Software Archive
Read-only legacy content
17060 Discussions
Time Drift and using NTP for syncing your system clock (including VMs)
Steven_T_Intel
Time Drift
Time drift is when a VM loses ticks and its system clock then becomes inaccurate. This phenomena has been well documented on the Web.
Using NTP for synchronizing the system clock
Overhead in using NTP
The observed overhead appears to be less than 1%. On Windows 2003, which uses SNTP (Simple Network Time Protocol), there are 2 UDP packets received and 1 UDP packet sent by the system under test. On SLES 9 SP1, which uses NTP, there is 4 TCP packets received and 1 TCP packet sent. On a lightly loaded system, updating every 10 minutes is sufficient. On a heavily loaded system, it is recommended to update every 5 minutes. I have set updates to occur every minute, without a significant load added to the system.
Windows 2003
There are just a few steps necessary to have your Windows 2003 system synchronizing with your NTP server, even from within a Virtual Machine.
Specifying your Internet Time Server
Right click on your time display. Click on the Adjust/Time selection. Click on the Internet Time tab. Enter the IP address or Name of the NTP server you wish to synchronize with.
Creating a Scheduled Task to synchronize your system
Create a batch file
You will need to create a batch file for your scheduled task to execute. The batch file needs only one line:
w32tm /resync
Create the Scheduled task
Go to C:WindowsTasks folder. You will see an entry to Add a scheduled task. Click on it to bring up the wizard. Browse to specify your newly created batch file as the executable for the new task. Specify daily execution. After you have created the task, use the advanced features to execute it every 10 minutes or 5 minutes as necessary.
SLES 9 SP1
There are just a few steps necessary to have your LINUX system synchronizing with your NTP server, even from within a Virtual Machine.
Edit the file /etc/ntp.conf. Specify your server by adding a line like:
Server 192.168.1.63
Creating a cron entry to synchronize your system
Create a shell script
Create a bash shell script with the lines:
#! /bin/bash
/etc/init.d/xntpd restart 2>&1 > /dev/null
Modify crontab
Edit /etc/crontab to add an entry for your newly created shell script. It would look like (to execute every 5 minutes):
0,5,10,15,20,25,30,35,40,45,50,55 * * * root /root/myNewScript
Steven_T_Intel
I found the following on the Novell site about SLES 10 SP1, which is similar to this post.
https://secure-support.novell.com/KanisaPlatform/Publishing/510/3858673_f.SAL_Public.html
