk:server:[2016-06-18T06:35:32.908Z]: (1466231732908): Component "core:userfs-name-converter" starting import
xdk:server:[2016-06-18T06:35:32.909Z]: (1466231732909): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-06-18T06:35:32.909Z]: (1466231732909): Component "core:crash-handler" starting import
xdk:server:[2016-06-18T06:35:32.911Z]: (1466231732911): Component "core:crash-handler" finished initialization
xdk:server:[2016-06-18T06:35:32.911Z]: (1466231732911): Component "core:i18n-support" starting import
xdk:server:[2016-06-18T06:35:32.911Z]: (1466231732911): Component "core:i18n-support" finished initialization
xdk:server:[2016-06-18T06:35:32.911Z]: (1466231732911): Component "core:theme" starting import
xdk:server:[2016-06-18T06:35:32.989Z]: (1466231732989): Component "core:theme" finished initialization
xdk:server:[2016-06-18T06:35:32.991Z]: (1466231732991): Component "server:userfs" starting import
xdk:server:[2016-06-18T06:35:32.999Z]: (1466231732999): Component "server:userfs" calling init()
xdk:server:[2016-06-18T06:35:33.048Z]: (1466231733048): Component "server:userfs" finished initialization
xdk:server:[2016-06-18T06:35:33.048Z]: (1466231733048): Component "server:user-profile" starting import
xdk:server:[2016-06-18T06:35:33.051Z]: (1466231733051): Component "server:user-profile" calling init()
xdk:server:[2016-06-18T06:35:33.052Z]: (1466231733052): Component "server:user-profile" finished initialization
xdk:server:[2016-06-18T06:35:33.052Z]: (1466231733052): Component "server:ui-builder" starting import
xdk:server:[2016-06-18T06:35:33.063Z]: (1466231733063): Unexpected undefined handler detected when requiring component: server:userfs
at Object.<anonymous> (/Applications/Intel XDK.app/Contents/Resources/app.nw/components/server/ui-builder/basic_api.js:17:16248)
at Module._compile (module.js:465:26)
at Object.Module._extensions..js (module.js:483:10)
at Module.load (module.js:360:32)
at Function.Module._load (module.js:315:12)
at Module.require (module.js:370:17)
at require (module.js:389:17)
xdk:server:[2016-06-18T06:35:33.137Z]: (1466231733137): Unexpected undefined handler detected when requiring component: server:userfs
at Object.<anonymous> (/Applications/Intel XDK.app/Contents/Resources/app.nw/components/server/ui-builder/undo_database.js:17:5250)
xdk:server:[2016-06-18T06:35:33.147Z]: (1466231733147): Unexpected undefined handler detected when requiring component: server:userfs
at Object.<anonymous> (/Applications/Intel XDK.app/Contents/Resources/app.nw/components/server/ui-builder/datafeed_api.js:17:3070)
xdk:server:[2016-06-18T06:35:33.150Z]: (1466231733150): Unexpected undefined handler detected when requiring component: server:userfs
at Object.<anonymous> (/Applications/Intel XDK.app/Contents/Resources/app.nw/components/server/ui-builder/help_server.js:17:2463)
xdk:server:[2016-06-18T06:35:33.151Z]: (1466231733151): Component "server:ui-builder" calling init()
xdk:server:[2016-06-18T06:35:33.154Z]: (1466231733154): Component "server:ui-builder" finished initialization
xdk:server:[2016-06-18T06:35:33.154Z]: (1466231733154): Component "server:emulator-notification" starting import
xdk:server:[2016-06-18T06:35:33.159Z]: (1466231733159): Component "server:emulator-notification" calling init()
xdk:server:[2016-06-18T06:35:33.160Z]: (1466231733160): Component "server:emulator-notification" finished initialization
xdk:server:[2016-06-18T06:35:33.160Z]: (1466231733160): Component "server:emulator-webserver" starting import
xdk:server:[2016-06-18T06:35:33.163Z]: (1466231733163): Component "server:emulator-webserver" calling init()
xdk:server:[2016-06-18T06:35:33.164Z]: (1466231733164): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-06-18T06:35:33.164Z]: (1466231733164): Component "server:zip-util" starting import
xdk:server:[2016-06-18T06:35:33.168Z]: (1466231733168): Component "server:zip-util" calling init()
xdk:server:[2016-06-18T06:35:33.169Z]: (1466231733169): Component "server:zip-util" finished initialization
xdk:server:[2016-06-18T06:35:33.169Z]: (1466231733169): Component "server:uuid-server" starting import
xdk:server:[2016-06-18T06:35:33.173Z]: (1466231733173): Component "server:uuid-server" calling init()
xdk:server:[2016-06-18T06:35:33.173Z]: (1466231733173): Component "server:uuid-server" finished initialization
xdk:server:[2016-06-18T06:35:33.173Z]: (1466231733173): Component "server:force-download" starting import
xdk:server:[2016-06-18T06:35:33.177Z]: (1466231733177): Component "server:force-download" calling init()
xdk:server:[2016-06-18T06:35:33.177Z]: (1466231733177): Component "server:force-download" finished initialization
xdk:server:[2016-06-18T06:35:33.177Z]: (1466231733177): Component "server:updater" starting import
xdk:server:[2016-06-18T06:35:33.184Z]: (1466231733184): Component "server:updater" calling init()
server:updater:[2016-06-18T06:35:33.184Z]: (1466231733184): config.base-auto
server:updater:[2016-06-18T06:35:33.185Z]: (1466231733185): url=auto
xdk:server:[2016-06-18T06:35:33.186Z]: (1466231733186): Component "server:updater" finished initialization
xdk:server:[2016-06-18T06:35:33.186Z]: (1466231733186): Component "server:editor-node" starting import
xdk:server:[2016-06-18T06:35:33.255Z]: (1466231733255): Component "server:editor-node" calling init()
xdk:server:[2016-06-18T06:35:33.256Z]: (1466231733256): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-06-18T06:35:33.256Z]: (1466231733256): Component "server:cordova" starting import
xdk:server:[2016-06-18T06:35:33.855Z]: (1466231733855): Component "server:cordova" calling init()
xdk:server:[2016-06-18T06:35:34.075Z]: (1466231734075): Component "server:cordova" finished initialization
xdk:server:[2016-06-18T06:35:34.075Z]: (1466231734075): Component "server:api-explorer" starting import
xdk:server:[2016-06-18T06:35:34.082Z]: (1466231734082): Component "server:api-explorer" calling init()
xdk:server:[2016-06-18T06:35:34.133Z]: (1466231734133): Component "server:api-explorer" finished initialization
xdk:server:[2016-06-18T06:35:34.133Z]: (1466231734133): Component "server:plugin-listener" starting import
xdk:server:[2016-06-18T06:35:34.137Z]: (1466231734137): Component "server:plugin-listener" calling init()
xdk:server:[2016-06-18T06:35:34.138Z]: (1466231734138): Component "server:plugin-listener" finished initialization
xdk:server:[2016-06-18T06:35:34.138Z]: (1466231734138): Component "server:git-runner" starting import
xdk:server:[2016-06-18T06:35:34.142Z]: (1466231734142): Component "server:git-runner" calling init()
xdk:server:[2016-06-18T06:35:34.142Z]: (1466231734142): Component "server:git-runner" finished initialization
server:editor-node:[2016-06-18T06:35:34.144Z]: (1466231734144): Starting Brackets node process /Applications/Intel\ XDK.app/Contents/MacOS/xdk-node /Applications/Intel\ XDK.app/Contents/MacOS/node-core
server:editor-node:[2016-06-18T06:35:34.443Z]: (1466231734443): Brackets node is running on port 50242
xdk:server:[2016-06-18T06:35:34.445Z]: (1466231734445): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-06-18T06:35:34.447Z]: (1466231734447): Component "server:ui-builder" calling start()
xdk:server:[2016-06-18T06:35:34.454Z]: (1466231734454): Component "server:ui-builder" finished start()
xdk:server:[2016-06-18T06:35:34.455Z]: (1466231734455): Component "server:emulator-webserver" calling start()
xdk:server:[2016-06-18T06:35:34.455Z]: (1466231734455): Component "server:emulator-webserver" finished start()
xdk:server:[2016-06-18T06:35:34.455Z]: (1466231734455): Component "server:editor-node" calling start()
xdk:server:[2016-06-18T06:35:34.455Z]: (1466231734455): Component "server:editor-node" finished start()
xdk:server:[2016-06-18T06:35:34.460Z]: (1466231734460): Intel XDK is initialized now
xdk:server:[2016-06-18T06:35:34.460Z]: (1466231734460): Writing to the server data file
xdk:server:[2016-06-18T06:35:34.464Z]: (1466231734464): Wrote server data to "/Users/denparf/Library/Application Support/XDK/server-data.txt"
xdk:client:[2016-06-18T06:35:34.657Z]: (1466231734657): Successfully read server data file
xdk:client:[2016-06-18T06:35:35.007Z]: (1466231735007): memmrk: 18720068 35318016
xdk:client:[2016-06-18T06:35:35.339Z]: (1466231735339): Component "core:assert" starting import
xdk:client:[2016-06-18T06:35:35.340Z]: (1466231735340): Component "core:assert" finished initialization
xdk:client:[2016-06-18T06:35:35.340Z]: (1466231735340): Component "core:component-error" starting import
xdk:client:[2016-06-18T06:35:35.340Z]: (1466231735340): Component "core:component-error" finished initialization
xdk:client:[2016-06-18T06:35:35.340Z]: (1466231735340): Component "core:command-line-options" starting import
xdk:client:[2016-06-18T06:35:35.340Z]: (1466231735340): Component "core:command-line-options" finished initialization
xdk:client:[2016-06-18T06:35:35.340Z]: (1466231735340): Component "core:service-error" starting import
xdk:client:[2016-06-18T06:35:35.341Z]: (1466231735341): Component "core:service-error" finished initialization
xdk:client:[2016-06-18T06:35:35.341Z]: (1466231735341): Component "core:buffer" starting import
xdk:client:[2016-06-18T06:35:35.341Z]: (1466231735341): Component "core:buffer" finished initialization
xdk:client:[2016-06-18T06:35:35.341Z]: (1466231735341): Component "core:signaler" starting import
xdk:client:[2016-06-18T06:35:35.342Z]: (1466231735342): Component "core:signaler" finished initialization
xdk:client:[2016-06-18T06:35:35.342Z]: (1466231735342): Component "core:signaler-group" starting import
xdk:client:[2016-06-18T06:35:35.344Z]: (1466231735344): Component "core:signaler-group" finished initialization
xdk:client:[2016-06-18T06:35:35.344Z]: (1466231735344): Component "core:logger" starting import
xdk:client:[2016-06-18T06:35:35.345Z]: (1466231735345): Component "core:logger" finished initialization
xdk:client:[2016-06-18T06:35:35.345Z]: (1466231735345): Component "core:http-request" starting import
xdk:client:[2016-06-18T06:35:35.348Z]: (1466231735348): Component "core:http-request" finished initialization
xdk:client:[2016-06-18T06:35:35.348Z]: (1466231735348): Component "core:version" starting import
xdk:client:[2016-06-18T06:35:35.348Z]: (1466231735348): Component "core:version" finished initialization
xdk:client:[2016-06-18T06:35:35.348Z]: (1466231735348): Component "core:exit-notifier" starting import
xdk:client:[2016-06-18T06:35:35.348Z]: (1466231735349): Component "core:exit-notifier" finished initialization
xdk:client:[2016-06-18T06:35:35.349Z]: (1466231735349): Component "core:userfs-name-converter" starting import
xdk:client:[2016-06-18T06:35:35.350Z]: (1466231735350): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-06-18T06:35:35.350Z]: (1466231735350): Component "core:crash-handler" starting import
xdk:client:[2016-06-18T06:35:35.352Z]: (1466231735352): Component "core:crash-handler" finished initialization
xdk:client:[2016-06-18T06:35:35.352Z]: (1466231735352): Component "core:analytics" starting import
xdk:client:[2016-06-18T06:35:35.352Z]: (1466231735352): Component "core:analytics" finished initialization
xdk:client:[2016-06-18T06:35:35.352Z]: (1466231735352): Component "core:i18n-support" starting import
xdk:client:[2016-06-18T06:35:35.352Z]: (1466231735352): Component "core:i18n-support" finished initialization
xdk:client:[2016-06-18T06:35:35.352Z]: (1466231735352): Component "core:theme" starting import
xdk:client:[2016-06-18T06:35:35.353Z]: (1466231735353): Component "core:theme" finished initialization
xdk:client:[2016-06-18T06:35:35.381Z]: (1466231735381): Analytics ID: 05184999-c871-42f3-ba7b-500aa41eadc3
xdk:client:[2016-06-18T06:35:35.384Z]: (1466231735384): onExit listener 0:
at Object.exports.onExit (/Applications/Intel XDK.app/Contents/Resources/app.nw/core-modules/public/exit-notifier.js:17:2339)
at setupDefaultAnalytics (/Applications/Intel XDK.app/Contents/Resources/app.nw/core-modules/public/analytics.js:17:1438)
at /Applications/Intel XDK.app/Contents/Resources/app.nw/core-modules/public/analytics.js:17:6219
at /Applications/Intel XDK.app/Contents/Resources/app.nw/node_modules/q/q.js:1229:26
at _fulfilled (/Applications/Intel XDK.app/Contents/Resources/app.nw/node_modules/q/q.js:834:54)
at self.promiseDispatch.done (/Applications/Intel XDK.app/Contents/Resources/app.nw/node_modules/q/q.js:863:30)
at Promise.promise.promiseDispatch (/Applications/Intel XDK.app/Contents/Resources/app.nw/node_modules/q/q.js:796:13)
at /Applications/Intel XDK.app/Contents/Resources/app.nw/node_modules/q/q.js:604:44
at runSingle (/Applications/Intel XDK.app/Contents/Resources/app.nw/node_modules/q/q.js:137:13)
xdk:client:[2016-06-18T06:35:35.432Z]: (1466231735432): Component "client:app" starting import
xdk:client:[2016-06-18T06:35:35.432Z]: (1466231735432): Component "client:help-helper" starting import
xdk:client:[2016-06-18T06:35:35.432Z]: (1466231735432): Component "client:nativefs" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:document-manager" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:project-manager" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:aa-controller" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:build-validator" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:projects-renderers" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:projects-renderers-smarthome" starting import
xdk:client:[2016-06-18T06:35:35.433Z]: (1466231735433): Component "client:active-sync" starting import
xdk:client:[2016-06-18T06:35:35.434Z]: (1466231735434): Component "client:apk-installer" starting import
xdk:client:[2016-06-18T06:35:35.434Z]: (1466231735434): Component "client:appcenter-options" starting import
xdk:client:[2016-06-18T06:35:35.434Z]: (1466231735434): Component "client:resource-manager" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:resource-cocos2d" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:resource-phaser" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:resource-pixi" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:resource-easeljs" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:resource-plain" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:resource-render-frame" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:resource-util" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:bower-package-manager" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:services-tab" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:editor" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:live-preview" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:backend-services" starting import
xdk:client:[2016-06-18T06:35:35.435Z]: (1466231735435): Component "client:backend-feeds" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:merged-feed" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:backend-services-ext" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:backend-service-utils" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:cert-manager" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:account-settings" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:ui-builder-client" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:project-meta" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:contenttype-registry" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:editor-registry" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:platform-registry" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:projecttype-registry" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:library-registry" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:cordova-registry" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:service-method" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:settings-db" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:adb" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:iosdb" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:device" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:device-discovery" starting import
xdk:client:[2016-06-18T06:35:35.436Z]: (1466231735436): Component "client:dialog-box" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:test-local-server" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:quick-tour" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:hot-keys" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:persistance" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:tabs" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:hash-utils" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:file-watcher" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:tool-tip" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:cordova" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:settings-ui" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:external-links" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:external-editors-runner" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:project-list-load" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:upload-manager" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:git-manager" starting import
xdk:client:[2016-06-18T06:35:35.437Z]: (1466231735437): Component "client:new-project-creator" starting import
xdk:client:[2016-06-18T06:35:35.511Z]: (1466231735511): Component "client:help-helper" finished initialization
xdk:client:[2016-06-18T06:35:35.512Z]: (1466231735512): Component "client:nativefs" finished initialization
xdk:client:[2016-06-18T06:35:35.539Z]: (1466231735539): Component "client:active-sync" calling init()
xdk:client:[2016-06-18T06:35:35.539Z]: (1466231735539): Component "client:active-sync" finished initialization
xdk:client:[2016-06-18T06:35:35.544Z]: (1466231735544): Component "client:apk-installer" calling init()
xdk:client:[2016-06-18T06:35:35.544Z]: (1466231735544): Component "client:apk-installer" finished initialization
xdk:client:[2016-06-18T06:35:35.565Z]: (1466231735565): Component "client:resource-render-frame" calling init()
xdk:client:[2016-06-18T06:35:35.566Z]: (1466231735566): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:35.567Z]: (1466231735567): Component "client:resource-util" calling init()
xdk:client:[2016-06-18T06:35:35.567Z]: (1466231735567): Component "client:resource-util" finished initialization
xdk:client:[2016-06-18T06:35:35.577Z]: (1466231735577): Component "client:backend-services" calling init()
xdk:client:[2016-06-18T06:35:35.579Z]: (1466231735579): Component "client:backend-services" finished initialization
xdk:client:[2016-06-18T06:35:35.580Z]: (1466231735580): Component "client:backend-feeds" calling init()
xdk:client:[2016-06-18T06:35:35.581Z]: (1466231735581): Component "client:backend-feeds" finished initialization
xdk:client:[2016-06-18T06:35:35.581Z]: (1466231735581): Component "client:backend-services-ext" calling init()
xdk:client:[2016-06-18T06:35:35.582Z]: (1466231735582): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-06-18T06:35:35.584Z]: (1466231735584): Component "client:merged-feed" finished initialization
xdk:client:[2016-06-18T06:35:35.585Z]: (1466231735585): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-06-18T06:35:35.593Z]: (1466231735593): Component "client:project-meta" calling init()
xdk:client:[2016-06-18T06:35:35.593Z]: (1466231735593): Component "client:project-meta" finished initialization
xdk:client:[2016-06-18T06:35:35.605Z]: (1466231735605): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-06-18T06:35:35.620Z]: (1466231735620): Component "client:build-validator" finished initialization
xdk:client:[2016-06-18T06:35:35.643Z]: (1466231735643): Component "client:service-method" finished initialization
xdk:client:[2016-06-18T06:35:35.645Z]: (1466231735645): Component "client:settings-db" calling init()
xdk:client:[2016-06-18T06:35:35.645Z]: (1466231735645): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:35.646Z]: (1466231735646): Component "client:adb" calling init()
xdk:client:[2016-06-18T06:35:35.652Z]: (1466231735652): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:35.654Z]: (1466231735654): Component "client:iosdb" calling init()
xdk:client:[2016-06-18T06:35:35.655Z]: (1466231735655): Component "client:iosdb" finished initialization
xdk:client:[2016-06-18T06:35:35.663Z]: (1466231735663): Component "client:persistance" calling init()
xdk:client:[2016-06-18T06:35:35.663Z]: (1466231735663): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:35.668Z]: (1466231735668): Component "client:file-watcher" calling init()
xdk:client:[2016-06-18T06:35:35.668Z]: (1466231735668): Component "client:file-watcher" finished initialization
xdk:client:[2016-06-18T06:35:35.671Z]: (1466231735671): Component "client:external-links" finished initialization
xdk:client:[2016-06-18T06:35:35.673Z]: (1466231735673): Component "client:external-editors-runner" calling init()
xdk:client:[2016-06-18T06:35:35.674Z]: (1466231735674): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-06-18T06:35:35.675Z]: (1466231735675): Component "client:project-list-load" calling init()
xdk:client:[2016-06-18T06:35:35.675Z]: (1466231735675): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:35.682Z]: (1466231735682): Component "client:upload-manager" calling init()
xdk:client:[2016-06-18T06:35:35.682Z]: (1466231735682): Component "client:upload-manager" finished initialization
xdk:client:[2016-06-18T06:35:35.684Z]: (1466231735684): Component "client:git-manager" calling init()
client:git-manager:[2016-06-18T06:35:35.685Z]: (1466231735685): git path = /Applications/Intel XDK.app/Contents/MacOS/git/bin/git
xdk:client:[2016-06-18T06:35:35.685Z]: (1466231735685): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:35.688Z]: (1466231735688): Component "client:new-project-creator" calling init()
xdk:client:[2016-06-18T06:35:35.688Z]: (1466231735688): Component "client:new-project-creator" finished initialization
xdk:client:[2016-06-18T06:35:35.701Z]: (1466231735701): Component "client:ui-builder-client" calling init()
xdk:client:[2016-06-18T06:35:35.701Z]: (1466231735701): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-06-18T06:35:35.704Z]: (1466231735704): Component "client:hot-keys" calling init()
xdk:client:[2016-06-18T06:35:35.704Z]: (1466231735704): Component "client:hot-keys" finished initialization
xdk:client:[2016-06-18T06:35:35.708Z]: (1466231735708): Component "client:document-manager" calling init()
xdk:client:[2016-06-18T06:35:35.708Z]: (1466231735708): Component "client:document-manager" finished initialization
xdk:client:[2016-06-18T06:35:35.718Z]: (1466231735718): Component "client:aa-controller" calling init()
xdk:client:[2016-06-18T06:35:35.718Z]: (1466231735718): Component "client:aa-controller" finished initialization
xdk:client:[2016-06-18T06:35:35.837Z]: (1466231735837): Component "client:contenttype-registry" calling init()
xdk:client:[2016-06-18T06:35:35.839Z]: (1466231735839): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-06-18T06:35:35.841Z]: (1466231735841): Component "client:editor-registry" finished initialization
xdk:client:[2016-06-18T06:35:35.859Z]: (1466231735859): Component "client:dialog-box" finished initialization
xdk:client:[2016-06-18T06:35:35.865Z]: (1466231735865): Component "client:tool-tip" finished initialization
xdk:client:[2016-06-18T06:35:35.869Z]: (1466231735869): Component "client:settings-ui" finished initialization
xdk:client:[2016-06-18T06:35:35.907Z]: (1466231735907): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-06-18T06:35:35.908Z]: (1466231735908): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-06-18T06:35:35.912Z]: (1466231735912): Component "client:resource-phaser" calling init()
xdk:client:[2016-06-18T06:35:35.912Z]: (1466231735912): Component "client:resource-phaser" finished initialization
xdk:client:[2016-06-18T06:35:35.916Z]: (1466231735916): Component "client:resource-pixi" calling init()
xdk:client:[2016-06-18T06:35:35.916Z]: (1466231735916): Component "client:resource-pixi" finished initialization
xdk:client:[2016-06-18T06:35:35.918Z]: (1466231735918): Component "client:resource-easeljs" calling init()
xdk:client:[2016-06-18T06:35:35.918Z]: (1466231735918): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-06-18T06:35:35.929Z]: (1466231735929): Component "client:resource-manager" calling init()
xdk:client:[2016-06-18T06:35:35.930Z]: (1466231735930): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:35.933Z]: (1466231735933): Component "client:resource-plain" calling init()
xdk:client:[2016-06-18T06:35:35.934Z]: (1466231735934): Component "client:resource-plain" finished initialization
xdk:client:[2016-06-18T06:35:35.956Z]: (1466231735956): Component "client:appcenter-options" calling init()
xdk:client:[2016-06-18T06:35:35.957Z]: (1466231735957): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:35.958Z]: (1466231735958): Component "client:services-tab" calling init()
xdk:client:[2016-06-18T06:35:35.959Z]: (1466231735959): Component "client:services-tab" finished initialization
xdk:client:[2016-06-18T06:35:35.961Z]: (1466231735961): Component "client:test-local-server" calling init()
xdk:client:[2016-06-18T06:35:35.989Z]: (1466231735989): Component "client:test-local-server" finished initialization
xdk:client:[2016-06-18T06:35:35.990Z]: (1466231735990): Component "client:tabs" finished initialization
xdk:client:[2016-06-18T06:35:35.999Z]: (1466231735999): Component "client:app" calling init()
xdk:client:[2016-06-18T06:35:36.016Z]: (1466231736016): Component "client:app" finished initialization
xdk:client:[2016-06-18T06:35:36.103Z]: (1466231736103): Component "client:cert-manager" finished initialization
xdk:client:[2016-06-18T06:35:36.107Z]: (1466231736107): Component "client:library-registry" calling init()
xdk:client:[2016-06-18T06:35:36.107Z]: (1466231736107): Component "client:library-registry" finished initialization
xdk:client:[2016-06-18T06:35:36.115Z]: (1466231736115): Component "client:device-discovery" calling init()
xdk:client:[2016-06-18T06:35:36.115Z]: (1466231736115): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.117Z]: (1466231736117): Component "client:hash-utils" finished initialization
xdk:client:[2016-06-18T06:35:36.187Z]: (1466231736187): Component "client:cordova" calling init()
xdk:client:[2016-06-18T06:35:36.187Z]: (1466231736187): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.205Z]: (1466231736205): Component "client:projects-renderers" calling init()
xdk:client:[2016-06-18T06:35:36.205Z]: (1466231736205): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.206Z]: (1466231736206): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-06-18T06:35:36.206Z]: (1466231736206): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-06-18T06:35:36.207Z]: (1466231736207): Component "client:projects-renderers-smarthome" calling init()
xdk:client:[2016-06-18T06:35:36.207Z]: (1466231736207): Component "client:projects-renderers-smarthome" finished initialization
xdk:client:[2016-06-18T06:35:36.237Z]: (1466231736237): Component "client:project-manager" calling init()
xdk:client:[2016-06-18T06:35:36.239Z]: (1466231736239): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.246Z]: (1466231736246): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-06-18T06:35:36.246Z]: (1466231736246): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.251Z]: (1466231736251): Component "client:navbar" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:tweets" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:projects-tab" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:test-tab" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:profilingTab" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:emulator" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:remote-tab" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:build-tab" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:build-service" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:bower-client" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:editor-tab" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:account" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:project-selector" starting import
xdk:client:[2016-06-18T06:35:36.252Z]: (1466231736252): Component "client:publish-tab" starting import
xdk:client:[2016-06-18T06:35:36.260Z]: (1466231736260): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-06-18T06:35:36.278Z]: (1466231736278): Component "client:cordova-registry" calling init()
xdk:client:[2016-06-18T06:35:36.279Z]: (1466231736279): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.316Z]: (1466231736316): Component "client:account-settings" calling init()
xdk:client:[2016-06-18T06:35:36.316Z]: (1466231736316): Component "client:account-settings" finished initialization
xdk:client:[2016-06-18T06:35:36.322Z]: (1466231736322): Component "client:quick-tour" calling init()
xdk:client:[2016-06-18T06:35:36.323Z]: (1466231736323): Component "client:quick-tour" finished initialization
xdk:client:[2016-06-18T06:35:36.327Z]: (1466231736327): Component "client:platform-registry" calling init()
xdk:client:[2016-06-18T06:35:36.328Z]: (1466231736328): Component "client:platform-registry" finished initialization
xdk:client:[2016-06-18T06:35:36.331Z]: (1466231736331): Component "client:projecttype-registry" calling init()
xdk:client:[2016-06-18T06:35:36.331Z]: (1466231736331): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-06-18T06:35:36.338Z]: (1466231736338): Component "client:device" calling init()
xdk:client:[2016-06-18T06:35:36.420Z]: (1466231736420): Component "client:device" finished initialization
xdk:client:[2016-06-18T06:35:36.427Z]: (1466231736427): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-06-18T06:35:36.434Z]: (1466231736434): Component "client:bower-package-manager" calling init()
xdk:client:[2016-06-18T06:35:36.435Z]: (1466231736435): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.483Z]: (1466231736483): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-06-18T06:35:36.484Z]: (1466231736484): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-06-18T06:35:36.491Z]: (1466231736491): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-06-18T06:35:36.491Z]: (1466231736491): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-06-18T06:35:36.512Z]: (1466231736512): Component "client:build-service" getting UI region for "build"
xdk:client:[2016-06-18T06:35:36.512Z]: (1466231736512): Component "client:build-service" calling init()
xdk:client:[2016-06-18T06:35:36.512Z]: (1466231736513): Component "client:build-service" finished initialization
xdk:client:[2016-06-18T06:35:36.547Z]: (1466231736547): Unexpected undefined handler detected when requiring component: client:projects-renderers-idrapp
at file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/components/client/projects-tab/projects-renderers.js:21:881
at flush (/Applications/Intel XDK.app/Contents/Resources/app.nw/node_modules/q/q.js:125:13)
xdk:client:[2016-06-18T06:35:36.548Z]: (1466231736548): Unexpected undefined handler detected when requiring component: client:projects-renderers-ebook
xdk:client:[2016-06-18T06:35:36.548Z]: (1466231736548): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-06-18T06:35:36.549Z]: (1466231736549): Component "client:settings-db" finished delayed initialization
client:git-manager:[2016-06-18T06:35:36.601Z]: (1466231736601): Custom Git Client Path is /Applications/Intel XDK.app/Contents/MacOS/git/bin/git
client:git-manager:[2016-06-18T06:35:36.601Z]: (1466231736602): Auto-Proxy setting is true
xdk:client:[2016-06-18T06:35:36.603Z]: (1466231736603): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2016-06-18T06:35:36.655Z]: (1466231736655): Component "client:account" getting UI region for "account"
xdk:client:[2016-06-18T06:35:36.655Z]: (1466231736655): Component "client:account" calling init()
xdk:client:[2016-06-18T06:35:36.662Z]: (1466231736662): Component "client:account" finished initialization
xdk:client:[2016-06-18T06:35:36.665Z]: (1466231736665): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-06-18T06:35:36.665Z]: (1466231736665): Component "client:project-selector" calling init()
xdk:client:[2016-06-18T06:35:36.665Z]: (1466231736665): Component "client:project-selector" finished initialization
xdk:client:[2016-06-18T06:35:36.685Z]: (1466231736685): Component "client:editor" calling init()
xdk:client:[2016-06-18T06:35:36.685Z]: (1466231736685): Component "client:editor" finished initialization
xdk:client:[2016-06-18T06:35:36.686Z]: (1466231736686): Component "client:live-preview" calling init()
xdk:client:[2016-06-18T06:35:36.686Z]: (1466231736686): Component "client:live-preview" finished initialization
xdk:client:[2016-06-18T06:35:36.686Z]: (1466231736686): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-06-18T06:35:36.687Z]: (1466231736687): Component "client:editor-tab" calling init()
xdk:client:[2016-06-18T06:35:36.702Z]: (1466231736702): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.715Z]: (1466231736716): Component "client:tweets" finished initialization
xdk:client:[2016-06-18T06:35:36.718Z]: (1466231736718): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-06-18T06:35:36.718Z]: (1466231736718): Component "client:projects-tab" calling init()
xdk:client:[2016-06-18T06:35:36.719Z]: (1466231736719): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.723Z]: (1466231736723): Unexpected undefined handler detected when requiring component: client:backend-service-utils
at file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/components/client/test-tab/test-tab.js:17:14299
at Object.context.execCb (file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/public/external/js/require-jquery.js:1615:33)
at Object.Module.check (file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/public/external/js/require-jquery.js:851:51)
at Object.<anonymous> (file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/public/external/js/require-jquery.js:1092:34)
at file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/public/external/js/require-jquery.js:129:23
at file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/public/external/js/require-jquery.js:1135:21
at each (file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/public/external/js/require-jquery.js:57:31)
xdk:client:[2016-06-18T06:35:36.723Z]: (1466231736723): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-06-18T06:35:36.723Z]: (1466231736723): Component "client:test-tab" calling init()
xdk:client:[2016-06-18T06:35:36.724Z]: (1466231736724): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.745Z]: (1466231736745): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-06-18T06:35:36.745Z]: (1466231736745): Component "client:emulator" calling init()
xdk:client:[2016-06-18T06:35:36.748Z]: (1466231736748): Component "client:emulator" finished initialization
xdk:client:[2016-06-18T06:35:36.783Z]: (1466231736783): Component "client:remote-tab" getting UI region for "debug"
xdk:server:[2016-06-18T06:35:36.850Z]: (1466231736850): memmrk: 30322180 43419136
xdk:client:[2016-06-18T06:35:36.783Z]: (1466231736783): Component "client:remote-tab" calling init()
xdk:client:[2016-06-18T06:35:36.863Z]: (1466231736863): Unexpected undefined handler detected when requiring component: server:proxy
at Object.myExports.init (file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/components/client/remote-tab/remote-tab.js:19:30604)
at /Applications/Intel XDK.app/Contents/Resources/app.nw/core-modules/private/main.js:17:9073
xdk:client:[2016-06-18T06:35:36.924Z]: (1466231736924): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:36.925Z]: (1466231736925): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-06-18T06:35:36.942Z]: (1466231736942): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-06-18T06:35:36.942Z]: (1466231736942): Component "client:navbar" calling init()
client:navbar:[2016-06-18T06:35:36.943Z]: (1466231736943): navbar options: {"common":{"servicesVersion":"release-2016-ww19"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-06-18T06:35:36.943Z]: (1466231736943): Component "client:navbar" finished initialization
xdk:client:[2016-06-18T06:35:36.943Z]: (1466231736943): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-06-18T06:35:37.022Z]: (1466231737022): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2016-06-18T06:35:37.022Z]: (1466231737022): Component "client:publish-tab" calling init()
xdk:client:[2016-06-18T06:35:37.032Z]: (1466231737032): Component "client:publish-tab" finished initialization
xdk:client:[2016-06-18T06:35:37.039Z]: (1466231737039): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-06-18T06:35:37.039Z]: (1466231737039): Component "client:build-tab" calling init()
xdk:client:[2016-06-18T06:35:37.046Z]: (1466231737046): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2016-06-18T06:35:37.047Z]: (1466231737047): Component "client:build-tab" finished delayed initialization
xdk:client:[2016-06-18T06:35:37.066Z]: (1466231737066): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-06-18T06:35:37.066Z]: (1466231737066): Component "client:bower-client" calling init()
xdk:client:[2016-06-18T06:35:37.068Z]: (1466231737068): Component "client:bower-client" finished initialization
xdk:client:[2016-06-18T06:35:37.069Z]: (1466231737069): Component "client:cordova" finished delayed initialization
xdk:client:[2016-06-18T06:35:37.143Z]: (1466231737143): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-06-18T06:35:37.143Z]: (1466231737143): Component "client:profilingTab" calling init()
xdk:client:[2016-06-18T06:35:37.146Z]: (1466231737146): Component "client:profilingTab" finished initialization
client:appcenter-options:[2016-06-18T06:35:38.062Z]: (1466231738062): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2016-06-18T06:35:38.063Z]: (1466231738063): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-06-18T06:35:38.066Z]: (1466231738066): Component "client:test-tab" finished delayed initialization
xdk:client:[2016-06-18T06:35:38.692Z]: (1466231738693): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2016-06-18T06:35:39.179Z]: (1466231739179): Component "client:persistance" finished delayed initialization
xdk:client:[2016-06-18T06:35:39.431Z]: (1466231739431): Component "client:project-manager" finished delayed initialization
xdk:client:[2016-06-18T06:35:39.433Z]: (1466231739433): Component "client:project-list-load" finished delayed initialization
xdk:client:[2016-06-18T06:35:39.440Z]: (1466231739440): Component "client:resource-manager" finished delayed initialization
xdk:client:[2016-06-18T06:35:39.440Z]: (1466231739440): Component "client:projects-tab" finished delayed initialization
xdk:client:[2016-06-18T06:35:39.441Z]: (1466231739441): Component "client:projects-list" starting import
xdk:client:[2016-06-18T06:35:39.441Z]: (1466231739441): Component "client:projects-info" starting import
xdk:client:[2016-06-18T06:35:39.441Z]: (1466231739441): Component "client:projects-create-list" starting import
xdk:client:[2016-06-18T06:35:39.441Z]: (1466231739441): Component "client:projects-create-info" starting import
xdk:client:[2016-06-18T06:35:39.461Z]: (1466231739461): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2016-06-18T06:35:39.462Z]: (1466231739462): Component "client:projects-list" calling init()
xdk:client:[2016-06-18T06:35:39.463Z]: (1466231739464): Component "client:projects-list" finished initialization
xdk:client:[2016-06-18T06:35:39.467Z]: (1466231739467): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2016-06-18T06:35:39.467Z]: (1466231739467): Component "client:projects-info" calling init()
xdk:client:[2016-06-18T06:35:39.468Z]: (1466231739468): Component "client:projects-info" finished initialization
xdk:client:[2016-06-18T06:35:39.481Z]: (1466231739481): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2016-06-18T06:35:39.481Z]: (1466231739481): Component "client:projects-create-info" calling init()
xdk:client:[2016-06-18T06:35:39.481Z]: (1466231739481): Component "client:projects-create-info" finished initialization
xdk:client:[2016-06-18T06:35:39.487Z]: (1466231739487): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2016-06-18T06:35:39.487Z]: (1466231739487): Component "client:projects-create-list" calling init()
xdk:client:[2016-06-18T06:35:39.487Z]: (1466231739487): Component "client:projects-create-list" finished initialization
xdk:client:[2016-06-18T06:35:40.008Z]: (1466231740008): memmrk: 34378548 52617856
xdk:server:[2016-06-18T06:35:41.851Z]: (1466231741851): memmrk: 30949292 43419136
xdk:client:[2016-06-18T06:35:45.009Z]: (1466231745009): memmrk: 34381904 52617856
xdk:server:[2016-06-18T06:35:46.853Z]: (1466231746853): memmrk: 20316196 43419136
xdk:client:[2016-06-18T06:35:50.011Z]: (1466231750011): memmrk: 34384356 52617856
xdk:server:[2016-06-18T06:35:51.854Z]: (1466231751854): memmrk: 19616172 28718336
xdk:client:[2016-06-18T06:35:55.012Z]: (1466231755012): memmrk: 34386792 52617856
xdk:server:[2016-06-18T06:35:56.855Z]: (1466231756855): memmrk: 19646180 28718336
xdk:client:[2016-06-18T06:36:00.013Z]: (1466231760013): memmrk: 34389228 52617856
xdk:server:[2016-06-18T06:36:01.856Z]: (1466231761856): memmrk: 18692224 26699136
xdk:client:[2016-06-18T06:36:05.014Z]: (1466231765014): memmrk: 34628248 52617856
xdk:server:[2016-06-18T06:36:06.857Z]: (1466231766858): memmrk: 17472800 24679936
xdk:client:[2016-06-18T06:36:10.015Z]: (1466231770015): memmrk: 34634024 52617856
xdk:server:[2016-06-18T06:36:11.859Z]: (1466231771859): memmrk: 17666524 24679936
xdk:client:[2016-06-18T06:36:15.015Z]: (1466231775015): memmrk: 34638164 52617856
xdk:server:[2016-06-18T06:36:16.861Z]: (1466231776861): memmrk: 17268744 24679936
xdk:client:[2016-06-18T06:36:20.017Z]: (1466231780017): memmrk: 28557448 53633536
xdk:server:[2016-06-18T06:36:21.863Z]: (1466231781863): memmrk: 17142116 24712832
xdk:client:[2016-06-18T06:36:25.017Z]: (1466231785017): memmrk: 28561304 53633536
xdk:server:[2016-06-18T06:36:26.863Z]: (1466231786863): memmrk: 16666316 23709312
xdk:client:[2016-06-18T06:36:30.019Z]: (1466231790019): memmrk: 26491624 34870016
xdk:server:[2016-06-18T06:36:31.865Z]: (1466231791865): memmrk: 16680252 23709312
xdk:client:[2016-06-18T06:36:35.020Z]: (1466231795020): memmrk: 26494152 34870016
xdk:server:[2016-06-18T06:36:36.866Z]: (1466231796866): memmrk: 16687356 23709312
xdk:client:[2016-06-18T06:36:40.022Z]: (1466231800022): memmrk: 25533136 34870016
xdk:server:[2016-06-18T06:36:41.868Z]: (1466231801868): memmrk: 16695408 23709312
xdk:client:[2016-06-18T06:36:45.023Z]: (1466231805023): memmrk: 25535688 34870016
xdk:server:[2016-06-18T06:36:46.869Z]: (1466231806869): memmrk: 16702512 23709312
xdk:client:[2016-06-18T06:36:50.024Z]: (1466231810024): memmrk: 22416708 30831616
xdk:server:[2016-06-18T06:36:51.870Z]: (1466231811871): memmrk: 16709616 23709312
xdk:client:[2016-06-18T06:36:55.025Z]: (1466231815025): memmrk: 22398404 29828096
xdk:server:[2016-06-18T06:36:56.872Z]: (1466231816872): memmrk: 16716704 23709312
xdk:client:[2016-06-18T06:37:00.026Z]: (1466231820026): memmrk: 22501756 30876672
xdk:server:[2016-06-18T06:37:01.873Z]: (1466231821873): memmrk: 16735644 23709312
xdk:client:[2016-06-18T06:37:05.028Z]: (1466231825028): memmrk: 21947836 30876672
xdk:server:[2016-06-18T06:37:06.874Z]: (1466231826874): memmrk: 16743800 23709312
xdk:client:[2016-06-18T06:37:10.029Z]: (1466231830029): memmrk: 21950364 30876672
xdk:server:[2016-06-18T06:37:11.876Z]: (1466231831876): memmrk: 16752404 23709312
xdk:client:[2016-06-18T06:37:15.030Z]: (1466231835031): memmrk: 21952824 30876672
xdk:server:[2016-06-18T06:37:16.878Z]: (1466231836878): memmrk: 16761124 23709312
xdk:client:[2016-06-18T06:37:20.032Z]: (1466231840032): memmrk: 21955284 30876672
xdk:server:[2016-06-18T06:37:21.879Z]: (1466231841879): memmrk: 16767956 23709312
xdk:client:[2016-06-18T06:37:25.033Z]: (1466231845033): memmrk: 21957744 30876672
xdk:server:[2016-06-18T06:37:26.880Z]: (1466231846880): memmrk: 16774856 23709312
xdk:client:[2016-06-18T06:37:30.035Z]: (1466231850035): memmrk: 21960204 30876672
xdk:server:[2016-06-18T06:37:31.882Z]: (1466231851882): memmrk: 16784692 23709312
xdk:client:[2016-06-18T06:37:35.035Z]: (1466231855035): memmrk: 21962648 30876672
xdk:client:[2016-06-18T06:37:35.664Z]: (1466231855664): Unexpected exception during whenInitialized() for "adb": Error: Component initialization timed out: "client:adb"
at file:///Applications/Intel%20XDK.app/Contents/Resources/app.nw/node_modules/q/q.js:1821:21
xdk:client:[2016-06-18T06:37:35.666Z]: (1466231855666): Unexpected exception while initializing "editor-tab" (maybe crash): Error: Component initialization timed out: "client:adb"
xdk:client:[2016-06-18T06:37:35.667Z]: (1466231855667): Unexpected exception while initializing "adb" (maybe crash): Error: Component initialization timed out: "client:adb"
xdk:client:[2016-06-18T06:37:35.667Z]: (1466231855667): Error in common initialization
[Log closed from xdk:client]
xdk:server:[2016-06-18T06:37:36.883Z]: (1466231856883): memmrk: 16791576 23709312
xdk:server:[2016-06-18T06:37:41.884Z]: (1466231861884): memmrk: 16798460 23709312
xdk:server:[2016-06-18T06:37:46.885Z]: (1466231866885): memmrk: 16807876 23709312
xdk:server:[2016-06-18T06:37:51.886Z]: (1466231871886): memmrk: 16814820 23709312
xdk:server:[2016-06-18T06:37:56.888Z]: (1466231876888): memmrk: 16821764 23709312
xdk:server:[2016-06-18T06:38:01.888Z]: (1466231881888): memmrk: 16828708 23709312
xdk:server:[2016-06-18T06:38:06.890Z]: (1466231886890): memmrk: 16835668 23709312
xdk:server:[2016-06-18T06:38:11.891Z]: (1466231891891): memmrk: 16842628 23709312
xdk:server:[2016-06-18T06:38:16.893Z]: (1466231896893): memmrk: 16851880 23709312
xdk:server:[2016-06-18T06:38:21.895Z]: (1466231901895): memmrk: 16860068 23709312
- Balises:
- HTML5
- Intel® XDK
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Denis - which OS are you using?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Denis - do you have anti-virus software? See https://software.intel.com/en-us/forums/intel-xdk/topic/607493
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Pamela, I'm using MacOS and I dont have any anti-virus software. it worked perfectly last 6 months, but that morning its behavior has completely changed.
Best,
Denis
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Denis,
I've just communicated with some developers. The issue is the client.adb error. Thank you for the log, it is very helpful. I will post here as I get more information.
Pamela
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Denis,
Pamela
Hello Pamela,
Any updates?
Best,
Denis
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
They are working on a resolution, but unfortunately, it's not something we can fix without a new release of XDK.
However, others who have experienced the problem eventually get it to work. In fact I tried upgrading to 3400 yesterday and experienced the same issue. After failing to install twice from the XDK install method. I went to xdk.intel.com, downloaded a fresh copy of the installation executable and installed, then it worked.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
