Software Archive
Read-only legacy content
Touchless controller configuration settings
HexLord
In the touchless controller sample , the following code is presented incorrectly.
Can anyone tell me the correct syntax.
PXCMTouchlessController.ProfileInfo pinfo;
tc.QueryProfile(out pinfo);
pinfo.config= [PXCMTouchlessController.ProfileInfo.Configuration.AllowZoom, PXCMTouchlessController.ProfileInfo.Configuration.Configuration_Scroll_Horizontally];
tc.SetProfile(pinfo);
Shaleen
Dagan_E_Intel
Hi Shaleen,
did you have a look at the toucless control sample in C#?
RSSDK\framework\CSharp\touchless_listbox_sample.cs
there's a simple example for that
I think this should work for multiple values:
            pInfo.config = PXCMTouchlessController.ProfileInfo.Configuration.Configuration_Scroll_Vertically | PXCMTouchlessController.ProfileInfo.Configuration.Configuration_Allow_Zoom;
HexLord
hi Dagan,
Thanks for the reply. It worked.
But I am not able get the cursor to follow the hand. Here's the code. Please let me know what is missed out.
 // Create a SenseManager instance.
            PXCMSenseManager sm = PXCMSenseManager.CreateInstance();
            // Enable the touchless controller feature.
            sm.EnableTouchlessController();
            // Initialize the pipeline
            sm.Init();
            // Get the module instance
            PXCMTouchlessController tc = sm.QueryTouchlessController();
            pinfo.config = pinfo.config = PXCMTouchlessController.ProfileInfo.Configuration.Configuration_Scroll_Vertically | PXCMTouchlessController.ProfileInfo.Configuration.Configuration_Allow_Zoom | PXCMTouchlessController.ProfileInfo.Configuration.Configuration_Enable_Injection ;
            // register for the ux events
            // tc.SubscribeEvent(OnFiredUXEvent);
            tc.SubscribeEvent(UXEvent_CursorVisible);
            tc.SubscribeEvent(UXEvent_CursorMove);
            // Streaming data
            while (sm.AcquireFrame(true) >= pxcmStatus.PXCM_STATUS_NO_ERROR)
                sm.ReleaseFrame();
            // Clean up
            sm.Dispose();
        private void UXEvent_CursorMove(PXCMTouchlessController.UXEventData data)
            Point point = new Point();
            point.X =(int) Math.Max(Math.Min(0.9F, data.position.x), 0.1F);
            point.Y =(int) Math.Max(Math.Min(0.9F, data.position.y), 0.1F);
        private void UXEvent_CursorVisible(PXCMTouchlessController.UXEventData data)
            textBox1.AppendText(data.bodySide.ToString());
        void OnFiredUXEvent(PXCMTouchlessController.UXEventData uxEventData) {
          //  textBox1.AppendText("UX Event");
