Software Archive
Read-only legacy content
17060 Discussions
Track multiple properties (ex. track objects and faces)?
Dirk_R_
Is it possible to track multiple properties?
For example track objects and faces at the same time?
While tracking objects I want to count how many persons are sitting in front of the computer.
I get the object tracking working, but not the face tracking.
The trackes faces are always 0.
I've tried something like this.
        public void EnableTracker()
	   // Object tracking works anly with this resolution
            _senseManager.captureManager.FilterByStreamProfiles(PXCMCapture.StreamType.STREAM_TYPE_COLOR, 640, 480, 30);
            // Enable object tracking
            _senseManager.EnableTracker();
            // Enable face tracking
            _senseManager.EnableFace();
            PXCMTracker objectTracker = _senseManager.QueryTracker();
            PXCMFaceModule faceTracker = _senseManager.QueryFace();
            var handler = new PXCMSenseManager.Handler
                onModuleProcessedFrame = OnModuleProcessedFrame
            if (_senseManager.Init(handler) >= pxcmStatus.PXCM_STATUS_NO_ERROR)
                pxcmStatus objectTrackingstatus = Set2DTrackFromFiles(_fileNames, objectTracker);
                pxcmStatus faceTrackingStatus = ConfigureFace(faceTracker);
                if ((objectTrackingstatus < pxcmStatus.PXCM_STATUS_NO_ERROR) &&
		(faceTrackingStatus < pxcmStatus.PXCM_STATUS_NO_ERROR))
                    _senseManager.Close();
                    _senseManager.Dispose();
                    return;
                _senseManager.StreamFrames(true);
         private pxcmStatus OnModuleProcessedFrame(int mid, PXCMBase module, PXCMCapture.Sample sample)
            // check if the callback is from the object tracking module.
            if ((mid == PXCMTracker.CUID) && !Stop)
                var tracker = module.QueryInstance<PXCMTracker>();
            else if ((mid == PXCMFaceModule.CUID) && !Stop)
                PXCMFaceModule face = (PXCMFaceModule)module.QueryInstance(PXCMFaceModule.CUID);
                PXCMFaceData fdata = face.CreateOutput();
                Int32 nfaces = fdata.QueryNumberOfDetectedFaces();
//Always = 0
            // return NO_ERROR to continue, or any error to abort.
            return pxcmStatus.PXCM_STATUS_NO_ERROR;
Dirk_R_
Dirk R. wrote:
I've found the solution. It's working now.
I have to add one line *fdata.Update();*
                    return;
		fdata.Update();
//Always = 0
