Software Archive
Read-only legacy content
17060 Discussions
Triggering of function specified in SendMessage every frame
Rishabh_R_
I've used the SendMessage component to trigger a function when a particular gesture is recognized. However this does not fire continuously if we hold the gesture for subsequent frames. Only fires when there is a transition
Is there a way to achieve what I'm trying to do using SendMessage. If not is there an alternative way to do the same?
AndreCarlucci
What is this  SendMessage component? Are you using Unity or some programming language?
